i have refoamed four pairs of acoustic research speakers using different kits everytime and the speaker-repairs ones were by far the worst. very thin foam, shims were literally a5 paper chopped up into strips and the glue ! dont get me started on the glue - they give you pva to do the refoam ! if you manage to get them to stick they fall apart a few days later on bass heavy music.
one of the best was from a dutch chap called Maroesjka, his site is here :
http://www.goodhifi.com/ superb bloke that will answer any questions you might have - choice of rubber or foam surrounds, quick postage oh and the glue is proper contact adhesive.
good luck with the refoam, its easy just dont rush it !
