Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21
    Wammer vacdac's Avatar
     Jul 2011
     Gyro SE Oyaide MJ-12
     Jelco 750 AT33EV/OC9
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. x-can v8 AKG272
     X.T.Z. 99.36piano ii
     M.F. A1 fbp
     XTZ AP100
    I get absolutely no problems, with static build up following wet cleaning on my moth pro either John, I've heard some people claim in the past that increased revolutions during cleaning can be a cause of this & therefore recommend 3-4 revs each way.....I now actually scrub for 6-7 revs in each direction as I find this pretty much always gives good results with no further cleaning being necessary.
    I do wonder whether other domestic/environmental issues may perhaps sometimes be the cause of static problems occurring for some with l.p. cleaning/replay.....a few years ago I used to wear a lot of high tech fabric outdoorsy clothing during the summer particularly, i.e. gore-tex/fast drying polycotton cargo pants, shirts etc & I would often get static build up when playing vinyl, I'm sure some will have had the experience of touching an escalator handrail & getting a small static discharge.....I now pretty much always wear natural fabrics wool/cotton/linen/silk etc....other than water proof coats.......I may be talking ooot of my arse re this point , but I do wonder whether carpets that have a polyester content may be a contributory factor in some households as like I say I have no problems at all re this & all my rugs etc are pure wool.
    When I used to get static build up in the past I used to find touching the metal (aluminium) handle of my carbon fibre record cleaning brush to the spindle of the record deck would allow it to discharge.
    Gyro, Jelly750d, AT33EV/OC9,Rondo, carts. Icon audio p.s.1.2 phono, C.A. Stream Magic 6, TEAC cd, Musical fidelity m1 d.a.c.(netgear readynas duo/acer timeline X lappy. Alva Nanoface) M.F. A1fbp pre XTZ ap100power,XTZ99.36 speakers,x-can v8 & x10v3, AKG 272hd
  2. #22
    Beer Monster themadlatvian's Avatar
     Dec 2008
     Huddersfield
     TD160B mk2 modified
     SMEIII, Denon DL-304
     In Sony
     Sansui CD-X501i
     SBTouch + server PC
     Sony TA-F770ES
     CelestionA3 modified
    Quote Originally Posted by vacdac View Post
    I do wonder whether other domestic environmental issues may perhaps sometimes be the cause of static problems occurring for some with l.p. cleaning/replay.....a few years ago I used to wear a lot of high tech fabric outdoorsy clothing during the summer particularly, i.e. gore-tex/fast drying polycotton cargo pants shirts etc & I would often get static build up when playing vinyl, I'm sure some will have had the experience of touching an escalator handrail & getting a small static discharge.....I now pretty much always wear natural fabrics wool/cotton/linen/silk etc....other than water proof coats.......I may be talking ooot of my arse re this point , but I do wonder whether carpets that have a polyester content may be a contributory factor in some households as like I say I have no problems at all re this & all my rugs etc are pure wool.
    When I used to get static build up in the past I used to find touching the metal (aluminium handle) of my carbon fibre record cleaning brush to the spindle of the record deck would allow it to discharge.
    Chris - I have no doubt at all that there is a lot of truth in what you are suggesting. We used to have a very nice blue carpet in our lounge - but it was purely made of polyester or some similar man-made material. The shocks we sometimes got touching metal objects after walking on that carpet were actually slightly painful.
    My Father had a profound influence on me, he was a lunatic. (Milligan)
  3. #23
    Wammer alank950's Avatar
     Dec 2009
     Northern Ireland
     Alan
     Vpi Aries Scout.
     Lyra Dorian
     Microgroove+
     Nu Vista 3D
     M Fidelity A5 Tuner
     Nu Vista M3
     Guarneri Homage
    Quote Originally Posted by themadlatvian View Post
    I find that there is a terrible static problem if I only dry wipe a record, but that wet cleaning them in my RCM (Moth) doesn't produce that problem at all.
    If I dry wipe some vinyl, I can pick up the record and remove it from the turntable with my heavy Dumpa mat still attached by static!
    So you think that if i run them through a solution in my disco antistat ,that should be fine?.Gonna give them a go with a steam cleaner also.Seen a few vids on utube about this and as long as the steamer is not held to close it does a great job.
    If the truth can be told so as to be understood it will be believed.
  4. #24
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. A1 fbp
     XTZ AP100
    Hi Alan,
    I reckon it's a case of suck it & see....if you do find you have a persistent problem with static then the Milty Zerostat gun may be worth considering as I've seen many people claim in the past that its done the trick for them, Superfi stock it for £40-95 http://www.superfi.co.uk/search.aspx...lty%20zerostat, that includes mainland UK delivery...not sure about N.I. tho, so I've also included a link from Amazon http://www.amazon.co.uk/dp/B0033SHDS...SIN=B0033SHDSS , the seller is still Superfi, but it does say UK delivery, which unless otherwise stated should include N.I.
    Quote Originally Posted by alank950 View Post
    p.s. Amazon do 99% I.P.A. for £6-99 inc UK delivery which seems gvfm...if you need to source more in the future
    Chris oooot
  5. #25
     Dec 2009
     Northern Ireland
     Alan
     Vpi Aries Scout.
     Lyra Dorian
     Microgroove+
     Nu Vista 3D
     M Fidelity A5 Tuner
     Nu Vista M3
     Guarneri Homage
    Hi Alan,
    Chris oooot
    Thanks Chris
    Ebay have some good prices on I P A also.Its the wetting agent i am having trouble sourcing.The smallest i can find is 1ltr on ebay and i dont need that amount.Gonna ring a local camera shop here tomorrow to see what they have.
    The static shocks i get sometimes from my equipment is serious and quite alarming especially when i am not expecting it.Makes me go" ####!" sometimes.
    Hi Alan,
    Chris oooot
    Thanks Chris
  6. #26
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. A1 fbp
     XTZ AP100
    The Ilford Ilfotol (wetting agent) I use is in a 250m.l. bottle, if you strike out trying to source it or something similar locally try Jessops..mail order they only stock it in one litre for £11-95...which as you suspect would likely last forever, you could maybe split it with someone else perhaps & still have more than enough
  7. #27
    Wammer uzzy's Avatar
     Apr 2006
     Northampton, UK
     Systemdek IV/Decca
     Marantz CD6004
     HB Burnit Pro
     Cambridge DACMagic2
     Art Impression
     AR SP9
     Hafler DH200
    If you go online get triple distilled water rather than use the deionised stuff from Halforfds. According to my daughter that is what they use in the labs for biology/chemistry because it has absolutely no nasties in it whatsoever. I also heard somewhere that methyl alcohol was better than Isopropyl but i do not know for sure - years ago when i worked in a hi fi shop we used Methyl in the KMAL machine.
    Do not overdo the alcohol there is a lot on the internet about it if you search - i would not do more than a 2 parts alcohol to 8 parts water as the alcahol can be damaging over time if the mixture is too strong.
    Thanks for the tip about the photographic wetting agent sounds to be a brilliant addition.
    I bought an okki nokki cleaning machine on ebay for just over £300 and its brill. I also use a microfibre cloth rested on for a few turns to make sure the LP is totally dry.
    uzzy recommends an ear wash as being the cheapest upgrade many can make in improving audio reproduction.
  8. #28
    Banned
     glasgow
     scott
     Artemis SA1
     Conductor Musicmaker
     Marantz UD9004
     dared EF-99
     Usher Be10
     Dared T9
     Dared T300PP
    mate has a Moth Rcm he is selling if still required
  9. #29
    We are doomed
     Nov 2011
     Hungerford
     As above
     Turns
     Transcribe
     Equalises
     Spins silver discs
     Converts
     Speak
     Attenuates, switches
     Amplify
    Quote Originally Posted by scott View Post
    ...and on the theme of returning to the OP, try speaking with Terry at Loricraft in Lambourn. He sometimes has ex-demo cleaners for sale. I have one myself and would recommend it. Squeaky clean results - no blades and no static.
  10. #30
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. A1 fbp
     XTZ AP100
    Not really sure of the point you're making here Kevin.....given that Alan the op has asked many of the subsequent points being discussed
    Given that he's baulked at the price of a new vacuum type R.C.M. & is enquiring re S/hand ones & has subseqently bought a Spin Clean.....I doubt even a S/hand Loricraft would b enticing as the price would still likely b rather high. As has already been discussed...other vacuum R.CM.'s i.e Moth that use a carbon fibre brush & vacuum arm...not blade ...do not in themselves cause static, this is far more likely to be an environmental factor...I myself get none despite using a prolonged cleaning cycle which I've found to give better results.
    Whilst I agree that Loricraft/K.M. are lovely things & are undoubtedly v. high quality & nice things to own....I'm unsure of the point you are trying to make here as I don't really see how if used proficiently you can't do an equally good job using other mfrs offerings, such as my Moth Pro RCM(self modded) with which I can bring even totally crudded up vinyl up to scratch wiv just one cleaning cycle
    Quote Originally Posted by KevinF View Post
  11. #31
    We are doomed
     Nov 2011
     Hungerford
     As above
     Turns
     Transcribe
     Equalises
     Spins silver discs
     Converts
     Speak
     Amplify
    Chris -
    In the Original Post, the postee asked:
    "Anyone have a decent record cleaning machine they want to part with?"
    I have addressed this question.
    If he or anyone else thinks a plastic bucket with alcohol and wetting agent is *decent*, that's his and their prerogative.
    Show me where in my post I suggest that your beloved Moth causes static. You seem to be remarkably sensitive to a non existent slur on your own choice of RCM.
  12. #32
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. A1 fbp
     XTZ AP100
    Kevn,
    You seemed to be suggesting the subsequent discussion points were digressing from the o.p. & you were were somehow riding in on your"White Charger" & saving the day whereas you were pointing him at an ex dem retail item, likely to be rather pricey & quite possibly not even available...so not even "answering the op at all really here you are re. your denial!!..."Squeaky clean results - no blades and no static." quite clearly seems to be inferring other types of R.C.M. do cause static & what are these blades you're on about...huh?, & whats wrong with someone making their own cleaning formulation? , these are well documented & I see no reason they shouldn't work extremely well ! I was fairly complimentary re your Loricraft....not really massively concerned that you seem to be being rude about mine, if that helps fill in "your Playtime"...fine .....the only thing I objected to was the disinformation & utter nonsense
    Chris -
  13. #33
    We are doomed
     Nov 2011
     Hungerford
     As above
     Turns
     Transcribe
     Equalises
     Spins silver discs
     Converts
     Speak
     Amplify
    Kevn,
    Some days are just not good days for you, are they Chris?
    Take a chill pill and stop overreacting.
  14. #34
    hup two three four wammer
     still old and black
     yup
     Yes indeed
     Runs Windows 7/64
     AN 4.1x sig
     AN-E
     Vibe/Pulse
     Tron
    Scott, methinks you must clear your inbox.
  15. #35
    Banned
     glasgow
     scott
     Artemis SA1
     Marantz UD9004
     dared EF-99
     Usher Be10
     Dared T9
     Dared T300PP
    inbox cleared
  16. #36
     Jul 2011
     Icon Audio ps 1.2
     C.A. SM6/Alva NF
     Teac cd/dab500
     M.F. m1/C.A. SM6
     M.F. A1 fbp
     XTZ AP100
    Lol, love that you have such great insight into my psyche Can't see how I'm overreacting when I'm merely offering a rebuttal to some clear lack of veracity/wrongness in your statements.....as for your further obfuscation & sidestepping of the points I made/questions I asked of you.....well that's simply hilarious .....s'all just smoke & mirrors really tho' !!
    Lol
    vacdac
  17. #37
     Dec 2009
     Northern Ireland
     Alan
     Vpi Aries Scout.
     Lyra Dorian
     Microgroove+
     Nu Vista 3D
     M Fidelity A5 Tuner
     Nu Vista M3
     Guarneri Homage
    Gonna try steam cleaning and a bath of home mix in the Antistat.Then hoover the residue of with a Henry Hoover...might be cheep but i am shure it will get the records pretty clean.
  18. #38
    Super Wammer Chumpy's Avatar
     Dec 2005
     BLACK LP12-Pro-Ject
     Naim CD5i-CD7300
     Naim5i-PM7200
     CV V15F-Kans
    Good practice = store-use suitably - nice water/Fairy liquid/carbon-fibre/nice J cloths etc to pat-dry. Sometimes a bit of suitably applied/removed isopropyl alcohol does biz.
    OR buy overpriced bit of 'technology' to gouge out your (usually unless Monty Python MTAH) 2 grooves.
    Does your record-cleaning machine need cleaning???
    'Sometimes via the senses, mostly in the mind' (or pocket)...
  19. #39
    Super dooper Wammer
     Sep 2007
     Bicester, Oxon. UK
     Lee
     NA interspace & arm
     Audio Analogue Maest
     AA Maestro, Whest
     Arcaydis AK3
    The back and forth here does remind me of this....(scroll to the 2 mins mark and watch from there)
    just gotta get to the next get together!
  20. #40
     London, , United Kin
     Robin
     clearaudio Innovatio
     Phantom/ Lyra Atlas
     Esoteric E-03
     Nagra CDC
     Magico V2
     ARC Ref 5
     darTZeel NHB 108
    The Loricraft 'seconds' aren't substandard at all as far as I can see. They're not 'used' either, but do represent a saving over advertised list prices. (for anybody interested)
    This looks cool http://www.hannl-vinylcleaner.com/en/?page=aragon_el
