Different devices with same remote control operating frequency.......
wizons
1,783
22
Bucks
This is a ridiculous and new situation: the remotes for my DAC and preamp both operate at the same frequency. It is an absolute nuisance. Adjusting the volume of the preamp with the preamp remote also adjusts the output volume of the DAC (which needs to be set at maximum). Changing the preamp's input also changes the digital input on the DAC etc.
Are there any solutions to this problem as it renders the system pretty much unusable?
mattski
477
Surrey
Matt
I had a similar problem and the only way I could partially solve it was luckily that my DAC could be told to accept a different remote command for volume - not sorted power yet though.
brystonian
2,544
323
Bedfordshire
Jim
If you never change anything on the DAC via remote. You could just stick something in front of the IR receiver on the DAC.
cynix
235
71
43
Scotland
Might be possible to change the remote "channel" on one of the devices, check manuals for details.
Or, you could get a remote extender box with a stick on IR transmitter and tape that over the IR receiver on one of the devices.
If you placed the receiver box for the remote extender a few meters away from your equipment rack you could then aim your remotes either at the equipment rack or the IR extender box to control the 2 devices separately. Shielding the sensors to make them more directional may help too.
Zymaze
