Audio Emotion  The Hifi Show Epiphany Acoustics
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Wammer supertramp's Avatar
     Jul 2007
     guess by my accent, , United Kingdom
    Peter William Belt
    Om.
    Spock will form the ultimate coalition...
    Super Dooper Wammer Nagraboy's Avatar
     Sep 2014
     Leics
     Greg
    No, but never underestimate the power of the Foos.
    Cock with Aspergers ncdrawl's Avatar
     Dec 2008
     Southport, NC USA
     Teddy Ray
     Rebuilt LAB 500
     SHURE M3D
     Custom Built Valve
     Forssell MDAC-2
     MasterSound/Bryston
     K&H 0300D
     In my DAC
     In my Speakers.
    Headphones
    no.
    im a cock.
    Be just and if you can't be just, be arbitrary- William S. Burroughs
    Depression Vortex kernow's Avatar
     Dec 2009
     Devon
     Shaun
     Gyro SE
     SME IV / Phoenix
     Audio South / P10
     Quad 99 CDP2
     Airport Express
     EAR Yoshino 8L6
     Tannoy Turnberry HE
    If you're reading a thread I've created it's probably to do with something breaking or not going to plan again.
    WYLD STALLYNS JPG's Avatar
     Jan 2007
     Bristol
     JVC QL-Y5F
     AT95E
     Technics SL-PG590
     Behringer UCA-202
     Leak Delta 30
     KEF Celeste IV
    Be excellent to each other. And... PARTY ON, DUDES!
     Wirral, England
     Raspberry Pi-2
     HiFiBerry dacplus
     Amphion 520
     Passive
     BK class D
    Headphones
    A little song by 'Napoleon XIV' sums it all up.
    Pac67
    No...but I once had great success whilst trout fishing changing the fly from a Pheasant Tail Nymph to an Olive Dun...
    Admin hifiwigwam's Avatar
     Sussex, West Side.
     Acoustic Solid 111
     Audio Note / Benz
     Puresound T10/P10
     Leema - Antilla
     SONOS connect
     Leema Elements
     Triangle Delta Sig'
     Modwright SWL 9.0SE
     Advantage S100
    Headphones
     Bowers & Wilkins P7
    Quote Originally Posted by supertramp View Post
    Has anyone here felt confused at first by PWB tuning tweaks only to find themselves using them successfully after trying them out (e.g drinking polarised water/which has been exposed to a strong magnetic field)?
    Why on earth would anyone "try them out?" unless they were stark staring mad.
    Wammer griffy's Avatar
     Dec 2008
     St Ives, Cambs
     Dave
     Rega Planar 3
     RB300 Ortofon 2MBlue
     Pro-Ject Phonobox II
     Naim ND5 XS
     SBT + sexy psu
     Jolida FX DAC III
     Mini-T/Sugden A48II
     Focal, Goodmans.
     Densen B200
     PS Audio Trio
    Headphones
    Also experiment by applying the same freezing/slow defrost process to such as batteries. Again have identical batteries. For experimental purposes the batteries used in remote controls are an ideal battery to use. If the remote control takes two batteries, then you require four identical batteries - two to be put through the freezing/slow defrost process, and the other two to be left as the control ones (non treated). After freezing two batteries, insert them into the remote control and listen to some music for a short time. Then replace the (treated) batteries with the untreated batteries and see if you can listen to the same music with the same pleasure as before !!
    Now that, is mental!
    Nothing in fine print is ever good news
    Moderator meninblack's Avatar
     Erehwon
     Mr Pink-and-Yellow
     Palmer 3.0
     AN Arm 3/ Io Gold
     Kondo KSL-SFz
     dCS P8i
     SB3
     AN DAC 2.1x/II Bal.
     Tannoy Kensington SE
     Audio Note M5 Phono
     Air Tight ATM-1
    Headphones
    LOL - Belt's "tweaks" combine the power of suggestion with the fact that many audiophiles seem to suffer from OCD.
    He has this in common with the rest of the tweak industry. In reality it's no more stupid to assume you will get better sound from a paperclip on the curtains than from an "upgraded" USB cable, but most people will easily fall for the psuedo-sciency marketing bollocks spun around the USB cable. Because they're idiots.
    To truly "hear" Belt's tweaks you have to be a special kind of idiot.
    keirik
    I stopped reading the hifi press (HiFi Answers mostly) in the 80's when Alvin Gold and Jimmy Hughes ( in those days using his full name of James Michael Hughes) were extolling the benefits of pinning up curtains and putting slips of paper between pages of books
    If you believe any of this I have a pure pass through pre-amp I can sell you.
    Its a box without connecters that you pass your interconnects through
    You can build your own for 0p out of a shoe box, or I can build you one for £5000 oer interconnect
    Subsequently Unresponsive loosend's Avatar
     Jun 2010
     Devon
     Dan
     Modded Mac Mini
     Modded Windows PC
     Astintrew/FA DAC-150
     Rowland/MF/TQ
     Ayon/Infinity/Frugel
    Pete, PWB is a beaut ain't he lol! What a tosser, a guy my brother new years back used to do all the tweaks, crepe paper under half filled vases, bits of kit kat wrappers in the middle of doors and windows etc, he even went so far as to turn around his speakers so they were facing the front corners of the room.
    Course my brother being the way he is told this guy there is a due to be published tweak that if u reverse hang ur curtains the denser lining of the curtains absorbs first reflections better, low and behold on his next visit dopey had done it! 'ah yeah, I can see what he means, I can hear the difference!'
    Fair doos tho in one respect to PWB, if people wanna believe his nonsense then let them, he ain't gunna say no to the money is he
    Too much time on my hands SergeAuckland's Avatar
     May 2008
     Bury St Edmunds, UK
     Serge
     EMT948, TRS9000, 401
     TSD15, Spirit,AT33ML
     AT630, Hafler
     SBT
     Meridian 206
     DEQ & DCX
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Headphones
     AKG K270 KOSS Pro4AA
    I still have the PWB brush given away by a magazine in 198X. Works really well for removing dust from small buttons...now what was it supposed to do?
    S.
     Jan 2007
     Bristol
     JVC QL-Y5F
     AT95E
     Technics SL-PG590
     Behringer UCA-202
     Leak Delta 30
     KEF Celeste IV
    Quote Originally Posted by SergeAuckland View Post
    S.
    Surely it's to remove your belly button fluff before listening - it will obviously make the sound clearer. I know "removing a veil" is a tired cliche, but it really does work.
     May 2008
     Bury St Edmunds, UK
     Serge
     AT630, Hafler
     SBT
     Meridian 206
     DEQ & DCX
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Headphones
    Ah right! Button..belly button...makes sense. I recall some guff about wiping the brush over the loudspeaker cones, and that would energise them with organic energy or somesuch. Cleaning out one's belly-button make so much more sense.
    S.
    Super Wammer misterpete's Avatar
     Jul 2007
     N Yorks
     Have a guess!
     Michell Orbe
     SME IV/Lyra Titan
     Zesto Andros PS1
     CA Stream magic 6
     Jolida Fusion
     Jolida Fusion DAC
     Audio Physics Avanti
     Tom Evans Vibe/Pulse
     Edge G8+ monos
    Headphones
     LCD3s
    I used to like those little black pieces of sticky paper that you had to stick on records, turntable arms, cartridge headshells, in fact everywhere! It was great fun and whiled away many a rainy night. Of course you knew it was never going to work, but you had to try it, just in case it did!
    So much music, so little time.....aren't valves brilliant!
     Jul 2007
    Om.
    Cogito, ergo doleo. rabski's Avatar
     Dec 2006
     Eat Mudlands
     Well Tempered
     WT / Dynavector XX2
     Kairsound SUT
     Marantz transport
     Squeezebox
     Audiosector NOS
     In the workshop
     Living Voice IBX R2
     Gordon Welford
     845 SE madness
    Headphones
     Nah
    The lines start to blur when we discover that something we all though was insane actually has some truth to it.
    If you'd said a few years ago that moving your curtains could make a difference then the foo-fighters would have crucified you. But we now know, through room measurement, that there is a substantial difference between a big expanse of glass and a big expanse of glass with curtains in front of it.
    Mind you, Peter Belt is still a cock.
    I know that you believe you understand what you think I said, but Iím not sure you realise that what you heard is not what I meant.
  19. #19
     May 2008
     Bury St Edmunds, UK
     Serge
     AT630, Hafler
     SBT
     Meridian 206
     DEQ & DCX
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Headphones
    Quote Originally Posted by rabski View Post
    I've been passing my evenings in the last week re-reading my Wireless Worlds from the 1970s. There was a lot of mention of room acoustics, the effects of soft furnishings and curtains even then.
    S.
  20. #20
    Wammer turning japanese's Avatar
     Jun 2006
     Equatorial New Stoke
     Dan Tracey
     Denon DP80
     Fr64. Spu
     Allnic 1500
     Teac p30
     Dax decade
     Jbl k2 s9800
     Concordant excelsior
     croftish
    Headphones
    when I got married we came back to the house after the church bit and had an hour or so to kill before the wedding breakfast. We decided to chill out listening to a few tunes, about one side of the record was over I flipped the disc whist my wife got changed into her normal clothes, we then sat down for the second half of the album without the benefit of all the wedding garb absorbing the sound - we were both convinced that the improvements were huge - it was like removing a veil
    The wrong kind of idiot
