No, it won't affect the picture at all SCART is a pass through, you can just use the line out phono sockets, phono cable to amp.So the switch nullifies the visual side?
No that's in not out
Just the job!@tackleberry
Here you go mate, can either send to you or if you going to the show will bring with me.
Audio to your amp via the two leads I've separated out (red & white RCAs with little black arrows on) and SCART out from TV. The other 3 RCAs are RGB for the picture part which you can either ignore or chop off.
Nope The USB is media in only.
Is it worth buying a cheap DAC with an optical input and analogue output to connect to your analogue amp?No optical bud
There should be just enough room to fit the lead, will maybe be a bit of a sod but possible.That’s fantastic bud. I’m not going to the show unfortunately, I’d really appreciate you sending it though!️️️️️
Put it in the 851n it has many digital inputsOk so it does have an optical , put it through the mini dac converter, and the volume is lower still
Then out to the A?Put it in the 851n it has many digital inputs
Ok, thanks again. Pm on wayThere should be just enough room to fit the lead, will maybe be a bit of a sod but possible.
PM me your addy and will get it sent. If it don't fit in the just bin it as its no good to me.
