Head Room  Audio Emotion Temple Audio  The Hifi ShowTemple Audio
Results 1 to 16 of 16
    Super Wammer MF 1000's Avatar
     Apr 2011
     Chester
     Keith
     Rega Planar 2
     Rega & AT95
     Rega Fono
     Roksan Attesa Mk2
     Trichord Pulsar 1
     Horns & Tr Lines:)
     Type 26 Valve - SJS
     Ming Da 845 Monos
    Headphones
    Musical Fidelity A370 Power amp
    Got home this afternoon after travelling over the other side of the country to collect a Musical Fidelity A370 power amp that I had won on eBay. For those of you unfamilier with this 'beast' it was made around 25 yrs ago as MF's answer to Krell power amps - and a beast it is weighing in at over 45Kg and around 300mm tall.
    Its a Class A 185 watt per channel amp that draws 650 watts at idle......wont need the central heating - both sides on the amp are actually the heatsinks and heat up to around 60 Deg C !
    here is the amp sat on top of my rack....best place to dissipate all that heat
    On getting it home I took the top off to take some pics..and remove a load of fluff with a air duster !!....
    The isnside of the amp is dominated by two huge torriodal transformers (its essentially a pair of monoblock amps in one box) with associated reservior capacitors, and 10 op amps per side bolted directly to the massive heat sinks.
    torriods...
    reservoir caps ....yes 10 22 000 uF Elna caps per channel !!
    There is some evidence of overheating in the past on the top of the circuit boards...these amps were well known for this ....maybe an area to be sorted in the near future.
    Once cleaned I connected it up...fed from the preamp output on my MF XA-1 (it has a passive output ) that currently feeds the Fostex 103 fullrange units and additional Kef T27 tweeters. I left my trusty MF A1000 (50 watts Class A super integrated amp) to drive the transmission line R50 bass units.
    We put on Hugh Lawrie...St James Infirmary and WOW ....at my bake off I had thought that the midrange from the Fostex was lacking....but now it hits you full on - loads more detail and impact. Ive been trying all sorts of tracks since and every one is a step change for the better
    The bonus on collecting the amp was the guys mother insisting I took the pre amp he had been using with it aswell...!! So I now have a Musical Fidelity MVT preamp
    Ive tried it in my system, but currently it doesnt sound as good as the passive control via the XA-1...maybe it needs some TLC and upgrading.
    Ill let you know how this progress with this beast....
    Keith
    eye eye wee tam's Avatar
     Jan 2009
     Washington Tyne&wear
     TOMMY
     DM LOGIC 101 MK1
     syrinx shure v15
     pioneer PD 91
     MERIDIAN 563
     KOSS CM1030
     SANSUI AU555A
     MAGNUM MF 250
    Headphones
    that as they say , is a bloody big beastie laddie , it might settle down , any idea if its been in regular use , or stored over a long period ? looks awesome btw , first pic of the rack with each box getting smaller the lower you look is
    sansui AU555A , magnum MF250 , pioneer PD 91 , meridian 563 ,logic dm 101 mk1/ AR the turntable , koss CM1030 ,marantz 2020 tuner and some cables
    Super Wammer rmsshipbroker's Avatar
     Feb 2012
     Yorkshire
     Steve
     Technics SL1210
     AN Arm 2 + IQ3
     An Kit MM stage
     AN CDT-Two
     AN DAC 2.1x Balanced
     AN Oto SE Phono Sig
     Audio Note J LX
    Jesus H Keith, that's bigger than my oven!
    (Probably warms up hotter as well)>
    Testing sofas to destruction since 1961
    Founding Wammer SSM's Avatar
     Tipoca City
     PP-1, SS-5
     12pr
     Triode-3, SS-1
     SE-3, PP-2, SS-2, 1D
    Headphones
     LOL
    Nice one Keith. The A370 is pure classic MF. I'm sure it has really given your choons a real can boost!
    Its quite a big bruiser though, I can understand why the seller's mummy wanted it out of her house. 650W at idle is no joke though. You could make lots of espressos on the side if you opted for Class D instead.
    As for the MVT pre not sounding as good as the X-A1... I'm not too surprised. I'd used my X-A2 as a pre into Quad 909 and it is more than decent. Clean clear and dynamic... a notch better than Arcam A28's. So don't be too quick looking for a new preamp.
    Enjoy
    SS
    CONRAD-JOHNSON HD3 & ET3SE > SUN SV-2A3 L.E. 25th Anniv. SE Class A | NAIM DAC V1 > C-J CLASSIC 60SE PP
    PRIMARE DAC30 > AYRE K-5xeMP > 6V6GT SE Class A | audiolab M-DAC
    > ICON AUDIO LA4 MKIII > EL84 SE Class A
    MUSICAL FIDELITY X-T100
    (modded valve pre) > GENESIS Advanced Tech. M60 (& I60) PP | PRIMARE A34.2 Class D
    OMEGA SUPER ALNICO & 3i Monitors |
    PRECISION 6.2, ELAC BS244, ATC SCM11, S3/5R, Alnico, XERO, DM 2/6, Q 2020i
    SS relics: REGA ELICIT, ARCAM A38, Musical Fidelity X-A2, NAIM NAP 100, QUAD 909, SONY TA-F246E | (reserved)
    Wammer It Cost How Much!?!'s Avatar
     Oct 2008
     Cheshire, good side.
     Bob
     SP10 Mk2/Bobc plinth
     SME 312S/ortofon
     S&B/Hagerman Trumpet
     Esoteric P-30
     Da F..kin' PC
     AS DAX Decade
     Avantgarde Solo +M&K
     Gryphon Bel Canto
    That looks like my old pre/power amps I sold it to a guitarist chap who wanted to use it for his guitars. Mk1 A370, the best one in my view. They sound best after 3 hours warm up when the power amp is fully warmed through, I warn you! Lots of heat and the pre is good, so if it's not sounding good get it sorted
    Super Wammer awkwardbydesign's Avatar
     Mar 2012
     Plymouth
     Oracle
     Decca
     Consonance
     Troels
     TVC
     Jungson
    Headphones
    I bid for one of these once; didn't win it. Probably just as well, as our electric bill is high enough as it is!
     Oct 2008
     Bob
     SME 312S/ortofon
     Esoteric P-30
     Da F..kin' PC
     AS DAX Decade
     Gryphon Bel Canto
    Next step, A570....
     Apr 2011
     Chester
     Keith
     Rega Planar 2
     Rega & AT95
     Rega Fono
     Roksan Attesa Mk2
     Trichord Pulsar 1
     Horns & Tr Lines:)
     Type 26 Valve - SJS
     Ming Da 845 Monos
    Headphones
    Quote Originally Posted by awkwardbydesign View Post
    According to my BG electicity monitor...my set up now consumes 1200 watts ...!!!
    For those of you familiar with Janes Choc Fudge cake ....the amp also doubles up as a superb fudge cake warmer ;)
    perfect end to a good day ..... a new amp amd warm fudge cake ...mmmmm
    Super Wammer Vinyl Art's Avatar
     Feb 2010
     Cumbria, The North,
     Cusworth Sig 301
     SME M2-12 & 312s
     Hashimoto/SJS phono
     Soundsmith Koetsu Bl
     Simon Mears Ucellos
     SJS 1.5 Special
     Border Patrol 300b
    Headphones
    Nice one, always lusted after one of these since seeing one at a Dealers in Bath many years ago....get the fudge cake off and get the pies on
     Jan 2009
     TOMMY
     DM LOGIC 101 MK1
     syrinx shure v15
     pioneer PD 91
     MERIDIAN 563
     KOSS CM1030
     SANSUI AU555A
     MAGNUM MF 250
    Headphones
    yep with bob , leave it on idle and use it a slow cooker when your at work , food and tunes when you walk through the door
     Apr 2011
     Chester
     Keith
     Rega Planar 2
     Rega & AT95
     Rega Fono
     Roksan Attesa Mk2
     Trichord Pulsar 1
     Horns & Tr Lines:)
     Type 26 Valve - SJS
     Ming Da 845 Monos
    Headphones
    Quote Originally Posted by BobC View Post
    So my room at Scalford will be official pie warming room will it ????
    best of all I got the beast for 700 ...and the MVT for free
     Dec 2011
    I have one of these running the bass in my 4 way. Very fine amp and agree it has a fab mid-range as I have run mine with it before. I had all the caps replaced in mine as a precaution and have run it now for a couple of years with no problems. It's a keeper!
     Oct 2008
     Bob
     SME 312S/ortofon
     Esoteric P-30
     Da F..kin' PC
     AS DAX Decade
     Gryphon Bel Canto
    I can see a second A370 coming in there...
     Apr 2011
     Chester
     Keith
     Rega Planar 2
     Rega & AT95
     Rega Fono
     Roksan Attesa Mk2
     Trichord Pulsar 1
     Horns & Tr Lines:)
     Type 26 Valve - SJS
     Ming Da 845 Monos
    Headphones
    Quote Originally Posted by Hayward View Post
    Was that just the signal caps Richie ??
     Dec 2011
    No all the big fat ones in the power supply too.
    scott
    used a A370 myself for 15years never missed a beat ,now using 300b & 6c33c
