Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Super Moderator Duvet's Avatar
     sarf london
     Feather
     Avid Acutus
     SME V / Airtight PC1
     Whest PS30 R
     SB Touch
     Micromega Mydac
     Kharma Ce 2.3
     ModWright LS36.5
     Plinius SA103
    Post imported post
    Ok whats peoples views. I 've had both a few times and i've got to say that a pre power wins most of the time imho. Theres a greater sense of depth and control to the music especially if upping the ante with a pre and two mono's. Basically a good biggun beats a good little'n.
    Shall i stay or get my coat.
    First pressings son !
    Super Wammer TIU's Avatar
     Dec 2005
     B'ham-Not-On-Sea
     Gary
     Modded Lenco GL69
     Linn LVX/G Eroica LX
     Slee Fanfare MC
     Pioneer PD-S801
     pending
     Amphion Argon³
    Post imported post
    I'll add my views next week, after I hear my first pre/power amps in my system.
    Of course the big question is: which cable to buy to connect the two? And having decided, would a more exspensive cable squeeze a bit more fidelity out?
    (Did I just mention cables?)
    'The pump don't work 'cause the vandals took the handles.'
    Super Wammer The Strat's Avatar
     Buckingham, , United
     Lindsay
     Roksan Xerxes 20+
     Artemiz/Dyn XX2
     Naim Superline
     Naim CDX2/XPS2
     Dyn Contour 1.8
     Naim 282/hi-cap
     Naim 250-2
    Post imported post
    Good evening Duvester,
    By coincidence I've just been comparing a supernait on home loan in a friends system with my 282 pre and my old still unsold 200 power. I think your prognosis is just about spot on the supernait is an excellent product but with the pre-power there was more control, everything seemed in better order and more defined.
    But there is obviously a premium just for having 2 boxes (3 if you have monos) and no doubt there are some cracking integrateds out there.
    As ever you pays your money...........
    Strat
    Wammer stobear's Avatar
     Sep 2005
     Ratoath, , Ireland
     Rob
     Hiding away somewhere
     Luxman
     Jadis
     Revel
    Post imported post
    The foo is the only thing that will change the sound, assuming you are not influenced by any type of mood/weather/mains or digetive change
    Acorns....hmmm!
    Founding Wammer kingsxfan's Avatar
     Wirral
     Phil
    Post imported post
    I don't think its a definite to say pre/power is better than an integrated. I've had pre/powers in the past as well as integrateds and they just did what they did.
    If they are well designed with top notch PSU's, there is no reason why either won't sound as good as the other. Some integrateds are almost the same as the pre/power versions, just well, err..integrated.
    I've read reviews for the MA2275 vs the MC275 and MC201(?) pre. The pre/power is just a bit more expensive. The reviewer said each did some things better than the other and it would be down to preference, andhow much space you had. The former is fooking huge and doesn't fit on your average rack. Don't know how I'd deal with it in two bits.
    Cogito, ergo doleo. rabski's Avatar
     Dec 2006
     East Mudlands
     Well Tempered
     Transfiguration
     Hashimoto/Art Audio
     RA Opus 21
     Squeezebox
     Audiosector with SB
     I think not
     LV OBX-RW
     SJS Arcadia
     845 SET
    Post imported post
    The very best integrated amps are effectively a pre amp and two power ampsin one box,ie: separate power supplies and decent isolation between parts. Combining power supplies is almost always going to be some sort of compromise.
    Mind you, I've heard some extremely good integrated amps and some bloodyawful pre/power combos.
    I know that you believe you understand what you think I said, but I’m not sure you realise that what you heard is not what I meant.
     Mar 2009
    Post imported post
    Prolly true that a good pre-power beats a good integrated from the same company, but some of them can get very close, and often have a charm of their own. Add in the relatively small price and size, and the law of diminishing returns, and it's no surprise that integrated amps like the A&R A60 and Naim's various Naits have so many fans.
    For more money, I've heard a pretty fine Lavardin and a great Densen integrated, and as something like an Ongaku no doubt proves, power isn't everything.
     Lindsay
     Roksan Xerxes 20+
     Artemiz/Dyn XX2
     Naim Superline
     Naim CDX2/XPS2
     Dyn Contour 1.8
     Naim 282/hi-cap
     Naim 250-2
    Post imported post
    I think one of the advantages of pre-power is that you have more upgrading possibilities - and the chance to balance your system as you think appropriate e.g. single stereo or 2 monos. Experience has told me that the Pre has far far far more impact on the staging of the sound (If that's the right way of describing it) than some realise.
    Strat
    Super Wammer cjr's Avatar
     UK
    Post imported post
    Below £3000 I'd go for an Integrated.
    Above £3000 I'd seriously look at Pre-Powers.
    That is just my ears and my preference though from kit I have heard. Much better VFM v Performance ratios below £3000 in integrateds I find. Then you step into an area of diminishing return, increase in performance but it will cost you.
    Linn LP12~Sony CDP-X3000ES~Sony ST-S3000ES~Denon DVD-2900~Marantz PS-17~Dynaudio Contour 1.3 MkII|Sony BDP-S760~Sony MDS-JB930QS~Sony SDP-EP90ES~Sony TA-N55ES~Diapason Emera|Sony PS-212A~Ikey RM3~Sony PS3~Sony STR-DA3200ES~Tannoy Rev R1+Centre~KEF 30B
    Moderator Papa Lazarou's Avatar
     Bletchley, Bucks
     Phil
     Voyd
     HR100S, Orpheus
     Tribute, AI P2
     CEC TL53Z
     Rega DAC
     AI Alto Mk1
     LV OBX-R2
     Audio Note Japan M7
     NAF 845 SET
    Post imported post
    I would imagine within the same brand that the pre-power will offer ultimately better performance. A good integrated can outperform a pre-power from another brand, as i've discovered.
    My Flickr Page: http://www.flickr.com/photos/philnmorgan/
    When a man steals your wife, there is no better revenge than to let him keep her. (David Bissonette)
     UK
    Post imported post
    Papa Lazarou wrote:
    I would imagine within the same brand that the pre-power will offer ultimately better performance. A good intergrated can outperform a pre-power from another brand, as i've discovered.
    Nail head interface there Phil. It is all about comparing the others marques.
    Awful Tory browellm's Avatar
     Sep 2008
     Nottingham
     Mark
     Acoustic Solid Wood
     AN Arm III/AN Io
     Allnic H1500/AN S2
     Modwright TP
     Avantgarde Uno Nano
     Kondo M7
     LV Argento
    Post imported post
    Would I rather have a Kondo integrated, or a Cyrus pre/power?
    I think the discussion is moot. Better to talk good amps, and bad amps.
    Super Wammer def's Avatar
     Oct 2008
     Great Missenden
     One day
     EMM Labs
     Kharma
     Aesthetix
     Kharma
    Post imported post
    Ah, but would you want a Kondo intergrated or pre/pwr?
    Generally amps are built to a price with more spent in a given range on the pre/pwr combo. A fair amount of any up charge is the casework and with an easy speaker load the pre/pwr isn't always going to be the best option.
    The best speakers are often the hardest to control or most revealing. Its here the usually lower compromise pre/pwr justifies its existance.
     Perth, Scotland
     Miles
     Not yet
     Mac mini
     Metrum
     Leben
     Living Voice
    Post imported post
    Hmm. Let me think... er... it's not a trick question is it?
    . gthang's Avatar
     Jun 2008
     My
     system
     sounds
     the
     same
    Post imported post
    Papa Lazarou wrote:
    I would imagine within the same brand that the pre-power will offer ultimately better performance. A good integrated can outperform a pre-power from another brand .
    Enough said imo
     UK
    Post imported post
    Well what are the best sub £3000 Pre-powers then? that compete with Integrateds ? I faced this dilemma with my Primare A30.1 II, the next step up for me was Integrateds such as :
    Krell X400i, Moon I-5, Sugden A21SE, Karan I180.
    I ended up thinking that I could have got a Primare Pre30 with A30.2 for the same cash as the Integrateds above. Mind you I upgraded with a 1989 Sony ES !!
    Super Wammer SteveS1's Avatar
     Jan 2008
     Weald, Kent, UK
     Duh!
     Nope
     Mini/U3/Weiss 202
     Berning ZH270
     ART Emotion Signatures
    Post imported post
    Me too.
    Comparing amps from the same brand tells you nothing about the potential of better designed integrated amps.
    It merely indicates that they have their price structure right.
    Steve
    Wammer Steveh's Avatar
     Feb 2007
     Wakefield, UK
     Steve
     only in microwave!
     Marantz CD17 M2
     Marantz CD6000OSE LE
     Marantz PM6000OSE
     Tannoy Eyris
     CHORD CPA2800
     CHORD SPM800B
    Post imported post
    And better still, IMHO, is a pre and 2 power amps(monoblocks).
    I started out with nothing and I've still got most of it left..............pure genius
  19. #19
    Super Wammer dudywoxer's Avatar
     sunny scunny
     colin
     Rega P9
     RB 1000 Apheta
     ios
     saturn
     squeeze box touch
     spen A6
     Rega Cursa
     Rega Exon
    Post imported post
    It depends what your looking for of course, but for my choice I would stack my pre/mono's upagainst any sub 3500 integrated.
    My system is a gaggle of essex girls held in check by a pair of Brighton Queens
  20. #20
    Moderator myrman's Avatar
     Oracle Delphi MkIII
     SME V, AN IO1
     TDP/Allnic H1200
     Halcro EC800
     Laptop/Jriver
     Stello DAC100
     Zingali Overture .3S
     Art VPS
     Art Quintet
    Post imported post
    Strat
    This is why I took the pre/power route some time ago. My pre takes digital inputs making it far more flexible than many standard preamp.Using a preampgives me the flexibility to choose the power amps that suit my taste which at present are a pair of Bel Canto Evo 200.2s and performance was as I had hoped. ie my previous Evo2i integrated sounded good but the pre/power sounds better and the pre/dual mono evos sound even better.
