Results 1 to 10 of 10
     Jul 2009
     stourport on severn
     mick
     yamaha
     old yamaha
     dynaudio excite 16
    Post imported post
    Hello folks i want to use my speakers for tv and audio but the way my room is the only way i could do this is to wall mount them.Any ideas on the best way to do this.
    Thanks Mick
    HiFi Dealer Wammer bigdur's Avatar
     Jul 2007
     Malvern
     Jack
     Acoustic Solid
     SPU Spirit + AN-IO
     Pro-ject Phono RS
     Audionote CDT-2
     JRiver
     Audionote 2.1 V2 Bal
     Modwright KWI 200
     Tune Audio Anima
     Modwright 36.5 DM
     Modwright KWA SE
    Post imported post
    Erm, with wall mount brackets
    Trouble is, Quad 11s pushed right against the wall...
    Push them back now and see what I mean.
    Super Wammer SergeAuckland's Avatar
     May 2008
     Bury St Edmunds, UK
     Serge
     EMT948, TRS9000, 401
     AT33ML, TSD15, MC-10
     SBT
     Meridian 206
     DEQ & CDQ
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Post imported post
    Thanks Mick
    Omnimounts. www.omnimount.com
    Huge range of wall and ceiling mounting items, for just about every weight.
    S.
    Think, eat, sleep, rugby It Cost How Much!?!'s Avatar
     Oct 2008
     Cheshire, good side.
     Bob
     Transrotor Fat Bob
     Transrotor/Koetsu
     Hagerman Trumpet
     Esoteric P-30
     Pierre Lurne Audio M
     Gamma Rythm Ref
     Snell Type J
    Post imported post
    What is the wall made of?
     Jul 2009
     stourport on severn
     mick
     yamaha
     old yamaha
     dynaudio excite 16
    Post imported post
    brick its the wall to next door.
    i realise wall mounts lol.just thought might be better on shelfs
     Jul 2007
     Malvern
     Jack
     Acoustic Solid
     SPU Spirit + AN-IO
     Pro-ject Phono RS
     Audionote CDT-2
     JRiver
     Modwright KWI 200
     Tune Audio Anima
     Modwright 36.5 DM
     Modwright KWA SE
    Post imported post
    Watch those rear ports, I have some 11ls for AV use and they like a bit of room otherwise they boom.
     Jul 2009
     stourport on severn
     mick
     yamaha
     old yamaha
     dynaudio excite 16
    Post imported post
    ok.is it a bad idea then
     Jul 2007
     Malvern
     Jack
     Acoustic Solid
     SPU Spirit + AN-IO
     Pro-ject Phono RS
     Audionote CDT-2
     JRiver
     Modwright KWI 200
     Tune Audio Anima
     Modwright 36.5 DM
     Modwright KWA SE
    Post imported post
    You could try stuffing the ports, best to push them back now and see what you think before you buy brackets and drill your wall etc
     May 2008
     Bury St Edmunds, UK
     Serge
     SBT
     Meridian 206
     DEQ & CDQ
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Post imported post
    Bad idea is relative. Wall-mounting rear ported 'speakers is never a "good" idea, but at times there is little alternative. Try moving the 'speakers closer and closer to the wall, and see what the minimum distance is for an acceptable sound.Ifthen that still gives you room for wall brackets (Omnimounts generally space something like 10cms from the wall) you know it's worth doing. If you can't get them closer than, say 20 or 30cm from the wall, then no wall mount will space that far, so the choice is then either different 'speakers or different mounting arrangements.As the 'speakers aren't terribly heavy, you could try a TV bracket if you really have to wall mount them, and can't have them closer than 20-30cms.
    You could also try bunging up the bass port with something like a rolled-upsock if bass booms, but generally, moving the port closer to thewall will reduce bass anyway. It's the wall gain caused by getting close to the reflective back surface that causes the problem.
    S.
     May 2006
     nr Cambridge, ,
     Bob
     skipped
     bel canto CD2/Dac3
     Esoteric UX-3
     revel
     Chapter Preface Plus
     Chapter 500 monos
    Post imported post
    Wall mounting could increase the nuisance factor for your neighbours by increasing the transmission of sound to their side, especially bass notes which will rumble through, even if relatively speaking standmounts/bookshelf speakers produce less bass than a floor stander.
