Can I 'Cast' to a R-Pi?
The Wam Show 2022 Confirmed, click to read more.
Bourneendboy
310
20
Tackley, Oxfordshire
Bill
I have a Raspberry Pi with an Allo Boss DAC hat and use Volumio and Bubble UPNP to stream Tidal.
However, I really like the ease of Casting from my Chromecast Audio and being able to use Tidal through the Tidal App.
Does anyone know a successful way of doing the same with a R-Pi?
Thanks in advance for any guidance.
Man in a van
1,790
313
103
Staffordshire
Ronnie
Hi Bill, would you please describe your envisaged set-up path ?
What is meant by "my Chromecast Audio"
ronnie
Bourneendboy
310
20
Bill
ronnie
Hello Ronnie, hope you are well!
I have a Chromecast Audio that I just plug into my headphone amp via a 3.5mm jack to RCA cable. I really like the convenience of this and being able to stream what ever I like - Tidal, Amazon, Spotify etc.
On the other hand, I generally use a R-Pi/Boss and really like the sound quality from this and was hoping it was possible to be able to Cast to the Pi like I do to the CCA.
Man in a van
1,790
313
103
Staffordshire
Ronnie
I have used this before
https://www.raspberrypi.org/forums/viewtopic.php?f=38&t=247892
I think Volumio has a Bluetooth thingie, But I'm not sure which way it works.
If you try the above link, it should install alongside Volumio.
Make a back-up of your card first.
Also Volumio uses the Raspberry PI OS Lite and when I tried the method described in the link it was with Raspberry PI OS Desktop.
ronnie
Coughin' better, thanks
Bourneendboy
310
20
Bill
ronnie
Cheers Ronnie.
I've got another SD card on the way to try a few things out.
So what's Bluetooth like? Is it a big SQ compromise?
Bourneendboy
310
20
Bill
ronnie
I think Moode may do Bluetooth.
Man in a van
1,790
313
103
Staffordshire
Ronnie
Cheers Ronnie.
I have had a quick go with Raspberry PI OS Lite and the link I mentioned.
I had to find another "instruction" link to set it up, but could not get it to work.
I hardly ever bother Bluetooth, so It's a bit of a learning curve for me.
Of to watch Le Tour, so may try later.
ronnie
Man in a van
1,790
313
103
Staffordshire
Ronnie
Bill, there is, or was, at least, Raspicast
This seems to use the Desktop Raspberry PI OS and an app for Android phone.
This means that it will not run alongside  Volumio
I don't know if it works on Buster best or Stretch.
In fact, I don't know if it works at all :S
ronnie
Man in a van
1,790
313
103
Staffordshire
Ronnie
A local
Not tried that one though, any good?
Sent from my SM-N960F using Tapatalk
Just came back to post this for Bill
https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=284031
Good breakfast, not been since the start of lockdown, I used to every two weeks with a buddy from Brereton. Maybe start again soon :)
Reactions: jamster
jamster
438
210
58
Lichfield
I think both Moode and Volumio also offer Airplay.
One needs an apple device to play from I think.
ronnie
Good point. It looks like PiCorePlayer would do the trick; it is LMS for raspberry pi.
That said, a £25 Chromecast Audio from My Memory might be the least hassle approach.
