Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21
    Founding Wammer Kiang's Avatar
     Leeds, , United King
    Post imported post
    considering what you are trying to achieve , perhaps using the bi-wire option might be the better tool. Keep this option open
    I assume ofcourse that you have eliminated all other possibilities for the problem eg: positioning, room interactions etc
    For the price van damme cables are excellent
    The van den hul will appear to do the job but after a while you may well realise that you lost a bit of imaging and soundstage in the bargain
    There is no substitute to trying various cables
    I find it difficult to guess how a cable might sound in your system - never heard the sound of those speakers
    Those foam rings (focus rings) that people were talking about a few days ago might be worth trying here - if they are as claimed. Well within DIY capability.
  2. #22
    Ursine Wammer technobear's Avatar
     Sep 2005
     Glastonbury, UK
     Audiolab 8200CDQ
     iFi Audio iCAN
     Beyerdynamic T1
     DSPeaker 8033S-II
     ESI uniK 08
    Post imported post
    I can report similar experiences with QED SA.
    Arcam/Mission - sounded great.
    Arcam/ATC/Castle - sounded great.
    ATC/Dynaudio - hmmmm. A little on the hard side. Perhaps I'll try some Van Damme
    Audiolab 8200CDQ, iFi Audio iCAN, Beyerdynamic T1, ESI uniK 08, DSPeaker 8033S-II, MJ Pro 50 mkII
  3. #23
    Super Moderator Duvet's Avatar
     sarf london
     Feather
     Avid Acutus
     SME V / Airtight PC1
     Whest PS30 R
     SB Touch
     Micromega Mydac
     Kharma Ce 2.3
     ModWright LS36.5
     Plinius SA103
    Post imported post
    I could do an ickyboy here and say check the classifieds there's some cheap van den hul going but i wont;)
    First pressings son !
  4. #24
     I'm in Pursuit -so stay out the way, , United Kingdom
    Post imported post
    I would give it a little while for your CD player to run in first as my CD33 was a little bright/harsh before it ran in. I have found ,however, Chord Odyssey (or if you don't want to spend as much use Rumour) works well and tends to be a reasonably safe bet. I thinkit generally matches most situations. The Arcam is very refined and delivers a very sweet sound in my opinion so I have found cables like Nordost can be a little overbearing in the treble and midrange stakes. Would also highly recommend the Krystal cables aswell. Not tried their speaker cable offerings but if the mains leads and interconnects are anything to go by, they'll be good.
    Enjoy your new stuff, I have had several items of Arcam's, all of which I have been pleased with. The Arcam FMJ CD player is a gem aswell IMHO.
    I would be interested to hear what you have been recommended speaker wise to use with your new kit as I am considering changing mine also!!
    Regards
    Jason.
  5. #25
    Super Wammer baltika_no_9's Avatar
     Sep 2005
     Hampshire, UK
     Rega P2
     RB250/Ortofon 2MBlue
     ProJect Phono Box RS
     ND5 XS/NAS
     Arcam
     EE M520
     B&W 805S
    Post imported post
    As I said earlier Paragon, the QED SA worked fine for years with my A85. It's just not right for the P1s. I will try as many of the suggested cables as I can lay my hands on!
    Cheers
    The world is filling up with entropy
  6. #26
     Edinburgh & Vancouver, , United Kingdom
     Bush
    Post imported post
    Probably because Arcam amps are a bit safe sounding.
  7. #27
     Sep 2005
     Glastonbury, UK
     Audiolab 8200CDQ
     iFi Audio iCAN
     Beyerdynamic T1
     DSPeaker 8033S-II
     ESI uniK 08
    Post imported post
    Which is another way of saying the competition are mostly bright and harsh ;)
  8. #28
     Sep 2005
     Hampshire, UK
     Rega P2
     ND5 XS/NAS
     Arcam
     EE M520
     B&W 805S
    Post imported post
    I think that particular piece of conventional wisdom is based on the earlier kit and really is too much of a generalisation to be applied to their current products.
  9. #29
     Sep 2005
     Hampshire, UK
     Rega P2
     ND5 XS/NAS
     Arcam
     EE M520
     B&W 805S
    Post imported post
    Regards
    Jason.
    I'm saving hard JH1! will let you know.......................Chris
