I'm toying with the idea of using an Antimode dsp device on my bass feed. This would have to go between the CDP and the inputs to the power amps in the bass speakers ie most (fixed) attenuation would be done on the power amp inputs and take place after the Antimode device, so the Antimode would have to be able to accept whatever the CDP was sending. Nominal output of the CDP is 2V and the Antimode is quoted as having a 1.65V input sensitivity (which I take to be maximum input signal) for single ended and 1.35V for balanced. Am I right in assuming this would not be a problem because:
- 1.65V/1.35V are only about 1.7dB/3.4dB down on 2V (if I've done my sums right!)
- An average music signal will very rarely, if ever, reach the nominal 2V output and even peaks are probably recorded to leave a little headroom
- I would normally be applying a slight (variable) volume reduction via the CDP 's variable output to compensate for differences in the recording level on different CDs
