Results 1 to 3 of 3
    Wammer sentinel one's Avatar
     Dec 2010
     Andrew
     Lenco 75
     A C Magnum CD 2020
     Lumley M2 MK II
     Lumley PP70
     Lumley M120
    Problem with electrical feedback on valve phono stage? Any suggestions?
    I have recently purchased my first valve phono stage (second hand) which sounds absolutely great. However, at switch off the amp makes a thump – if I am not mistaken only on the left channel - there is some sort of electrical discharge that perhaps shouldn’t be there? The thump can be heard irrelevant of whether the volume has been turned up or down.
    What is this problem most likely to be and is this an easy problem to rectify?
    Thanks for any hints or relevant info. in advance. Much appreciated.
    Pac67
    It's quite common to get a "thump" at the speakers when powering down, and one school of thought is to always turn the amp's volume down and power the amp off before the source to avoid any possible damage to the speakers. Switch on is the opposite (ie switch the source on first, keep the amp volume low or zero, and then turn the amp on). If the phono stage sounds good and you have no problems with it during use, don't worry too much. This thump can be caused by the amps power supply capacitors discharging at switch off. Some people prefer the opposite route, ie power amp on first then source and vice versa. It depends largely on whether your amp has a soft start/stop function to prevent capacitor surge. DC offset issues with amps can also cause a thump which might point to an issue with the amp rather than the source.
    Team Coco FTW! i_should_coco's Avatar
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    Simple. Turn off the power amp first. Which is the correct thing to do anyway, because of things like this.
    In the endless battle between theory and reality, reality has yet to lose.
