Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21
    Super Imposter hearingisbelieving's Avatar
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
     T+A Spectrum ADL III
    Lol Chris how do you get a goat from my avator? The actual pic is the album cover from Oceansize's Self Preserved While The Bodies Float Up album. To my mind it is a drawing of a headless female bust.
    CDP T+A Pulsar 1240R, DAC Chord DAC64 MkII, Amp Audio Note Oto Se, Speakers T+A Spectrum ADL III (modded), Headphone Amp Creek OBH21SE (modded), Cans Grado RS2, DVD Arcam DV135 + DV88-Plus Stands: Partington Heavi MkI, Soundstyle ST100
  2. #22
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Ordered a quad matched set of Sovtek EL84M/6BQ5 Military Spec from HotRoxUK yesterday. Selected budget delivery option but it appears they have been delivered today. Cant wait to get home, put them in and make sure that they solve this problem I have been having. Fingers crossed!
  3. #23
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Well thats fucked it! Got home all excited about getting my amp working again. Put all the new valves in and....
    Nothings fucking changed!!!!
    Same very worrying noise being emmitted from the speakers as the valves start to warm up....
    So what is the likelihood that it is one of the 3 remaining ECC83 valves that i havent changed yet. They are all Full Music 12AX7's and look bloody expensive to replace like for like so maybe I should get some cheap ones to see if they are the problem? Or maybe I should just take it to a reputable service tech - anyone know anyone in the West Midlands?
  4. #24
    Super Wammer robin's Avatar
     Dec 2006
     City of Bradford,
     robin
     bow wizard
     moon equinox
     chord 64mk2
     cary cad 300bsei
     tannoy 15" golds
     VDH-array a1
     radford sta 15
    chris, when i blew my leak 20 up putting a cap in the wrong way round it was two of the 3 ecc83s that were damaged, so could be worth buying some cheap ones off ebay to make sure
    django pre leak st 20 kora mandalas. with modded crossovers,
  5. #25
    Super Wammer Valvebloke's Avatar
     Dec 2009
     Central southern UK
     Rega Planar 2
     Quad 99 CDP-2
     Hmm where to start ?
     ESL57s, JR149s ...
    I don't think we have enough information to guess what the fault is I'm afraid. When you were looking at the output valves earlier you thought that the fault had followed a valve from one channel to the other. If you can be sure about that, i.e. that both channels have, at one time or another, exhibited this fault then it has to be something which is common to both channels (say the power supply ?) or it has to be something which you moved from one channel to the other (one or more EL84s, assuming you changed nothing else). It's now looking like the root cause is not the EL84s though. I guess the ECC83s are not common to both channels either so unless the same fault has appeared simultaneously in two of them then the root cause will be somewhere else. The '83s may or may not be damaged, as Robin's were, but that's not the root cause and it's that that you have to track down. It sounds like it's time to get a tech involved. He'll have access to the kit needed to isolate the fault which will be tough, and potentially expensive in unnecessary spares, if you try to do it from scratch.
    VB
  6. #26
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    thanks Robin and VB. Looks like its time to get a tech involved. If anyone knows a reputable one in west midlands please let me know.
  7. #27
     Dec 2006
     City of Bradford,
     robin
     bow wizard
     moon equinox
     chord 64mk2
     cary cad 300bsei
     tannoy 15" golds
     VDH-array a1
     radford sta 15
    pm bigdur he will put you right
  8. #28
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Quote Originally Posted by robin View Post
    already been in touch with Jack as I bought the amp from him. He is very busy with his Ming Da stuff at the mo and life in general so dont want to bother him too much. I have used good ol google and found a company/tech that looks very good and is very local:
    http://www.amplabs.co.uk/
    his profile and testimonials certainly are encouraging so will give him a buzz tomorrow and see what he can offer.
    thanks
  9. #29
    Wammer Toe rag's Avatar
     Apr 2009
     Paignton, , United Kingdom
     Linkserver+mini mac
     Accuphase DP57
     J wood audio special
     TanS10/Elipse activ
    Quote Originally Posted by SMEagol View Post
    what is you avatar Chris? I find it rather disturbing - and thats coming from me!, is it half goat / half woman?
    Funny enough I thought that aswell
    Also I always thought that one should never have the speakers disconnected when turning on a valve amp
  10. #30
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Not disputing that Chris but why have a "pre-amp out" output if that is the case? I used the Oto as a Pre to my active speakers for several hours and it didnt seem to do it any harm(at the time that is...). Do other valve integrateds have pre-outs and if so what are you supposed to do if you want to use that function???
  11. #31
    Rubberoid i_should_coco's Avatar
     Sep 2006
     Coco-san
     Voyd Reference
     HR100S/Strain gauge
     DIY
     Laptop/JRiver
     Nadja
     4.1-way active horns
     Nadja DSP
     Lots
    It depends on the amp. But with any amp a dummy load it's a good idea if not using speakers
    Everything rattles, you just need to shake it hard enough.
  12. #32
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Quote Originally Posted by i_should_coco View Post
    not being funny but you would think they would mention that in the manual.
    Especially if they already go to the length of listing what the volume control does
    When you say dummy load do you mean using some resistors? if so what value and rating would they have to be?
  13. #33
     Sep 2006
     Coco-san
     Voyd Reference
     HR100S/Strain gauge
     DIY
     Laptop/JRiver
     Nadja
     Nadja DSP
     Lots
    As I said, it may not be a problem, depending on the topology. It's more of an issue with pentode our ultra-linear amps as the high impedance of the tube means you can get some very high voltages in the output transformer primary, causing it to be damaged. Triodes have a lower internal impedance, so it's less of an issue.
    As a note, such damage is really only likely if you actually try and play music through it.
    Ideally use 8 Ohms or so. Up to 20/30 ohms should be fine, it's not critical and 20W should be adequate as a rating.
    As I said, it may but be necessary, but the dummy load won't hurt and better safe than sorry.
  14. #34
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    There's the rub - I was playing music through it when I had my actives connected to the pre-out...
    Luckily I have found a competent tech so hopefully he will be able to get to the bottom of this and it wont be too expensive!
  15. #35
     Sep 2006
     Coco-san
     Voyd Reference
     HR100S/Strain gauge
     DIY
     Laptop/JRiver
     Nadja
     Nadja DSP
     Lots
    I'm pretty sure it will be fine. If the output transformer was fried, you wouldn't get noises, you'd get silence!
  16. #36
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Wow thats a relief to know as I believe they are the most expensive component in a valve amp - especially AN! Will report back when the tech has inspected the damage...
  17. #37
     May 2011
     Clows Top
     Chord DAC64 MkII
     T+A Pulsar 1240R
     Chord DAC64 MkII
     Auido Note Oto Se
    Just been informed by email that the Oto is now mended and ready for collection. Picking it up tomorrow night so will report back soon. It took a while for the guy to repair it but for a fixed fee of £90 you cant really complain! As well as the repair he also carried out a couple of small mods i had requested, and a couple he thought might be a good idea for no extra charge.
    Cant wait to hear it sing with the new valves as well!
  18. #38
    hup two three four wammer
     still old and black
     yup
     Yes indeed
     Runs Windows 7/64
     AN 4.1x sig
     AN-E
     Vibe/Pulse
     Tron
    Ignore my post
  19. #39
    Super Wammer adsa's Avatar
     Jan 2007
     Engerland
     Adam
     MF M1 / Transfig
     Yamaha MCX1000
     Linn
     None!
    What was up with it then?
    845 SET's ROCK!!!
  20. #40
     still old and black
     yup
     Yes indeed
     Runs Windows 7/64
     AN 4.1x sig
     AN-E
     Vibe/Pulse
     Tron
    For some inexplicable reason I only got 1st page of the thread. I thought that was all of it and offered some sterling advice about 6N14P valves, then when I clicked the reply button the post came up three pages later. I didn't have time to read them all and it seemed best to remove the post, and I was amazingly enough (probably) right. Not v. exciting
