4 ohm avr
jarrod
170
4
west brom
jarrod
There are none Jarrod. Please elaborate what or why you want one and I'll try to help more.
i have just brought the celestion a series speakers a2 a1 a5 a6s which are rated at 4 ohms so i want a avr that will suit :D
Tel
30,402
575
Hove Actually
Kevin
Just plug them in and play.
all these figures are just nominal. Most AV amps have high wpc outputs and will be fine.
vacdac
11,536
278
Go with a Legacy Processor + Hefty multi channel power amp instead if you need some proper grunt Jarrod. I've just retired my owned from new Audiolab 8000X7 7 channel power amp last week & am looking to move it on if interested. It drives 4ohm speakers with ease & does a really good job with my XTZ 99.36 mk.ii main speakers, which are a tricky load & relatively inefficient....all the slam & volume levels you could want with your Celestions & it's gr8 for 2ch stereo use & was my mainstay for this too until I bought my XTZ power amp a coupla years back.
I have the matching 8000AV processor which remains in current use & is also a great unit that can be brought bang up to date w current surround codec compatibility if used with a Blueray that has multi channel outs on phono/RCA's. :cool:
A big Arcam AVR would be a great alternative, as they're not bad in stereo.
moo-fi
1,372
660
Doncaster
Fred
I am looking at driving Kef Ref2.2 x 5 and found that very few AVR's are suitable, Anthem or Arcam are really the only ones I have found not to run in fright. A Processor with a proper power amp is the way ahead but expensive. If you look at the current draw from the mains of most AVR's you will see they are really lacking in the drive department, forget makers power claims as they are works of creative accounting.
Still looking though but it seems to be either a Rotel pre and power combi or an Arcam AVR (I object to Anthem UK price compared to across the pond).
Tel
30,402
575
Hove Actually
Kevin
Hmmm
Only gets four stars in WTF
Probably rubbish
But hey it is cheap and ignores all the advice in the posts above except mine, difference between me and the other posters is that I know nothing about AV :D
surayne
1,519
10
Surrey
If you're driving something like Kef Refs then pre/power is the only sensible way to do it, but there are bargains to be had with older multichannel power amps. I've seen Meridian 558s go for under £1K, it would drive pretty much anything. The Emotivas from across the pond are highly rated too.
An alternative option is to use a stereo power amp or monos to drive the front speakers (using the pre-outs of the AVR) and use the inbuilt amps of the receiver for the surround speakers. I did this for a few years and it worked very well.
kawuschel
