Results 1 to 8 of 8
    Super Wammer adsa's Avatar
     Jan 2007
     Engerland
     Adam
     MF M1 / Transfig
     Yamaha MCX1000
     Linn
     None!
    Post imported post
    Hi Folks
    If I have US voltage 120v at 60hz device, which uses a switch mode PSU. Will a UK converter running at 50hz be fine?
    Regards
    adsa
    845 SET's ROCK!!!
     Jan 2007
     Engerland
     Adam
     MF M1 / Transfig
     Yamaha MCX1000
     Linn
     None!
    Post imported post
    Worked it out. Switch mode power supplies are not that bothered about frequency change...
    845 SET's ROCK!!!
    Registered
     Apr 2010
     East London, , United Kingdom
    Post imported post
    or voltage input
    Banned
     Oct 2007
     Fuck
    Post imported post
    Cats squirrel wrote:
    or voltage input
    Careful... it depends. Some are designed for universal voltage and some ain't.
    Cogito, ergo doleo. rabski's Avatar
     Dec 2006
     East Mudlands
     Well Tempered
     Audio Note IQ3
     Pending
     Awful
     Squeezebox
     Audiosector
     Not as such
     LV IBX-RW
     Cloney heaven
     845 SET
    Post imported post
    or voltage input
    Most I've seen are Euro spec and will run on 110-120v with no problem. But I do have one here that's designed for the US market and has a max of 120v.
    They're usually labelled, but they're cheap as chips anyway (and fucking awful) so if you're not certain, stick it in the garden on the end of a long extension lead and see whether it goes bang spectacularly when you turn it on.
    Better still, sort out the actual voltage/current drain/termination of the unit and get a proper PSU for it. Switch-mode stuff is responsible for a hell of a lot of mains interference and it's an inherently nasty bit of work.
    I know that you believe you understand what you think I said, but I’m not sure you realise that what you heard is not what I meant.
    Thai wammer ob1's Avatar
     Jan 2007
     outside....Norwich,
     OB
     TW Raven AC3
     Phantom/transfig
     Soundsmith SG 410
     vertex alethia DAC1
     Marantz CD12
     Marantz DAC 12
     BlackSwan
     Soundsmith SG410
     MSB monoblocks
    Post imported post
    or wait until the 240V model come along in UK!
    John Peel said, "Life is full of surface noises." Obviously he never heard my rig!
     Jan 2007
     Engerland
     Adam
     MF M1 / Transfig
     Yamaha MCX1000
     Linn
     None!
    Post imported post
    OK folks, thanks for your comments. What make of step down do you recommend? The power output is 120v 0.53a 60hz 30w. I looked at this.
    http://www.amazon.co.uk/High-Quality...ref=pd_cp_ce_3
    845 SET's ROCK!!!
    Wammer mrwippy's Avatar
     Plymouth, UK
     Acoustic Signature
     SME, Rega, Roksan
     Sugden Masterclass
     NAD
     7 Pi Corner Horns
     Bottlehead
     Bottlehead
    Post imported post
    It would perhaps be worth trying to find out if the unit is earthed - many of these small low cost units aren't
    This supplier is often recommended.
    Squeezebox - Sounds like a 'girl thing'
    Still around, but mostly elsewhere
