Amp Suggestion for Elac UniFi UBR62 Reference ?
JMDM
5
Hi All,
New in here.
I have bought Elac UniFi UBR62 Reference home after auditioning from a HiFi Shop.
However I am not satisfied with the sound pairing it with a class D amp i.e SMSL AO200.
So I am planning to go for a MidFi Class A/B Amp and i was considering stuffs from Arcam as I prefer slightly warmer and laidback presentation.
However i could be wrong and don't wanna make a big mistake by buying the wrong amp, hence I am here for all your suggestions/recommendations.
Thanks in advance..
hiesteem
peacebro
1,180
900
133
Pete
Hi All,
New in here.
Thanks in advance..
Not sure how much you want to spend, but the Rega IO is a powerful and detailed amp at £420. Fits the slightly warmer sound but airy/room filling as well.
The Audiolab 6000a at 50 watt per channel and comes with a dac and blue tooth might offer more in flexibility with all it's digital options and more power.
Reactions: JMDM
johns
94
73
23
Maidstone kent
What was the amp used when you auditioned your speakers, does that dealer stock arcam. You brought your speakers after auditioning them, we'll done, now do the same for the amp.
Good luck and welcome to the wam.
Reactions: JMDM and DaveyTed
JMDM
5
Thanks John for the warm welcome..
The amp used was some Prima Luna Tube Amp which I can't afford at all unfortunately.
No this dealer doesn't have anything from Arcam at all which is again unfortunate.
But I can try alternative sources to get some Brit brands like Arcam.
I can spend from £400 to £470 on the amp either new or even used thus was considering Arcam pre-owned.
I already have an SMSL M500 MKii dac. So only considering a good Integrated-Amp with a remote and an HT input, so that I can use the same speakers with my AVR as well.
Thanks all for the replies.
Reactions: hiesteem
JMDM
5
Thanks for the Rega IO suggestion. However 30W @ 8Ohms, I am being skeptical considering the Elacs are 6ohms ,86db 140W speakers. But my listening space is medium sized though.
hiesteem
peacebro
1,180
900
133
Pete
Cambridge audio is a very good value for money brand, On there website they have a selection of amps and amp/receivers with phono stage.
The AXR85 stereo receiver looks interesting. 85 watts per channel, built in blue tooth, which allows you to stream from your phone or tablet and a moving magnet phono stage for good measure.
I believe Richer sounds stock the brand.
JAD
120
191
43
Sevenoaks have a clearance brand new and boxed MusiCal Fidelity M2si at £499 which imho is a bargain. Possibly not the warmest sound you will get but perhaps an option to consider. Personally, I don’t find it overly bright. Has remote and HT input and will have no trouble driving your speakers.
Reactions: bigrod and JMDM
JMDM
5
As of now I have easy access to these below Cambridge Amps :-
AXA 25 - Cheapest but only 25W
AXA 35 - 35W and in budget
AXR 85 > 85W with Radio budget limit
CXA 81 > Most Expensive and over budget
Anyone can advise on the above those based on the criteria required i.e.
A remote + HT Mode + a bit Warm Sounding.
I don't need Radio or a DAC if that helps..
Cheers 🥂
JMDM
5
Bump!
It's funny that no one even commented anything on an arcam amp though.
languyengoc
