Results 1 to 12 of 12
     Mar 2006
     Ramsgate Southeast K
     None
     Meridian G08
     AVP2-Bryston 4BST
     Proac studio 100
    Post imported post
    Im looking for 1mm or bigger to deliver current for my poweramps only need say 2x 1 meter at most and teflon insulation possible metal screen outer tubefor cables too?
    Pioneer 508D & 4280 tv's & 51 bluray,Meridian G08 Proceed,AVP2,Bryston 4BST,Proac Studio 100\'s on target R2 stands & a dedicated hifi mains install.
    Registered
     Apr 2006
    Post imported post
    Try giving "Zanash" a PM, he can get hold of 1mm 4n Solid silver possibly bigger?, It is a bit pricey compared to 0.5mm. I used some1mm recently to replace the cheapPSU leads that connect between my MF XPSUV3 & MF X10V3 & XDACV3. Made a big difference, that you normally get when using silver, dynamics, cleaner sound and better speed.
    In regards to Sleeving you can get it online from RS they do various sizes,anyway it's the 1.27mm Clear PTFE you would be looking for.If your really stuck, PM meas I may have some kicking around.
     Mar 2006
     None
     Meridian G08
     AVP2-Bryston 4BST
     Proac studio 100
    Post imported post
    Thanks mailled him so await the reply
    Did you get any WBT plugs yet? my Mithrillsare running in superb even at low volume levels I can still hear cristal clarity and define the bass fully,why do we have to have neighbors would love volume to run at consistent level ideal not mega loud but reasonableyou know what I mean.
     Mar 2006
     None
     Meridian G08
     AVP2-Bryston 4BST
     Proac studio 100
    Post imported post
    Iv just contacted The missing link now and got a deal on some wire so sorted thanks all who looked replyed all the best bagpuss.
    Registered
     Apr 2006
    Post imported post
    Hi, I've ordered the some Eichmann 4n Silver Bullets with the missing link, the WBT Topline Silvers look great, but apart from the thin layer of Platinum thats on WBT, The Eichmanns are the same spec both being that they are made of 4n Fine Soild Silver, and they are half the price !
    Anyway I will be making a New Digital I/C and replacing the plugs on my other I/C. Thats the problem with Silver, IMO Once you make the jump from Copper/ Goldto Silver,it's hard to go back,such is the improvement in sound.
    Once I've wired them up, I will let you know my thoughts
     Mar 2006
     None
     Meridian G08
     AVP2-Bryston 4BST
     Proac studio 100
    Post imported post
    I used the gold plated copper ones the siver wbt's a bit astronomical price jump eichmanns can be tight fitting and not so solder friendly less space but whats said I dont know for sure as never seen or used in the flesh?
    I think you will be happy with the extra detail you missed out with standard plugs though as Meridian says in it'sbrochures "music that sounds this good can be addictive" bloody hell yes
    Registered
     Apr 2006
    Post imported post
    What size/ type cable did you get ?
     Mar 2006
     None
     Meridian G08
     AVP2-Bryston 4BST
     Proac studio 100
    Post imported post
    0.5 but 3 runs each for positive negative ground and they are going to cover it all for me too £20
    Registered
     Apr 2006
    Post imported post
    Sounds good,lets us know how you get on.
    Pub Cat Cloth-Ears's Avatar
     Here
     Arse Cloth
     In microwave.
     Disconnected.
     Nice ornaments
     Never on.
    Post imported post
    Stellabagpuss: Are you a cousin of mine ?
    A proud Scotchman from bonnie Scotchland
    Registered
     Apr 2006
    Post imported post
    Must be those dam Mice on the mouse organ !! Ha Ha. I'm sure we have chatted in the past on Zerogain. I like the photo !!
     Here
     Arse Cloth
     In microwave.
     Disconnected.
     Nice ornaments
     Never on.
    Post imported post
    We may well have but I do not recall.
    I am not often in that dark place any more. I go back occasionally.
    I prefer it here with all the frollic and fun. I got banned for a week once on the other place, for cheek. I even guessed he was a teacher, and his profile said he was !
