Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
  1. #41
    Finally a box KEEPER Craig's Avatar
     Copenhagen
     Craig
     Mac / ATV
     Beresford 7520
     MF X-A1
     Tannoy Cheviot
    Post imported post
    So. I have a quetsion regarding an external hard drive to my Mac Mini
    The drive I am currently using (A Seagate 750GB) doesn't spin down / standby when nothing is playing, so it keeps on running through periods of inactivity, increasingly with an annoying whir.
    Is this an issue with the MAC - i.e. that I won't be able to find a HDD which chills the f*** out once in a while?
    Or do most HDD's have the ability to take a breath and put themselevs into standby, and I have just got a retarded example?
    WTD: JVC AX-SD1 amplifier (looks like this one)
  2. #42
    Wammer opusover21's Avatar
     Mar 2007
     Next door
     Mrs Brown
     Mac mini, SSD
     Amarra, FireWire
     Weiss DAC2
     Beolab 5
     In speakers
     Class D ICEpower
    Post imported post
    Craig - I dont know the specific drive but guess its a 3.5" type rather than a 2.5"?...I think its that specific drive...its certainly needs a bit more consideration than just cost and capacity...there are some quite big differences between them for what seems such a simple device what with the actual drives themselves, cooling fans which are to be avoided like the plague.........I read (sad I know) and tried a few...the WD drives I can honestly say are whisper quiet and never had a problem...the seagate 2.5 drives are now 750GB for decent money in theory should be quieter...I've got a 2.5" 500GB drive and its fine......all this assuming its in the listening area...?
  3. #43
    Awful Tory browellm's Avatar
     Sep 2008
     Nottingham
     Mark
     Acoustic Solid Wood
     AN Arm III/AN Io
     Allnic H1500/AN S2
     Modwright TP
     Avantgarde Uno Nano
     Kondo M7
     LV Argento
    Post imported post
    If the drive won't spin down, it usually means there is a process or program accessing it somewhere. What happens when the Mini is in Sleep mode?
  4. #44
     Mar 2007
     Next door
     Mrs Brown
     Mac mini, SSD
     Amarra, FireWire
     Weiss DAC2
     Beolab 5
     In speakers
     Class D ICEpower
    Post imported post
    Mark good point...turn off sleep mode and also in security block spotlight access to all drives
  5. #45
    Registered
     Jun 2008
     London, , United Kin
     Linn LP12
     Mac/Weiss Dac2
     Berning ZH270
     Tannoy Cheviots
    Post imported post
    Thanks for the excellent write up.
    My headless Mac Mini running Snow Leopard doesn't require a permanent mouse connection. It restarts fine without any peripherals connected. It also manages to wake from sleep via wi-fi from an iTouch or screen share from a MacBook. I was always told WOL (Wake on Lan) was impossible over wi-fi!!
  6. #46
     Copenhagen
     Craig
     Mac / ATV
     Beresford 7520
     MF X-A1
     Tannoy Cheviot
    Post imported post
    Thanks fellas - will look into those issues
  7. #47
     Copenhagen
     Craig
     Mac / ATV
     Beresford 7520
     MF X-A1
     Tannoy Cheviot
    Post imported post
    Stuart - thanks for the advice. It's a 3.5, yes
    Mark I rarely sleep the mini to be honest (I know) so I'll start that tonight and see what difference it makes
  8. #48
    Wammer oldius's Avatar
     Dec 2008
     Helsby, Cheshire
     Geoff
     G99, 401, TD125
     too many for field
     Leema Agena
     SB Touch
     Laptop
     Caiman
     Shahinian Obelisk
     Bryston BP25
     Bryston 4B SST2
    Post imported post
    Any software required to use Spotify premium through Airport Express on PC? If so, please recommend something that works well!
  9. #49
     Mar 2007
     Next door
     Mrs Brown
     Mac mini, SSD
     Amarra, FireWire
     Weiss DAC2
     Beolab 5
     In speakers
     Class D ICEpower
    Post imported post
    I cant believe this thread is still going after so many weeks...
  10. #50
    Wammer pwiles1968's Avatar
     Feb 2011
     In the Middle Bit
     Genie occasional use
     ATV > AudiolabCDQ
     Bel Canto Evo II
     B&W 805s
    Nice post, I currently run a Gen 1 ATV as a server with xHDD but a mini will be on the books if it ever dies. You may want to add USB connection to DAC as an option, there are quite a few external DAC's onthe market that will take a USB input from a MAC or PC.
    I am not sure if it is the iPad I am using or the article itself but there appears to be some text corruption makes reading he post a touch difficult.
    Paul...
  11. #51
    Super Wammer leenorris78's Avatar
     Jun 2009
     London - SE15
     Lee
     technics 1210
     MHDT Havana
     RC-995 pre
     Mackie HR624Mk2
    I thought I would post here to keep threads together and I'm sure that others may find replies useful.
    As I run a mac, and hearing about the wonderful db power amp being much better than the inferior iTunes for ripping, i discover db is windows only.
    Is there a better program available that rip better than iTunes?
    I found this:
    http://www.macupdate.com/app/mac/234...ssless-decoder
    Or is there better? Or am I being paranoid? I was thinking of ripping in third party software, such as x-lossless, and dropping the files into iTunes?
    If I rip in itunes AIFF, am I chained to itunes forever? If so, what's the way around this?
    Many questions that 10 hours on the net have not answered. Many thanks and best regards, Lee
  12. #52
     Jun 2009
     London - SE15
     Lee
     technics 1210
     MHDT Havana
     RC-995 pre
     Mackie HR624Mk2
    There is also MAX and RIP
    http://sbooth.org/
  13. #53
     Sep 2008
     Nottingham
     Mark
     Acoustic Solid Wood
     AN Arm III/AN Io
     Allnic H1500/AN S2
     Modwright TP
     Avantgarde Uno Nano
     Kondo M7
     LV Argento
    Quote Originally Posted by leenorris78
    I found this:
    I'd say XLD and MAX are the best rippers for the Mac
    Ripping to AIFF is absolutely fine. The whole point of all the lossless codecs is you can transcode between them with no loss of quality. So if for some reason you want to change you can use batch based tools to do so. If you are sticking with the MAc, I would personally rip to ALAC, it's half the size of AIFF, the same quality and will cost you a lot less £ in disk space.
  14. #54
     Jun 2009
     London - SE15
     Lee
     technics 1210
     MHDT Havana
     RC-995 pre
     Mackie HR624Mk2
    So rip cd's with XLD for more accurate rip quality and then drag and drop into ITUNES?
    This would leave me with 2 copies, just what I want.
    EDIT: having spent a good few hours trying to work out what all the options are and trying to get XLD to work correctly, I have decided that XLD is not for me. As I can see it, XLD checks a database to see if the cd has been ripped properly, leaving you to source a better copy if your original is screwed. If your original is screwed, you liked it like that in the first place. Also, I can only get XLD to save tracks from different albums in one long list, not what I need for archive. Looks like its iTunes for me.
    Good luck if you decide to use XLD. For some it could be useful. Not for me.
    EDIT2: This helps to tell you how to set preferences to organise files properly.
    http://www.computeraudiophile.com/co...LD-Preferences
    This tells you how to import XLD files automatically into iTunes
    http://www.youtube.com/watch?v=rvksYCJuPy8
