Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    FTM! pmac's Avatar
     Co. Durham
     Palmer 3
     O.L./IoGold/SPU N
     Kondo KSL-SFz/Vida
     UR Unico CDE
     coming soon!!!
     Audio Note Japan M7
     Beard P50 - for now!
    Post imported post
    I`ve tried most, if not all, of the manual methods and, without exception, they arevery poorwhen compared to the results from a vacuum based RCM with a goodquality cleaning solution.
    I realise that it is beyond what you are looking to spend, but you will always be doing things by half until you get there.
    Second hand models do sometimes crop up atreasonable prices, but not many, which is probably testament to how good they are.
    If you have no intentions of making this sort ofinvestment, there was a thread not too long ago where NCDRAWL (I think)was raving about a manual system which worked via the kitchen tap. (can`t find the thread, or I would have included a link). Not sure how much it cost, but he certainly rated it.
  2. #22
     Nov 2007
     South Devon, , United Kingdom
    Post imported post
    I have used a VPI for some years now. Its a noisey as hell but cleans the LP's perfectly. Unfortunatly it does zip for records damaged by as naff stylus.
    Phil
  3. #23
    Sceptical Wammer
     Oct 2005
     East Midlands, Unite
     Tony
     Lenco Soup
     Rotel RCD991
     Wad Kat88
     Spendor S100
    Post imported post
    I disagree. I think this overstates it. Done with care and patience the manual methods can bepretty much as effective as the VPI/Moth/Clearaudio style machines (which I have used), the problem is you do need to be meticulous and you do need to spend a lot more time on it. That the machines save a lot of time and effort is undoubtedly true.
    The method of getting the dirt out and into solution is pretty much the same. A brush and liquid - the only difference is that you are moving the brush round rather than a machine moving it for you. The method of removing the dirty solution is the big difference, but there is no reason why rinsing properly with dfistilled water (not tap water) and (very importantly) making sure that once rinsed you only use a clean microfibre cloth (keeping a stock in hand if you doing a few records), it shouldn't be pretty much as effective, andin practice it is.
    At times over the years I've had a machine to hand and not had a machine to hand. I wouldn't have said there was anything much in it in terms of how clean the records were either visibly or audibly using either method, but I know if I had a lot to do I'd want a machine ... and some ear defenders.
    Now I can't speak for the Monks and Loricraft machines, other than that looking at the way they work on a groove by groove basis, in theory they should be the perfect method. Bloody expensive though.
  4. #24
    HiFi Dealer Wammer bigdur's Avatar
     Jul 2007
     Malvern
     Jack
     Acoustic Solid
     SPU Spirit + AN-IO
     Pro-ject Phono RS
     Audionote CDT-2
     JRiver
     Audionote 2.1 V2 Bal
     Modwright KWI 200
     Tune Audio Anima
     Modwright 36.5 DM
     Modwright KWA SE
    Post imported post
    Emma Royd wrote:
    Uncle Ants wrote:
    Emma Royd wrote:
    bigdur wrote:
    I'd advise against spraying a cleaner on and wiping it off with a cloth, it wont properly clean the disk and will no doubt leave a load of shite behind too
    Cannot for the life of me see how this works by spraying a chemical onto the disc,then rubbing excisting shite into the grooves.
    It doesn't .... that's why it needs to be rinsed off wth distilled before drying.
    Do the instructions state that the disc must be rinsed after spraying?
    I was refering to the meathod in post 3. Bad idea imo
  5. #25
    FTM! pmac's Avatar
     Co. Durham
     Palmer 3
     O.L./IoGold/SPU N
     Kondo KSL-SFz/Vida
     UR Unico CDE
     coming soon!!!
     Audio Note Japan M7
    Post imported post
    and that is my point, rinsing just does not clean all of the residue from the grooves in my experience.
    Maybe my technique was flawed....
  6. #26
    Sceptical Wammer
     Oct 2005
     Tony
     Lenco Soup
     Rotel RCD991
     Wad Kat88
     Spendor S100
    Post imported post
    Maybe it was. You need to use a lot of it in a squeezy bottle, so that it flows off the record. Much as if you ran it under the tap. It needs to take the dirty solution away with it down the sink.
  7. #27
    Wammer flaxton's Avatar
     Aug 2009
     barry vale of glamorgan, ,
     rega planer 3 modified
     rega saturn
     krell kav400xi
     pmc 21s
    Post imported post
    i use my old wharfdale turntable from 1972 to clean my vinyl. after cleanibg i suck out the debris with an old cleaner. not brilliant but does quite a good job.
  8. #28
    Super Wammer Borats Baby's Avatar
     May 2006
     Boredsville, , Unite
    Post imported post
    Before I got the Knosti manual cleaning machine, I cleaned all my charity shop vinyl using either one of the 2 methods in post #3.
    One particular LP had some bad tidemarks where it had been in the damp, and mould all over it. A sponge in the sink and a quick rinse saw most of the shite gone and a quick scrub with the AM spray and a microfibre cloth finished the rest off.
    For lightly soiled records, the spray works fine on its own, gets rid of fingerprints and such like. The muck comes off on the cloth, you can see it ! The liquid left on the record evaporates away and your left with a record which plays without any pops or clicks and sounds great.
    Whats not to like ?
    The op stated he didn't really want to spend £50, given that stipulation Jack, what would you suggest ?
    BORED FUCKING SHITLESS !!!
  9. #29
     Jul 2007
     Malvern
     Jack
     Acoustic Solid
     SPU Spirit + AN-IO
     Pro-ject Phono RS
     Audionote CDT-2
     JRiver
     Modwright KWI 200
     Tune Audio Anima
     Modwright 36.5 DM
     Modwright KWA SE
    Post imported post
    One particular LP had some bad tidemarks where it had been in the damp, and mould all over it.Â* A sponge in the sink and a quick rinse saw most of the shite gone and a quick scrub with the AM spray and a microfibre cloth finished the rest off.Â*
    For lightly soiled records, the spray works fine on its own, gets rid of fingerprints and such like.Â* The muck comes off on the cloth, you can see it !Â* The liquid left on the record evaporates away and your left with a record which plays without any pops or clicks and sounds great.
    Whats not to like ?
    Â*
    I wouldn't and didn't suggest anything for a good reason. Those reasons have been discussed in previous posts.
  10. #30
    Acc shut see Purité North
     Dec 2007
     Purité North
    Post imported post
    Nah, don't listen to these muppets, wire brush and Dettol every time
    Got me out of sticky spots a few time I can tell you!
    Got some sticky spots out me a few times too, by thunder!
  11. #31
     May 2006
    Post imported post
    Furry Muff
