Results 1 to 3 of 3
    Wammer Stupinder's Avatar
     Feb 2008
     North Korea
     Kim Jong un
     Tabun
     Rondong-1
     Taepodong-1
     Musudan-1
    Integrated as Power amp
    I know, it's another daft question from over the channel.
    I have a valve integrated and a Solid state power amp. Down the line I thought it may be interesting to do as PaulF-2007 has done and use the valves to power the mids and highs of an active system and the SS to do bass duties.
    Is this right? - Source - Passive pre - active crossover - Valve integrated and SS amp - speakers.
    Thanks from numptyland
    If I can't use the integrated in this way then I may as well flog it I suppose.
    Super Wammer paulf-2007's Avatar
     Jun 2008
     souf east for work
     plays vinyl
     plays cd's
     2A3
     diy
    Yes Stu, that right. I have gone one stage further with a 3 way crossover. Pre amp to inputs and then 3 pairs of outputs, lows to 130w amp, mids to 300B amp and highs to 3.5w amp ( as the horns have a much higher efficiency ). May be able to loan you a 2 way dgital crossover when I finally get a 3 way that works.
    main system: 15" open baffle bass, 200Hz auto-tech tractrix horn with BMS 4592mid, Raal 140-15D , Rotel RB861, J Sound labs 300B, 6n6P, 6h8c, 5C4M set DEQX PDC, MHZS cd88, Garrard 401. Colarro 2010
     Feb 2008
     North Korea
     Kim Jong un
     Tabun
     Rondong-1
     Taepodong-1
     Musudan-1
    Cheers Paul. I may well take you up on that offer at some point in the future.
    Does it matter that the valve amp is integrated?
