Linn Owners
Adding Majik 2100 to Majik I as preamp
huzy
166
3
Gdynia,Poland
Kris
Hi Gents,
The Majik I integrated would act as a preamp only connected via its preouts with The Majik 2100 power.
Will this marriage be a significant upgrade over the Majik I integrated alone?
Thanks for comments
zee9
Audio Junkie
1,298
680
New Jersey, USA
Zorawar
A different sound it would be. The 2100 is faster and may sound clearer with Dynamik but it’s a different sound to the older amps.
Adsm/3 >> Akurate 4200/1 >> Tukans (Silvers/K400)
Elad Repooc
342
473
Pacific Northwest
Which version of the Majik I, and 2100?
If both have Dynamik, they are going to sound similar but the 2100 will improve the performance in terms of tune. Not a lot, but it will be there.
If neither do, then it's the same difference.
If Majik-I has Dynamik (must be a newer one then, the older ones don't support Dynamik) and the 2100 does not, don't bother with the 2100 unless you want to purchase a Dynamik for it.
If the 2100 has Dynamik and the Majik-I does not then it will be a pretty noticeable difference as zee points out. It may or may not be to your liking depending on the speakers, but personally I like the faster, cleaner, punchier sound of the newer Chakra amps. The older amps sound a bit slower and "rounded" in comparison. Musical to be certain either way.
I am not sure which speakers you own but assuming the Majik-I and 2100 have the same relative gain then you can consider bi-amping. You would need to determine which versions of the electronics you own to see if this is possible.
Reactions: Tendaberry
huzy
166
3
Gdynia,Poland
Kris
Thanks,I do not intend to biamp.
What is the Dynamik bringing to the party as regards the Majik I integrated?
akamatsu
Michael
5,409
5,345
Michael
Here's an alternate suggestion; get a Majik DSM. I think it will outperform any system you create around the Majik-I.
I recently bought and tested out a Majik DSM/3 ($2200). It was fantastic. Please see my signature for what I usually listen to.
The newer stuff is really good.
Reactions: Pennypacker
Pennypacker
d^_^b
621
390
Netherlands
The best option in my opinion, adding a really good streamer, every DSM or DSi has Dynamik as standard so no worries, shortest signal path so no need for a half decent interlink (think at least Linn Silver). And it ads Space Optimisation.
If I should start again in this product/price group a DSM or DSi would be top priority.
Reactions: akamatsu
Jail4CEOs2
1,410
640
Taiwan
I have an excellent MDSM/2 for sale. This setup will be sonically better than the one you propose, and depending on what speakers you have, offers the option of Exakt.
OldLinn
133
73
Marlborough ish
Graham
Until recently I used x4 LK100 power amps (Aktive of course)  but even with all the caps replaced (which to be fair was a massive upgrade) other bits began to die so I bit the bullet and bought x2 Magik 4100 amps and the upgrade was huge infact I have never looked back. Old V New? - NO comparison!
kengxx
