Results 1 to 19 of 19
    Registered
     Nov 2007
     Kilmarnock, , United Kingdom
    Post imported post
    Hi,
    Looking for advice on what would be the best bet for a speaker cable upgrade (that aint £30 a metre!!)and should I biwire the speakers or use a set of jumper cables
    Cheers!!
    I`m over the moon & under the influence
    Super Wammer dudywoxer's Avatar
     sunny scunny
     colin
     Rega P9
     RB 1000 Apheta
     ios
     saturn
     squeeze box touch
     spen A6
     Rega Cursa
     Rega Exon
    Post imported post
    van damme pro studio grade, use bits for jumpers.
    This stuff, you may find it cheaper if you shop around
    http://www.clearly-av.co.uk/v545060.html
    My system is a gaggle of essex girls held in check by a pair of Brighton Queens
    Mardy Wammer Tel's Avatar
     Aug 2006
     Hove Actually
     Kevin
     Stogi, AN Io
     Audio Note S6c
     Rega Saturn
     SBT
     Rega
     LV OBX-R2
     Audio Note M3
     CocoSan 300B PP Mono
    Post imported post
    Upgrade from what?
    Don't bother bi-wiring though.
    "People are more important than animals" - Cloth Ears 22/2/13
    Registered
     Nov 2007
    Post imported post
    Sorry, Chord Co Rumour 2 cable at the moment (each cable around 3 mtrs). Also, is it worth throwing oodles of wedge on fancybanana plugs, stick with a twist or go with a terminal
     Dec 2007
     deepest darkest derbyshire, ,
    Post imported post
    just bought some of this and made jumpers from a short length,excellent improvement.
    cost imho,means nothing where cables are concerned.
    my other recommendation if you want a branded cable is Nva ls1.
    both of these cables have a neutral balance,as a rule of thumb with these cables,the thicker the more bass weight the trade off being the treble may be a little more recessed.
    i use van damme 2.5 mm
    i think the nva ls1 is 7 strand ls3,14 and ls5,21
    If it aint life threatening dont f-in worry about it !!!!!
     sunny scunny
     colin
     Rega P9
     RB 1000 Apheta
     ios
     saturn
     squeeze box touch
     spen A6
     Rega Cursa
     Rega Exon
    Post imported post
    I changed from Chord to Van Damme, easier to route, as in bends easier, and thats at 4mm sq. Any change in sound, I think so, but I assume thats simply because of the extra thickness of copper. The main reason I changed was cost, I need 2 x 11m runs and I refuse to pay stupid amounts of money for rebranded copper cable, covered in posh wrappers. And the Van Damme is a nice shade of blue, clashes very well with most things.
    Super Wammer bandit pilot's Avatar
     Jul 2007
     Junction 30 M1
     Rick
     Pioneer plc-590
     Jelco/Goldring 1042
     Tricord Dino/NCPSU
     Burmester 006
     Coincident TE
     Trilogy 902
     Lumley Ref 120 m/b's
    Post imported post
    why not have a chat with this fella.
    http://www.the-missing-link.net/index.htm
    they do free home trials on a buy it if you like it basis. send it back if you dont.
    they also do kit form stuff (some of which i have) and have to say that for the money they are excellent.
    Things you own, end up owning you!
     Aug 2006
     Hove Actually
     Kevin
     Stogi, AN Io
     Audio Note S6c
     Rega Saturn
     SBT
     Rega
     LV OBX-R2
     Audio Note M3
    Post imported post
    I just looked at this site, they don't seem to do speaker cables or am I looking in the wrong place?
     Jun 2007
     France
     Jean-Baptiste
     Bow ZZ8
     Brinkmann
     Focal Diablo
    Post imported post
    As mentionned in another post, the best way to do it is get some unterminated cable and use the final inch to go through your binding posts. Remember, the best connector is no connector at all, and the best jumper is no jumper at all. You could spend hundreds on platinum WBTs, Siltech jumpers or rhinoceros horn, they will still be in the way of the signal.
    Spend the money on the cables and as Tel commends, don't bother bi-wiring.
    JB
     Jul 2007
     Junction 30 M1
     Rick
     Pioneer plc-590
     Jelco/Goldring 1042
     Tricord Dino/NCPSU
     Burmester 006
     Coincident TE
     Trilogy 902
    Post imported post
    well i dont know what to say about that tel. just had a look myself and i cant see it either?. he certainly used to do speaker cables as i owned some of them for quite a while and they were very good indeed. might still be worth ringing to find out, a really nice bloke to talk to and a free no stringshome trial. i cant think of another cable manufacturer that offers such a service. i might be wrong though.
     Dec 2005
     Bahrain, , Bahrain
    Post imported post
    follow the link for interconnects and then scroll right down the page! I found em ok and I'm a non-believer!
    Cheers
    Dave
     Jul 2007
     Junction 30 M1
     Rick
     Pioneer plc-590
     Jelco/Goldring 1042
     Tricord Dino/NCPSU
     Burmester 006
     Coincident TE
     Trilogy 902
    Post imported post
    Cheers
    Dave
    so it is dave. bloody strange place to put your most expensive product though!
     Dec 2005
     Bahrain, , Bahrain
    Post imported post
    Well that's cable believers for you ! :green:
    Cheers
    Dave
     Dec 2007
    Post imported post
    Nva do a free home trial 2wks iirc
     Jul 2007
     Junction 30 M1
     Rick
     Pioneer plc-590
     Jelco/Goldring 1042
     Tricord Dino/NCPSU
     Burmester 006
     Coincident TE
     Trilogy 902
    Post imported post
    that doesnt surprise me. another cottage industry manufacturer that ive had some very nice equipment from, mine was the first gen early 90's stuff though.
    anybody want to know what soundpipe is and where to get it;)(by pm of course)
    Half man half cucumber johnniebaby's Avatar
     Seagull City
     Acoustlc Solid
     Hadcock 242/Kontra A
     Anatek MC1
     Sony DVP-S7700
     AUDIO INNOVATIONS700
     Audionote AN E's
    Post imported post
    I'm not crazy, my reality is just different to yours.............................
     Sunny Hampshire, , United Kingdom
    Post imported post
    Hi there,
    I use this stuff as I couldn't get away with the Van Damme Blue cable running all over the place - it really does clash with everything.....
    This may or may not have more appealing looks, but it appears to have a slightly "better" quality of construction and material (copper) than the Blue Studio series.
    I'm happy anyway.
    http://www.clearly-av.co.uk/V502000.html
    I brought a drum of it from here - works out cheaper than theBlue Studio per metre, and if you don't need it all you shouldeasily be able to sell on the leftovers and get the balance of your money back.
    http://www.letsautomate.com/10986.cf...7-d522664a3c01
    Should have plenty spare to make upsome jumpers with!!
    cheers,
    Dave.
    As I step over the still twitching corpses of the Cheeky Girls, I realise I\'ve only one bullet left.....and both Chas AND Dave are still standing....
    I am the LAW! smegger68's Avatar
     Jan 2006
     Bridgend
     Lenco 88
     Kuzma / Decca LSG
     Trichord Dino+
     Denon DVD 2900
     HTPC
     Audio-GD NFB 12
     SD Acoustics SD-5
     Ming Da MC-7R
     Audion / Alesis
    Post imported post
    Another vote for NVA cables here - I recently changed my Exposure speaker cable for NVA LS2 which is really cheap at the moment as they are clearing old stocks - I paid £18 for a nicely terminated 3 meter pair!
    It has brought about an improvement in clarity in my sound, especially in the midband and on vocals. The bass is also better controlled. The more expensive variants are supposed to be even better and you can part ex your old cables for the better ones for exactly what you paid for them! Cant be bad
    "Faster, Faster, until the thrill of speed overcomes the fear of death." - Hunter S. Thompson
  19. #19
    Super Wammer hifinutt's Avatar
     Dec 2007
     midlands , , United
     phil
     nil
     msb cd4
     bel canto fm 1
     bel canto 3.5 vbrs
     ml summit x
     puresound L10
     belles mb 200
    Post imported post
    if you like rumour, why don`t you move up to oddysey as there is loads about s/h and sounds superb [imho]
    You might slip, you might slide, You might stumble and fall by the roadside, But don't ever let nobody drag your spirit down, Remember you're walking up to heaven
    Don't let nobody turn you 'round, eric bibb
