Results 1 to 5 of 5
    loving this site Millennium's Avatar
     Jan 2012
     West London UK
     None
     None
     None
     PC USB
     Micromega MyDAC
     Denon AVC-A10se
     Triangle Comete EX +
    Cheap DAC PC to Valve Amp (output stage) - thoughts? D3?
    Hi There
    I am thinking of pulling the trigger on this dac, the FiiO D3. My current setup is Asus DX/XD > (Optical) > Yamaha DSP A5 > (RCA from Main level output) > Harmon Kardon A500 Integrated valve amp (Tape Mon inputs, or some other line level inputs).
    I used to use a soundcard headphone level output to my A500's phono input stage (sacriledge I know) which did work fine and sound good but having just taken the A500 out of storage the preamp stage sounds crummy, and replacement valves aren't cheap.
    What I am trying to avoid is having to have the Yamaha on just to listen to stereo music via the PC and the valve amp, as the Yamaha is currently my DAC. The D3 looks like it would take care of this problem handily, and all for around £25.
    Now I am not expecting the same kind of performance you would see from a proper £300>£1000 standalone DAC, I'm just looking for something acceptably good that would compare to a high(ish) end home cinema DAC or a top end sound card DAC. My valve amp is pretty old and even the output stage would colour the sound no doubt so perfect replication is not really the issue. Just something nice and "listenable".
    Couple of questions
    1) Is this DAC a complete waste of money? Something better second hand? Keep using my amp?
    2) There are some reports that the level output of this dac is quite high. Would this potentially pose a problem for my valve amp? Any way around this?
    3) Alternatives are welcome.
    Many thanks you nice folks....
     Jan 2012
     West London UK
     None
     None
     None
     PC USB
     Micromega MyDAC
     Denon AVC-A10se
    No thoughts on the FiiO D3 folks? I have been reading around a bit more and reviews are mixed but generally positive. I'm just wondering if I have missed a trick here on a good second hand Dac to look out for or similar... hmm
    Cock with Aspergers ncdrawl's Avatar
     Dec 2008
     Southport, NC USA
     Teddy Ray
     Rebuilt LAB 500
     SHURE M3D
     Custom Built Valve
     Forssell MDAC-2
     MasterSound/Bryston
     K&H 0300D
     In my DAC
     In my Speakers.
    Id definitely go for the Fiio. Things have come a long way since your yammy's day..and even at a low price, id expect that it sounds good. even the cheapest of the cheap units has plenty of capability these days because tech is so advanced.
    go for it. id expect that it would be a good improvement!
    Be just and if you can't be just, be arbitrary- William S. Burroughs
     Jan 2012
     West London UK
     None
     None
     None
     PC USB
     Micromega MyDAC
     Denon AVC-A10se
    Hi there,
    Thanks for the reply
    I am thinking of upping my budget a bit and maybe going for a dacmagic or dacmagic 2 from Cambridge Audio. They seem to sometimes go for under £100 on fleabay.. sometimes quite a bit less!
    Would this be worthwhile do you reckon? I know there is one here for sale with a PSU upgrade but the price is a little high for me perhaps...
     Dec 2008
     Southport, NC USA
     Teddy Ray
     Rebuilt LAB 500
     SHURE M3D
     Custom Built Valve
     Forssell MDAC-2
     MasterSound/Bryston
     K&H 0300D
     In my DAC
     In my Speakers.
    the DAC Magic is certainly a fantastic piece of kit. So yeah, if you have the budget for it...and you know then that the DAC wont be a limiting factor at all.
