DIY streamer
Tony_J
19,916
198
Bunessan
Tony
Maybe I had a defective PSU as sometimes volumio would only last a few days before corrupting. The same went with moode. The supply was the only thing I changed and it's never been a problem even once since.
The Pi is known to need a tad over 5V to be reliable, so it could be that your supply was a bit under spec.
I know I've mentioned this before, but if you want a cheap LMS based streamer / streaming amp, you could do worse than find a defunct Simple Audio Roomplayer and install Squeezelite on it. My last one (without amp) was about £16. The amp version has 50W ICE module. No need for a separate case or power supply as it's all included. No WiFi... just ethernet or built in ethernet over mains.
I put one in the bring & buy at Stoke last weekend - could have had it for peanuts. Contact @Bazzer if you want it ...
Reactions: t1no
bencat
Amplifier Destroyer
8,026
5,057
Andrew
@Tony_J Hold that thought I bought it on Monday as things were being packed up I am looking to load LMS on to it and see what it is like as a Server . But suspect that it is not going to work very well so will just keep as an additional player .
Reactions: t1no and Tony_J
Tony_J
19,916
198
Bunessan
Tony
Ah ok - that must've been after we left.
bencat
Amplifier Destroyer
8,026
5,057
Andrew
@Tony_J Did you change the SSH login details on the unit ? The standard was User - root Password SambaPig but thus does not seem to be working . If you have can you remember what you reset it too as I need to do a little work and need to access via SSH .
Tony_J
19,916
198
Bunessan
Tony
Pretty sure I didn't change it but that was a long time ago - I bought it for the amp board
bencat
Amplifier Destroyer
8,026
5,057
Andrew
I know and have tried it multiple times but not working .
Gray
502
461
Has anyone had a go at making A raspberry pi streamer
Yes, I use one in my main system.
Then made this self-contained, semi- portable headphone rig.
The music is on the SSD (right) and there's a little DAC behind the Pi:
griffo58
13
5
23
64
Crewe
Looks good hope to start mine soon
Reactions: Gray
Gray
502
461
Good luck to you, I'm sure you'll be glad you did.
If you can flash an SD card, you'll have no trouble. Seriously, I'd never touched an SD card before, so that was the hardest part for me 🤪
Good old Volumio avoids the need for any geekery (programming) 👍
kawuschel
