Broken CD Player
Brown Bottle
5,886
1,251
The Hoo Peninsula
Steve
My Creek Evo CD Player is knackered, not reading discs. Yesterday with the help of a mate (alright he did 90% of the work, I held things for the other 10%) we changed the laser mech, which is not the easiest job in the world. Anyway turned it back on and Hey Presto 'No Disc'.
Other than sending it back to Creek, any ideas?
Cheers BB
The Strat
14,024
130
123
Buckingham, UK
Lindsay
I don't know the Evo but I'd have thought probably not worth the cost of repair? Loads of good CDPs out there Rega Apollo is the best of the current crop at real world prices perhaps?
Brown Bottle
5,886
1,251
The Hoo Peninsula
Steve
Hi Lindsay, I just wondered if there was something I might be missing. I certainly wont be sending it to Creek, I have had a problem with both my Amp and CD Player and I haven't been impressed with their customer service. Unfortunately even real world prices are currently out of reach so it's DVD player for now.
Cheers BB
istari knight
1,807
10
South downs
What did you change ? The whole transport or just the laser block ? 99% have an "anti-static point" that requires desoldering before use... I assume that was done ? If not it wont work at all.
V
Voice_Coil
Its not as simple as just swapping the laser, LOL
But people WILL take short cuts.
V
Voice_Coil
That's the point of the thread, I assumed there might be something else! Cheers BB
Some lasers require mechanical adjustment too....then theres the servo...yadda yadda...
The Strat
14,024
130
123
Buckingham, UK
Lindsay
Hi Lindsay, I just wondered if there was something I might be missing. I certainly wont be sending it to Creek, I have had a problem with both my Amp and CD Player and I haven't been impressed with their customer service. Unfortunately even real world prices are currently out of reach so it's DVD player for now.Cheers BB
In which case I would raid the Flea pit for a cheap DAC.
istari knight
1,807
10
South downs
Indeed. Yet not a single one I've replaced has required it & to my knowledge all are still working now. Can you recall if the antistatic point was removed Steve ? They vary between manufacturers but all are very similar in execution to this:
If your friend did remove it then you need to observe what happens when a disc is inserted... To quote from Lukasz Fikus website which I've always found helpful in such situations:
1. Open the player's hood
2. Put an original factory made CD with clean surface and press drawer CLOSE button.
3. Does the drawer close fully?
4. If 3 is yes, then does the CD spin at all?
5. If 4 is yes, does it spin for 2-3 seconds or for over 10 seconds? Does it spin VERY FAST like crazy or with somewhat controlled speed ?
6. If the 5 answer is - controlled speed and 2-3 seconds - the laser is alive and it can detect the beam reflection from the disc surface.
Tips: if the laser is dead, the CD will not spin at all. The CD motor has a signal to start spinning only after the laser heads reports: "reflective surface detected at the height where CD is expected to be ".
Brown Bottle
5,886
1,251
The Hoo Peninsula
Steve
Hi James, no we din't do anything with the anti static protection, we didn't know about it. The problem is that the disc doesn't start spinning, as in Tips above.
Cheers BB
istari knight
1,807
10
South downs
In that case you need to find the anti-static point & remove it... Whilst in place it shorts the laser so it wont work at all.
If you can post what model the laser is I'll look for the datasheet which will show where to find it :)
seasidersrock
832
21
Blackpool
Ian
You could also consider the replacement laser is U/S.
Philips stopped production, whats available from the Far East in my own experience dont meet Philips spec and are cheap copys.
I had the same problem replacing a VAM 1250 in my Maestro, only sorted by sourcing an original Philips produced unit....
Just a thought............
seasidersrock
832
21
Blackpool
Ian
You could give Colin at Chevron Audio a ring..... He sorted out my Maestro, one of the good guys and prices are reasonable.
istari knight
1,807
10
South downs
James, it's a Philips VAM1201 laser assemblyCheers BB
Ah, okay... I do recall fitting one into a Marantz CD67 - Theres no antistatic point on it, just a shorting clip that sits along the ribbon cable connectors... That needs be left on until the very last moment otherwise its goodbye new laser.
Its one of those situations where there's so many variables involved its very hard to advise... Of all the laser's I've changed [dozens] these are the biggest PITA. I'd send it back to Creek for repair & then flog it.
