For Sale: Acoustic Energy AE2 mk 1 (According to AE they were built in 1996)
Price: £802801800 plus p&p at cost or pick up or WAM taxi or pick up at Lurch's bakeoff.
Purchased from boardsofcanada in Feb 2019 after having heard a pair at a Wam Show and took the opportunity to buy these when they came available.
I was not disappointed and have enjoyed my time with them, but now I have the Posselt Albatross speakers, the AE2's are sitting there not getting used.
I have successfully driven them with a SET valve amp with approximately 10watts output and a solid state class A amplifier with 100wats output.
Since being purchased they have been resprayed, as when I bought them they had a number of scratches which were needed to be addressed.
The resprayer was asked to match as close as possible the original finish and in my opinion he did a very good job. The visual condition is now 9 maybe even 9.5 out of 10.
No damage to any of the drive units or grills.
Stands not included in this sale.
Dimensions: 15.15" (385mm) H by 9.25" (235mm) W by 11.8" (300mm) D.
Weight: 37.5lb (17kg) each.
Description: Two-way, reflex-loaded, stand-mounted loudspeaker.
Drive-units: 1" (25mm) metal-dome tweeter, two 4.5" (110mm) metal-cone woofers.
Crossover frequency: 3kHz. Crossover slopes: 4th-order, 24dB/octave.
Frequency response: 65Hz–18kHz ±2.5dB, 50Hz–22kHz ±4dB.
Sensitivity: 91dB/W/m (2.83V).
Nominal impedance: 8 ohms (5.5 ohms minimum at 50Hz and 250Hz, 16 ohms maximum at 27Hz).
Power Handling: Amplifier requirements: up to 250W.
Price: £802
