Page 23 of 24 FirstFirst ... 1321222324 LastLast
Results 441 to 460 of 462
  1. #441
    Founding Wammer jonjin's Avatar
    Post imported post
    10uF Mundorf Supreme... exactly the same as before... I seem to be happy with 1uf on my tweets, haven't yet played with a 2uF.
  2. #442
     Feb 2006
    Post imported post
    10uF is more like it for 1kHz
    & this is with the Stereolab horns?
    what are you having to use to attenuate the S2 & tweeter? Wirewounds do slug the hf. I was quite shocked by traces I ran with & without L-Pad attenuation
  3. #443
    Post imported post
    On the S2 - 9dB l-pad with Duelunds. Standard resistors on the tweeter. I'm deaf above 14kHz anyways
    edit-you'll just have to come and listen!
    edit2-Sterelabs as the Azuras won't fit... unfortunately. The Azuras do blend better.
  4. #444
    Team Coco FTW! i_should_coco's Avatar
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    Post imported post
    Is it the source impedance of the LPAD? Or just the inductance? Have you measured how inductive they are?
    In the endless battle between theory and reality, reality has yet to lose.
  5. #445
    Post imported post
    I post this here as it parallel's my experience and provides a recipe for people wanting to build a horn system using modern drivers at a very reasonable cost. Also very well written with all the technical measurements.
    http://www.audiodesignguide.com/HiEff/HiEff.html
  6. #446
     North Thrumpton, ,
    Dismantling? What happened?
    It's never too late to have a happy childhood.
  7. #447
    Super Wammer paulf-2007's Avatar
     Jun 2008
     souf east for work
     plays vinyl
     plays cd's
     2A3
     diy
    Hi JJ, very useful link. I put together some open baffles and at present run 15" woofers with a 130w rotel amp and 8" full range drivers with 2A3 mono's. At JVS ( jims ) bake off it was agreed that there was cone break up from the 8" drivers and adam ( amdismal ) suggested limiting the 8" drivers frequency range to give it less to do. I decided to cut it off at 3000hz and have been looking at compression drivers and horns to cover from 3000hz upwards. It looks like there is an affordable way forward with the BMS drivers and tractrix horns on the stereo labs site.
    Quote Originally Posted by jonjin View Post
    main system: 15" open baffle bass, 200Hz auto-tech tractrix horn with BMS 4592mid, Raal 140-15D , Rotel RB861, J Sound labs 300B, 6n6P, 6h8c, 5C4M set DEQX PDC, MHZS cd88, Garrard 401. Colarro 2010
  8. #448
    Exploring options for 150Hz horns. Not many people make them. I'll update very slowly...
    http://www.autotech.pl/pdf/audio_en.pdf
    http://www.bentwoodhorns.com/
    http://www.stereo-lab.de/EN/spheric-...rns/index.html
    and Azura of course (where this all started)
    http://www.bcae1.com/xoorder.htm
    http://sound.westhost.com/lr-passive.htm
  9. #449
    Talking Christmas comes early to chez JJ
    RCA 9448 - 1.4" throat
  10. #450
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    Ooooh! Either that's a "children's" size cigar, or them are very big.
  11. #451
     Feb 2006
    Can't wait to hear how that goes. What's the plan re horns to attach to them?
  12. #452
    Quote Originally Posted by i_should_coco View Post
    Them are big mama Cohiba cigar!
    Quote Originally Posted by murray johnson View Post
    No definitely plans yet. Still trying to find a 150Hz horn. Coco might have one spare
    But this will be a far in the future project as the room is too small. It will be a 4-way:
    tweeter
    S2 down to 1kHz
    9448 200-1kHz
    probly folded bass horn
    JJ
  13. #453
    There is no honk AmDismal's Avatar
     St Albans
     Adam
     AT95E
     Has a keyboard
     Hums
     Made of fish
     Average >> Median
    WTF - a cigar?!?! Jeez man, haven't you got something that is actually a practical way of illustrating scale - like a ruler?!? A CD?!?!? You're a doctor, for crying out loud!?!?
    Cool though
    Fuck the horns, I just listen to the Snells now.
  14. #454
     Feb 2006
    tweeter
    S2 down to 1kHz
    9448 200-1kHz
    JJ
    Poof!
  15. #455
    Poof!
    LOLOLOLOLOLOLOLOL
    Just tested the pair and thank gd they both sound clean and healthy.
    edit, Adam, cigar is 18 cm long...
  16. #456
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    edit, Adam, my cigar is 18 cm long...
    No need to brag.
  17. #457
    Super Wammer ADPully's Avatar
     Oct 2007
     Witney
     If I
     Agreed
     With you
     we would
     both be wrong
    Nice one JJ with the RCA's and the hamlet moment - Hopefully I will have something 7" diameter to show you in a few weeks.
    Ipod Pure I-20, Battery ACK dac, Power amp Transcendent SE OTL 1.5W, plus Behringer ultracurve digital cross over and disco amp for bass, Speakers DIY 3 way Open Baffle, Hawthorne 15"Augie, Audio Nirvana 8"er and RAAL 140-15D
  18. #458
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    So, you wanna get some 1.4" to 1.5" throat adapter made up then?
  19. #459
    Ok boss
    edit to add spiel from ebay...
    Here we have a rare pair of RCA MI-9448 permanent magnet theatre compression drivers. As I understand the RCA models, the 9448 was produced from immediately after World War II until approximately 1950 when it was replaced by the MI-9458. I do not know what the differences are between the 9448 and 9458; the examples I have seen of both feature the same diaphragm and drilled hole pepper pot phasing plug. These units, like the WWII-era drivers produced by RCA for the U.S. Navy, featured a larger, heavier magnet structure compared to the later 9458 series. In the mid or late 1950s the 9458 series debuted, and carried the RCA theatre systems through the 1970s in A, B and C versions.
  20. #460
    Registered
     Nov 2010
     Bunbury, Australia
     Alan
     Garrard 401, Commonw
     Schroeder Model 2
     Hmmm?
     Esoteric P700(trans)
     MSB PowerDac
     Muratori 3 ways, oth
     First Sound Presence
     various tube, s/s
    Jonjin
    You "box" is full and cant be sent messages. Please empty so I can send you a message about 9448's thanks
    cheers
    Alan
