Results 1 to 4 of 4
     Feb 2010
     Eastbourne
     alan
     various
     marantz
     various
     monitor audio
    volume control on yamaha receiver
    Just thought I'd post this as there might be a simple solution. I have a Yamaha remote controlled receiver (RX-V620RDS) - everything works fine manually and also with the remote except for one thing - the volume control which only operates with the remote. The volume control moves round when you turn it but has no effect on the volume. Obviously I can use the unit without any problems but it would be nice if the volume control could be operated manually as well. Could it be something very simple that I could fix myself? Thanks for any advice.
     Jan 2010
     manchester
     chris
     Change often
     Altec StoneHenge 1
    This may sound too simple but the knob might be loose on the spindle (if this is just a regular volume pot) try pulling the knob off (te hee hee) then turning it by hand. if it works when replacing the knob use a dab of silicone to secure it firmly.
    chris
     Feb 2010
     Eastbourne
     alan
     various
     marantz
     various
     monitor audio
    thanks for reply - unfortunately removing the knob and turning the spindle still doesn't result in being able to operate the volume control - maybe there's something like a little cord inside which has broken??
    Alan
    Registered
     Dec 2010
     Alan
    Yamaha Volume Problem
    I have exactly the same problem and the remote is getting worse.
    I have looked for a replacement remote but so far have only found ones that cost silly money (£100+) .
    Did you resolve this issue?
