Cable suggestions sought for multiamping horns... any secret DIY bargains out there?
Inamelotone
176
21
Down South
Hi Folks
I am planning on rewiring my set up and having as many of the wires neatly tucked into their own wooden diy trunking system... as I have settled on a 4 way system that means quite a lot of cable running around the room, not to mention trying to keep hum at bay, etc. hence why I have decided to make an effort!
I can't bring myself to spend hundreds, so was wondering if you guys had some secret DIY tips on the hidden loudspeaker cable gems out there... ? Also, based on your own experience, how critical is it that the cables are of the same length left and right? Currently to keep things as tidy as possible would mean the right channel cables being 2 metres longer or so...
Thanks for your thoughts
Inamelotone
Tony_J
19,927
198
Bunessan
Tony
Hi FolksI am planning on rewiring my set up and having as many of the wires neatly tucked into their own wooden diy trunking system... as I have settled on a 4 way system that means quite a lot of cable running around the room, not to mention trying to keep hum at bay, etc. hence why I have decided to make an effort!
Inamelotone
There's a useful analysis of speaker cabling and its effect (or not) here: http://www.roger-russell.com/wire/wire.htm#differences
vacdac
11,536
278
Van Damme Hi-Fi UP-OFC 4mm or 2.5mm depending on amp used.....the 6mm is frankly overkill for most domestic hi-fi needs but is still affordable if you think you really need it. :D
Lots of us on here use this I use the 4mm w jumpers made from the same for my triwirable XTZ floor standers, I do have a v high current amp though @ 62.5amps. The 4mm is more than enough in this application. The Nakamichi Z plug/BFA's are also excellent as are the Sewell all copper spades. Both are inline double screw fixing & give an immensely strong termination IME.
Lots of us on here use this stuff, either self built or sourced ready made from the always excellent Paul @ Purite North:^ who is a dealer & regular contributor on here.
stewartwen
3,583
34
near Blackpool
Stewart
If you go to City Electrics, a real visit in person. They will show you what they have......................they are very helpful and have branches all over the country.
I buy quite a lot of cable from them and have always been delighted with them and of course they wont rip you off..........have a look at the 3-7 core Doncaster from their stock list.
S
Reactions: vacdac
vacdac
11,536
278
If you go to City Electrics, a real visit in person. They will show you what they have......................they are very helpful and have branches all over the country.I buy quite a lot of cable from them and have always been delighted with them and of course they wont rip you off..........have a look at the 3-7 core Doncaster from their stock list.
S
Years ago I bought a fan speed controller from them that another supplier tried to charge me £52-50 for City Electrics charged around £7-50 inclusive of VAT.....They're good for all sorts & v helpful, whenever I've used them with no B.S. & great prices. :cool:
Inamelotone
176
21
Down South
Thank you all... I was looking into Van Damme so good to see it is well thought of. Thanks also Paul for putting my mind at rest about using different lengths! A good audio buddy of mine swears by the Anticable solid core stuff, which might be just within reach I suppose, but I hear it can sound a little hard, something I am trying to avoid. Have any of you played with this stuff?
egs
