Advice please, volume level.
tackleberry
3,149
Leeds..
I have a Sony tv connected to an 851a, which then runs a homebrew soundbar. I’m connecting the tv to the amp via the 3.5 headphone Jack from the tv to rca on the amp. My issue is the volume control has to be set halfway on the tv and up quite high on the amp. Can I use any other connection to the amp that gives a true audio gain to the amp? Here are some pics of the back of the tv F146FF26-BA6B-4466-ADA1-3455407A3D48.jpeg 1FBF3942-855F-4603-A230-BA52FF9E4E05.jpeg
Nativebon
MUZIC FIRST
1,152
909
London UK
Ian
I don't know how old your tv is, but if you got dynamic compression on your tv sound settings this may significantly improve level output.
StingRay
Legend Wammer
9,830
5,182
Suffolk, UK
Ray
Does the tv have a digital out? I can connect mine to my streamer then play it through that. Volume is similar to other music on streamer.
Using the headphone outlet is probably not the best option.
Reactions: DomT and Strider
Lurch
4,937
5,007
Chichester, W Sussex
If you have ARC on one of your hdmi sockets and an hdmi in on your 851N then that may be a, possibility.
Reactions: DomT
DiggyGun
DiggyGun
292
323
UK
I had a similar problem with my TV. One of the issues that I had was excessive bass during the action scenes, but dialogue was very low. (Common problem on a lot of films). To hear the dialogue at a reasonable level, you had to have the volume quite high, which made the bass far too loud, to the point that the neighbours complained. Another issue was that the input level to the amplifier was always louder than any other input.
To overcome this, I got a nine band graphic equaliser, which I put in line between the TV and the amplifier. Lowering the bottom end bass and raising the top end treble for the dialogue. After a bit if tweaking, it is OK now with an acceptable balance. On mine, however, I have the volume on the TV set to Zero and control the volume via the amplifier. The inputs from both the streamer and the TV are both now at the same level, which helps with the volume.
DG….
glenhb
Glenhb
1,329
579
133
Doncaster
Glen Buddery
4 x USB on the rear for:-
WiFi dongle x1
Local media eg HDD or USB stick or BT dongle x2
USB type B for audio in when connected to a PC x1
1 x USB on the front to connect local media eg HDD or USB stick.
bobovox
0.3636
1,133
1,000
Beckenham
Robert. Not Bob.
I use the audio out RCAs strait out of my (fairly ancient) Sony TV Into my amp using some 3m long RCA cables. I take it your TV doesn’t have those? If not then optical (Toslink) into your 851N would be my next suggestion. If that’s not possible then get an HDMI audio splitter If you have HDMI out on the TV.
Lawrence001
4,308
1,818
133
Lawrence
TVs these days don't do analogue outs as they are usually plugged into soundbars, AV amps etc. So the best option if you don't want to use a proper dac is to get a little optical to RCA converter (which is a small DAC of course).
But you might be able to sort it by using the variable input sensitivy on your amp, IIRC you can set each input at a different gain to match your input components. Have you set this one as loud as possible? It's somewhere in the setup menu.
Reactions: Strider
Strider
Nothing to see here
5,105
2,211
somewhere or other
Mark
I reckon that tv is older than me!
It looks like it doesn't have optical out, one thing you can do is use the SCART plug as most are bidirectional. Get yourself a SCART to composite out that has an in/out switch. Plug a pair of phono cables from the SCART to your amp - av it!
tackleberry
3,149
Leeds..
So the switch nullifies the visual side?
bj10au
