Results 1 to 5 of 5
    Registered
     Nov 2011
     Rega RP1 w/ PP
    RCA Cable on Rega RP1
    Hi,
    As some of you may be aware the Rega RP1 has a built in RCA cable with is about 1m long. My problem is that i plan to buy an integrated amp which, due to my storage problem, is going to have to be about 2m away from the TT. Is there anyway of extending the this cable with a 3rd party RCA?
    Also i plan to run another cable from the "tape out" of the amp to a headphone amp. Anyone recommend any cables that are going to be a match for the stock RP1 cable.
    I hope thats clear?
    Cheers,
    Keith
    Super Wammer The Strat's Avatar
     Buckingham, , United
     Lindsay
     Roksan Xerxes 20+
     Artemiz/Dyn XX2
     Naim Superline
     Naim CDX2/XPS2
     Dyn Contour 1.8
     Naim 282/hi-cap
     Naim 250-2
    There are those who have their Rega arms re-wired and might be able to advise as to the sonic benefit but I would have thought that quality the standard offering from Rega is fine. If you simply need a longer length I would simply ask a Rega dealer if they could arrange it for you. For your headphone amp unless you are looking to really refine a higher end system a standard offering by Chord or QED would be fine, but the guys on here also recommend the Hitachi stuff which is widely available I understand.
    Strat
     Oct 2010
    I can see that you have RP1, most likely with RB200 arm, perhaps not a very good candidate for an upgrade. I would probably leave the cables as they are and extend them with phono female to female atapters.
    You could always upgrade your kit once you outgrow your RP1.
    I have my RB250 rewired and foam filled by audio origami. There are also a number of rega arm self-install rewiring kits available, google it.
    As far as the sonic improvement, well, that is a very personal experience. Some people hear it, some don't. I am very happy with my rewired rega arm.
    Banned
     May 2011
     Warrington, Cheshire
     Andrew Davies
    Extending tone arm cables with phono plug-socket extension leads might lead to hum pickup problems and sometimes high frequency loss. If your new amp does not have an actual phono stage built in you might try a separate stand alone phono stage(Project stages are excellent value)and place this next to your deck and run a 2m lead from this into an auxilliary socket. This will not cause any hum problem and might sound better.
    Super Wammer SergeAuckland's Avatar
     May 2008
     Bury St Edmunds, UK
     Serge
     EMT948, TRS9000, 401
     AT33ML, TSD15, MC-10
     SBT
     Meridian 206
     DEQ & CDQ
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Quote Originally Posted by DougBradyHiFi View Post
    Whilst the above is sensible advice, in practice, it's only another metre so is unlikely to be a problem. Use decent low capacitance cable (like RG6 or RG59) and the extra 60pF of capacitance won't have much effect, even with a MM cartridge, and none at all with a MC.
    S.
