Audio Emotion
Page 8 of 8 FirstFirst ... 678
Results 141 to 158 of 158
Thread: Spur
  1. #141
    Cogito, ergo doleo. rabski's Avatar
     Dec 2006
     G. Rumpty Git
     Well (bad) Tempered
     Dynavector XX2
     Kairsound SUT
     Pioneer wooah
     Netbook/HiFace
     Audiosector NOS/FiiO
     Leak + mayhem
     Living Voice IBX R2
     Gordon Welford
     845 SET / KT88 PP
    Headphones
     No bloody way
    Quote Originally Posted by earlofsodbury View Post
    Of all the subjects raised around hifi, only cables are surrounded by more mythology and misunderstanding than mains power.
    A big part of the reason for this is there are so many variables...
    A common misunderstanding lies in what constitutes mains perturbances:
    For a start, no-one seems to know for sure what UK domestic voltage should actually be thanks to deliberate obfuscation by power suppliers. Nominally we're Euro-harmonised at 230VAC @50Hz, but that voltage figure is +10% / -6% allowing them to go right on generating at the 240VAC they always have. This can and does fluctuate considerably, although the core frequency is remarkably stable.
    Nonetheless, due to local and regional demand, inclement weather, grid switching, faults etc. you may experience undervoltages ("sag" or "brown-out" - lights dim/flicker) or overvoltages ("surge" - lights brighten, sensitive electronics keel-over or experience reduced service life), either can be transient (uS, mS) or sustained (S).
    From generation to your fuse box the supply cabling is picking-up waveform distortions throughout the frequency range.
    Some of this is just passive pickup of high-frequency noise, both conducted and radiated, some of it is much lower frequency, usually due to badly designed or unsuppressed electrical installations in homes, factories, shops etc. On top of this is growing use of power lines for data and even voice signal transmission, which started with the power companies using the lines to control their own equipment remotely and has grown to include anything from encrypted data to in-home baby monitors.
    Mains pollution doesn't stop at the fuse box though. The commonest complaint is of pops, clicks and data-lock losses due to thermostats, rheostats and unsuppressed switching within the household.
    An increasing if less immediately obvious problem are switchmode power supplies - chiefly wall warts and the internal PSUs in many smaller digital devices. SMPS tend to produce switching noise at high frequencies, this can be suppressed, or more commonly the SMPS is designed to produce its noise at frequencies outside the operating range of the device it's intended to power... Fine for that device, but potentially bad news for your hifi.
    There are countless sources of hi frequency noise, but lower frequency interference can manifest strongly too.
    The commonest is so-called DC offset, which is a severe AC waveform clipping caused by asymmetrically switching devices like certain crude thermostats and some devices utilising thyristors. The effective DC voltage is low, usually mVDC range, but this is plenty enough to saturate marginally specified transformers, especially toroidal ones, causing mechanical noise and a great reduction in efficiency.
    The most often overlooked source of mains perturbance is your own hifi. Rabski touches on this, but it's doubly significant because it is right at the heart of your system. Digital kit can produce a lot of out-of-band interference, both radiated and conducted, while so-called digital amps (usually varieties of switchmode) may produce extremely low output distortion yet feedback masses of noise via their PSU, and of course, SMPS are ever more common for all kinds of non-amp functions, especially with the rise to dominance of computer audio.
    With all of this being well-known and universal, it is most definitely odd that so few manufacturers take steps to protect their kit with built-in filtration, indeed aside from manufacturers of digital amps who are compelled to, the only one I know who really do things properly are Bryston, who build-in common-mode, differential and DC fliters into their amps. Seems it takes a pro audio company to do it right - which is amusing when some pro-oriented hifi pundits rubbish the need for mains filters at-all!
    Still, there are filters and filters - indeed I had to design my own to overcome the issues - but the fact is many act as a bottleneck. They may prevent ingress of external noise, true, but they also actually couple self-generated noise in a system more efficiently by providing too high an impedence at various points. The BT isolation transformers mentioned earlier are good example (hence why they're sold-off so cheaply...), and in common with all isolation transformers have their own problems, as they very readily saturate if any DC offset is present - vibrating and buzzing like a bastard and strangling system dynamics. Most are in any case underspecified to cope well with dynamic transients.
    Mains is a minefield, and spurs just one trip hazard along the way, but they really are only useful if you don't have enough sockets or the rest of your house-wiring is an obsolete, high-impedence rats' nest.
    churz, sod
    Erudite, detailed and accurate.
    However, it misses slightly my basic point.
    If we are spending massively over the odds (and we are) on 'serious' hi-fi products, why the fuck are we putting up with design and build that is incapable of dealing with mains-borne interference and voltage shifts that are inherent in virtually every mains supply in the land?
    If I can buy an amp for £100 to run my guitar through for gigging, and it shoves out a decent 500Wrms and suffers NO effects from mains interference, then why should I accept that a £5000 hi-fi power amp should need me to spend a further couple of thousand pounds on power conditioning in order to be usable in normal domestic situations.
    No fucking wonder the domestic audio market is in such a mess. 'Fitness for purpose' comes to mind...
    I know that you believe you understand what you think I said, but Iím not sure you realise that what you heard is not what I meant.
  2. #142
     Jan 2010
     Horley, Surrey, UK
     Roksan Xerxes 20+
     N/A
     All valve
     Pretty damn good!
    Quote Originally Posted by rabski View Post
    Fascinating question.
    About 2 or 3 times a week I go to gigs in either Brighton or London.
    The bands use regular B&Q type extension leads to power their kit.
    If they're from the good ole US of A they have cheap looking voltage transformers.
    The sound is full, powerful and real.
    They play into amps and on stage 'speakers which are then miked into the PA.
    How come this sounds so exciting? It's not just the volume---although that helps. There's an immediacy and naturalness which the Hi Fi can't reproduce.
    Gigs aren't Hi Fi. There's loads of things wrong. The vocals are often indistinct, drums aren't usually miked properly, bass guitar is sometimes over amplified.
    But there's a freshness which I've spent years trying to achieve at home.
    Ho hum!
    Guy
    Know what's important, go for it, and value it when you get it.
  3. #143
    Too much time on my hands SergeAuckland's Avatar
     May 2008
     Bury St Edmunds, UK
     Serge
     EMT948, TRS9000, BD1
     TSD15, Spirit,V15VSa
     AT630, Hafler
     SBT
     Meridian 206
     DEQ & DCX
     Active B&W 801F
     Meridian 501
     3 x Behringer A500
    Headphones
     AKG K270 KOSS Pro4AA
    The same thing can be levelled at DACs...why should we pay hundreds or thousands even for a DAC that doesn't buffer, reclock and/or filter properly. Why should we spend hundred or thousands on amplifiers with high output impedance and high distortion. We should we spend hundreds or thousands on loudspeakers with a frequency response that looks like the cross-section of the alps?
    Why have we got ourselves into this situation where we pay premium prices for technically inferior product?
    S.
  4. #144
     Dec 2006
     G. Rumpty Git
     Well (bad) Tempered
     Dynavector XX2
     Kairsound SUT
     Pioneer wooah
     Netbook/HiFace
     Leak + mayhem
     Living Voice IBX R2
     Gordon Welford
     845 SET / KT88 PP
    Headphones
     No bloody way
    With all respect Guy, point + missed.
    Miking up and mixing a live gig is a bloody nightmare. My point only refers to the ability of very cheap and average PA and gig amps to be totally unaffected by mains interference.
    I play bass and keyboards. Both to a level of perfection that would stun you, though only through their total lack of virtuosity.
    My 'normal' amps are a Laney and a Peavey, with a combination of home-brew speaker stacks and assorted effects shit. The entire lot put together cost me less than £1000. The Peavey is my normal bass amp. It cost £250 and can manage about 750Wrms of low-frequency grunt. More to the point, I plug it into a common supply with a load of lighting effects stuff and assorted other mayhem, and I NEVER get pops, clicks or any other nasties.
    Why? Because it has a power supply that's designed to deal with that sort of shit.
    My point again. If a £250 amp can be designed to reject mains-borne interference, why can't a £5000 one?
  5. #145
    Super Wammer alexh's Avatar
     Feb 2009
     Hereford, , United K
     Alex
     Aune CD2 Pro
     DDDAC 16 Stack
     ATC SCA2 Pre amp
     ATC SCM50ASL
    When I build anything, I will select a good quality IEC filter socket by Schurter or Belling Lee etc. Even a 2 pole one is around £30 - 40-00. But rarely seen in Hi end stuff
    If you can`t buy it, Build it.
  6. #146
     Dec 2006
     G. Rumpty Git
     Well (bad) Tempered
     Dynavector XX2
     Kairsound SUT
     Pioneer wooah
     Netbook/HiFace
     Leak + mayhem
     Living Voice IBX R2
     Gordon Welford
     845 SET / KT88 PP
    Headphones
     No bloody way
    That will be in part because I wasn't addressing your point other than to mention its validity in passing while echoing the same question.
    Otherwise the answer to your question is prosaic - cost, and the fact that electronics engineers live in a hypothetical world where all operational conditions are optimal - this is why all their theoretically optimal, low-distortion equipment sounds like dogshit to our highly subjective and individual ears/expectations, and why they leave out line conditioning, because according to their manuals all mains power is a perfect 230VAC undistorted sine wave.
    Indeed you weren't and indeed you did and indeed you did. And yes. And yes again. And, I think, yes once more.
  7. #147
     Dec 2006
     G. Rumpty Git
     Well (bad) Tempered
     Dynavector XX2
     Kairsound SUT
     Pioneer wooah
     Netbook/HiFace
     Leak + mayhem
     Living Voice IBX R2
     Gordon Welford
     845 SET / KT88 PP
    Headphones
     No bloody way
    There are two different arguments going on here.
    Primarily, I buy, build and modify hi-fi equipment purely on the basis of its ability to reproduce music. That is all I am interested in. As long as it fulfils that basic function well, then how it measures is totally irrelevant.
    However, I do expect it to perform consistently. If is is adversely affected by the power supplied to it, then in my humble opinion, it is not fit for purpose.
    Anyway. I'm going to listen to some Bach organ pieces on my poorly-measuring system. I expect them to affect me, and not adversely. Therefore, I have achieved my aims.
  8. #148
    Wammer Cyclopse's Avatar
     Dec 2010
     Prometheus Audio
     Schroeder R, Atlas
     Whest Black Edition
     Nagra CDT
     Rasberry Pi USB out
     Meitner MA-1
     Paul Hynes PS
     Raidho C1.1
     Modwright LS36.5
     Mark Levinson 331
    Headphones
    Quote Originally Posted by russ abbott - royds brother View Post
    Mr abbott would like to know what deck you have?
    Cyclopse looked far and wide for a turntable that meets his demanding requirements. When he came across this manufacturer he knew his search was over:-
    http://www.prometheusaudio.co.uk/
    Regards
    Cyclopse
  9. #149
     Jan 2010
     Horley, Surrey, UK
     Roksan Xerxes 20+
     N/A
     All valve
     Pretty damn good!
    Point not missed, just skidded over, Mr Rabski!
    As you said, how come your amp can avoid these mains borne problems when Hi Fi at a much higher cost can't?
    A point well made. I simply took the opportunity to whizz off on a hobby horse of mine. Why do live gigs sound so good but, at the same time, sound so "wrong" in a Hi Fi sense.
    Bass and keyboards, eh? Not Squarepusher are you?!!
    Guy
  10. #150
    Wam Fooodly doo di da vacdac's Avatar
     Jul 2011
     Gyro SE Oyaide MJ-12
     Jelco750 AT33EV/PTG2
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Oppo BDP103D/dab500
     C.A. SM6 + 5 more
     Schiit Lyr2
     X.T.Z. 99.36piano ii
     M.F. A1 fbp
     XTZ AP100
    Headphones
     AKG Q701, ADH700X
    Chris says That's a Feckin ace TT
    As to Elektwickery ....well shucks Buttercup you would seem to know sweet F.A. as wegards dat....I'd suggest a cavity search to see if Lars is still up one still causing mayhem as this is clearly causing a cognitive infarction in your case
    Wegarrrrds vacdac
    Quote Originally Posted by Cyclopse View Post
    Regards
    Cyclopse
    Gyro, Jelly750d, Oyaide MJ-12, AT33EV/OC9ml ii/F3iii, Rondo Red carts, Icon audio PS 1.2 phono, C.A. Stream Magic 6, Oppo BDP,(Synology DS715/Acer timeline X lappy. Alva Nanoface) M.F. A1fbp/Schiit Lyr2 pre's, XTZ ap100 power, XTZ99.36 speaks, x-can v8, AKG Q701
  11. #151
    Wammer penance's Avatar
     Disappearing up my o
    Sodbury wonders why all Bristolians are mad bastards.
    Penance see's soders envy.
  12. #152
    Penance rests his case on sodders.
  13. #153
    Super Dooper Wammer daveyu's Avatar
     Mar 2011
     SME 20/2
     SME V / CA Accurate
     Nagra VPS / VFS
     Mark Levinson 37
     Mark Levinson 306S
     Merlin VSM/MM
     C-J Act 2
     C-J 140
    Headphones
    Looks like I started something here, the facts are that I needed some new powerpoints in a new room for my hifi, so why not get a new spur,
    to my ears it makes a difference and I spent the money (not that much really).
  14. #154
    Old Age Pedaller Camverton's Avatar
     Jul 2009
     East Sussex
     Malcolm
     In the loft
     PC JRiver
     Oppo
     Meridian Director
     Hegel H360
     ML Electromotion
    Droodzilla, chumpy, and now penance: sodbury rests his case.
    I would like to rest my spur on Sodbury but alas it isn't big enough. Mine you am a bit pissed.
    Btw, what the fuck is this thread about?
  15. #155
     Southampton, , United Kingdom
    Quote Originally Posted by hearingisbelieving View Post
    I use two BT mains conidtioning units as filters for my hifi. I bought them for £20 a piece and never hear any clicks or pops. I guess if they are good enough for BT then they are good enough for me. Job done!
    Ahhh yes - they were made by Oneac (grey boxes). Quality bits of kit if you can find them.
    AV kit: JVC HD1 Projector, Yamaha RX-V775, MA Bronze 7.1 speakers, 2 x DIY 15" Sealed Subs, Sony BD370, HTPC.
    Stereo: HTPC - TEAC UDH-01 DAC, Marantz 6100 Monoblock Amps, MA B4 Speakers.
  16. #156
     Feb 2008
     UK
    I liberated a 2 gang Olson mains conditionim unit (from a skip). It is basically a metal box with 2 good quality sockets, and a shielded mains lead into a filter unit. The filter consists of a DC Blocker, RF Choke & Switching noise supressor. The very same type of filters are present in my cheapest of the cheap clock radio. I use it to supply my second system (NAD 325BEE/NAD C520), as it isolates my hifi from a nearby wallwort type power supply. Why this type of filter is not fitted internally as standard in high end kit is beyond me. Very cheap to produce and easy to implement. I would be surprized if they cost more than £5.00 a piece. They would completely negate the need for external filtering and dedicated power supplies.
    There are some overly complicated power supplies out there. It should be simple. An amplifier needs good clean power, be it a transister amp or an I/C based amp. Some amps need a regulated (voltage stable) power supply (FET's/Transistors/Op Amps etc), and some amps can get away with unregulated power supplies (Chip Amps such as LM1875/3875 etc). As long as they are a clean DC level (off load for unregulated), and have enough capacitance to cope with the transients of the music at the required level of amplification (for the load supplied).
    A filter to remove the DC component from the AC waveform and another filter to remove switching noise and RFI. Then a good quality, low nosie rectifier, and enough capacitance to remove the noise. A monolythic (3-terminal) regulator to take care of the voltage regulation (although, high power systems may need discrete regulation to deal with the extra power), and it really is that simple. Alright, some systems may need more than 1 different voltage, but the principle remains the same.
    Tomorrow belongs to those who can see it coming.
    Chris.
  17. #157
    Super Wammer nomismo's Avatar
     Jun 2009
     Near the Middle
     Splodge
     Gone
     Gone
     Gone
     Meridian G08:2
     Auralic Aries
     Auralic Vega
     Packed away
     gone
     Gone
    Headphones
     Senn HD650's Taurus
    If your gullible enough to want one and pay the price i'll pop around and put one in, realistic price no returns
    Quote Originally Posted by vacdac View Post
    I'm lovin the logic here guys......must say I think I'm sold on going for one of these solutions myself....does anyone know of a suitable gimp who can install one of these solutions for me for triple r.r.p. & bonus fee & totally unreasonable surcharges whilst royally rogering me from behind using my ball gag for leverage?
  18. #158
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Oppo BDP103D/dab500
     C.A. SM6 + 5 more
     Schiit Lyr2
     M.F. A1 fbp
     XTZ AP100
    Headphones
     AKG Q701, ADH700X
    Quote Originally Posted by nomismo View Post
