Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41
    Moderator gjm's Avatar
     Jul 2007
     NZ & loving it!
     Graham
     Transrotor-based DIY
     PC / Danish DAC
     SAS B11a / 2A3 Monos
     Impulse/Aspara horns
    I think I have everything I need. It's just a matter of getting everything in the right place, and in the right order!
    There are some wonderful words on the paperwork supplied with the cartridge:
    "You are allowed to remove briefly the stylus guard and gloat over your jewel-like new acquisition. We respectfully suggest you do this while the cartridge is still secured to its box. [I forgot to mention the stunning, gorgeous, perfectly made polished wooden box the cartidge s shipped in.] When you feel temporarily adequately fulfilled, kindly refit the guard very carefully, leave it in place until further notice, and follow these instructions implcitly."
    Oh. That's OK then. At least I don't have to ask permission!
    The best hifi show in the UK today - http://www.thehifishow.com/
  2. #42
    Wammer vacdac's Avatar
     Jul 2011
     Gyro SE Oyaide MJ-12
     Jelco 750 AT33EV/OC9
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. x-can v8 AKG272
     X.T.Z. 99.36piano ii
     M.F. A1 fbp
     XTZ AP100
    Classy Bodge Graham Ahem wot I really meant was superbly executed & well thought through modification Sir...Well done!!
    Result fella....I do seem to remember a reviewer quoting that blurb you mentioned....t.b.h. once read it's not something you would instantly forget is it...perhaps in Hi-fi World some time back or somewhere on the t'internet perhaps
    Chris oooooooot
    Quote Originally Posted by gjm View Post
    Good news! The cartridge is now hanging from under the tonearm. I mounted the bolts in a craft drill, and while they were spinning took a file to the threads under the head. This seems to have done the job very nicely - the bolt still has to be threaded through the headshell, but now has forward and back movement once it is fully inserted.
    Now all I have to do is try to recall how to align the cartridge...
    Gyro, Jelly750d, AT33EV/OC9,Rondo, carts. Icon audio p.s.1.2 phono, C.A. Stream Magic 6, TEAC cd, Musical fidelity m1 d.a.c.(netgear readynas duo/acer timeline X lappy. Alva Nanoface) M.F. A1fbp pre XTZ ap100power,XTZ99.36 speakers,x-can v8 & x10v3, AKG 272hd
  3. #43
     Jul 2007
     NZ & loving it!
     Graham
     PC / Danish DAC
    We can just about wrap this one up now. Just about...
    The cartridge is fitted to the arm correctly, and beautifully aligned courtesy of a most eminent member of this forum.
    We did experience a problem with arm height... The Tabriz Zi has a dangle counterweight which was fouling on the head of one of the dome bolts used to secure the arm. We've got around this by <ahem> using a 2-bolt fixing, but I'll look into some spacers to go between the headshell and cartridge which will hopefully mean the arm can be raised a few mm. I had some carbon fibre isolators somewhere so I'd best start looking. Of course, this means the alignment process will be revisited - let's hope I was paying attention! - and perhaps I'll be needing longer bolts, which will also need to be modified...
    Regardless, it sounds superb and I am very happy.
  4. #44
    Team Coco FTW! i_should_coco's Avatar
     Sep 2006
     Coco-san
     Voyd Reference
     WB / Strain gauge
     DIY
     Laptop / JRiver
     Nadja
     4-way active horns
     Nadja DSP
     Several
    Or use countersunk bolts on the arm plate.
    it was sounding rather lovely (at least once the speed was adjusted, lol). Interesting deck!
    In the endless battle between theory and reality, reality has yet to lose.
  5. #45
     Jul 2007
     NZ & loving it!
     Graham
     PC / Danish DAC
    For those that haven't seen it, here it is in all it's glory.
    The speed issue was a bit bizarre. Power is supplied to the TT motor by an Origin Live PSU, something I know has divided opinions on here. Playing some old standards - OK, Blue Raincoat - it sounded fine. Swapping to a 45rpm copy of Rumours, and it was obviously too slow... Hmm. And so was another 33rpm record.
    Anyway, score one for Origin Live because the pots on the back of the PSU are easily accessible and normal service was quickly resumed.
  6. #46
    Registered
     Feb 2012
     Sheffield
     Voyd Valdi
     Sony X303ES
     Gold Baile S8 300B
     M.Short Classic 40
    I had a similar problem when fitting a London Gold/Deccapod to an RB300. The Deccapod takes 6BA screws which were a little tight into the headshell, so careful filing of the threads with a jeweler's file eased the problem. 6BA tend to be 102-106 thou, 2.5 mm 95-100 thou.
  7. #47
    Down And Out mighty ant's Avatar
     Oct 2006
     London, England
     Anthony
     turns
     spins
     hot
     electrify
    Have you tried Westfield Fasteners (http://www.westfieldfasteners.co.uk) for screws/nut/bolts. You can order just one or two if you want rather than the 10 million bag full from that orange coloured diy store?
    "He who increases knowledge increases sorrow" Live in ignorance and be happy.
  8. #48
    Super Wammer paulf-2007's Avatar
     Jun 2008
     souf east for work
     plays vinyl
     plays cd's
     2A3
     diy
    looking good graham
    main system: 15" open baffle bass, 200Hz auto-tech tractrix horn with BMS 4592mid, Raal 140-15D , Rotel RB861, J Sound labs 300B, 6n6P, 6h8c, 5C4M set DEQX PDC, MHZS cd88, Garrard 401. Colarro 2010
