Results 1 to 13 of 13
    Wammer dougan's Avatar
     Mar 2006
     Devon, , United King
     Dougie
     Marantz SA-11
     Marantz PM-11
     PMC GB1i
    Post imported post
    Hi guys,
    First post, so please be gentle;)
    I was listening to the Primare I30 tonight, which I have on trial. I also have a Marantz CD17 KI Mk2, and every time I chose a track number on the Marantz remote control, the Primare would either go to standby or select a different input, depending on which number I picked.
    Is there anything that can be done about this? As much as I am enjoying the Primare, if this happens each time I try to change tracks, it would have a serious bearing on changing to it.
    dougan
     Harrow, , United Kin
     Mark
     NAS Spacedeck Heavy
     ARCAM CD192
     ARCAM A80 & P80
     Wilson Benesch Arc
    Post imported post
    Hi Dougan
    Welcome to wigwam.
    Couldn't see your question sitting all forlorn there, but I'm not the person to answer.
    If you really enjoy the sound of the Primare then either stop using the cd remote, move the two pieces of kit apart from each other, or, once it's yours, tape over the infra red eye on the amp.
    No doubt one of our resident techies will offer to re-programme your remote with new hexadecimal coding, after which point it won't work on anything
    Good luck
    W&F
    Effem
    Post imported post
    I doubt very much indeed there can be anything done about it as it's at code level in the remote systems. Short of having individual long straight tubes down which you fire the seperate remotes to each unit's remote sensor window you are pretty much stuck with the conflict
    Super Moderator Duvet's Avatar
     sarf london
     Feather
     Avid Acutus
     SME V / Airtight PC1
     Whest PS30 R
     SB Touch
     Micromega Mydac
     Kharma Ce 2.3
     ModWright LS36.5
     Plinius SA103
    Post imported post
    Alot of remotes are purchased in large quantities from the electrical stock parts bin. Creek and MF used identical remotes for years. I 'd fire an email of to Primare first and see if there is any remedy
    First pressings son !
    Wammer mosfet's Avatar
     Surrey
    Post imported post
    Unfortunately not. There is, as you have found out, similarity between the infrared control signals both pieces of kit use for remote operation. Hence the Primare is responding to the infrared signals sent by the Marantz Remote.
    I’d suggest you try and find the receiver diode on the front of the Primare (usually covered by a small piece of plastic) and cover this with a piece of black electrical tape. You’ll lose the remote function of the Primare but this will solve the problem you describe.
    Effem
    Post imported post
    Call that a techynical answer? My tubes idea was a better one by far as at least the poor man still has full remote functions on both bits of kit
     Mark
     NAS Spacedeck Heavy
     ARCAM CD192
     ARCAM A80 & P80
     Wilson Benesch Arc
    Post imported post
    Oi! I suggested that first, and I'm not technical
    You're suppose to come with an answer which refers to the refractive indices of a marantz x275 transmitter compared to the super diodic, 4 times over-sampled, minimised gain receiver in the primare
    W&F:minikiev:
     Surrey
    Post imported post
    Oh yes, so you did. All due acknowledgement for sticky tape solutions to W&F!
    Not until page four
    Pah! Remote controls on amplifiers are for lazy arses anyway (but you could use a flexible optical fibre as a light guide given the properties of total internal reflection, angle of incidence blah, blah, blah.. :yoda
     Mar 2006
     Dougie
     Marantz SA-11
     Marantz PM-11
     PMC GB1i
    Post imported post
    Many thanks for the replies guys!
    I have emailed Primare and will report back with their answer.
    I am of the opinion there is nothing that can be done. Not the end of the world I know, but if a amp has a remote it would be nice to use it.
    dougan
    Super Wammer cjr's Avatar
     UK
    Post imported post
    Simple query here : Have you tried the Primare remote for the I30 to operate the CDP ?
    Linn LP12~Sony CDP-X3000ES~Sony ST-S3000ES~Denon DVD-2900~Marantz PS-17~Dynaudio Contour 1.3 MkII|Sony BDP-S760~Sony MDS-JB930QS~Sony SDP-EP90ES~Sony TA-N55ES~Diapason Emera|Sony PS-212A~Ikey RM3~Sony PS3~Sony STR-DA3200ES~Tannoy Rev R1+Centre~KEF 30B
     Mar 2006
     Dougie
     Marantz SA-11
     Marantz PM-11
     PMC GB1i
    Post imported post
    Hi CJ,
    Nice to hear from you again!
    No, I have not tried the Primare remote, it was still packaged up, unused So I did not try it. Bugger it, its mine for a week so I will try it.
    Have just tried the Primare remote, all it seems to change is the volume level on the cd player. The Marantz has a volume control level, which I always keep at maximum.
    dougan
     UK
    Post imported post
    dougan wrote:
    Hi CJ,
    dougan
    Dougan IIRC there is a way of selecting the CD source on the Primare “menu”, that allows the remote to be used in conjunction with Primares CD/DVD sources, you may need to read the manual or call Primare to find out how. But its working the volume on the Marantz which is a positive sign, a £25 universal remote may have to be the solution for the marantz CDP.
    Anyway you may like this little shot of the new Pre 30 & brace of A30.2s in a nice Spectral rack.
    Effem
    Post imported post
    It's worth a shot CJ although even with a universal remote I think there is still going to be a code conflict with the remotes. Isn't it so annoying when something as small as this issue mars an otherwise enjoyable purchase?
