German Maestro GMP8.3D headphones at Audiologica
Audiologica
Audiologica
1,308
Horsham
Richard Santiago
New stock now in, these excellent headphones are now available for next-working-day delivery
http://www.audiologica.co.uk/headphones/german_maestro_8_35d.html
01403 336 339
Whether used on mixing desks or portable devices, the low-impedance and highly sensitive drivers of the GMP 8.35 D are able to accommodate any situation. Superior diaphragms with copper-plated voice coils create a precise resolution across the frequency-range. Users will be amazed at the dynamic bass response and wide clarity in the mid and high range. With a closed earcup and one-sided cable design the GMP 8.35 D is the ideal partner for the project studio.
Built to last, the GMP 8.35 D is constructed from durable PE material which makes them near indestructible. The padded steel headband features generous cushioning and the ergonomic design creates the most comfortable listening experience possible.
Technical Specifications
Frequency response: 20 - 27.400 Hz
Nominal impedance: 35 Ω
Acoustical principle: Closed
Earpads: Synthetic leather, circumaural
Average pressure on the ear: ~5.5 N
Weight: 220 g (without cable)
Connector: Gold-plated 3.5 / 6.35 mm jack plug
Cable: Coiled, one sided 1.5 / 3 m
Features
Perfect for heavy & long-term use in the field and mobile applications
Easy to drive low-impedance on mixing-desks or portable devices
Sensitive drivers adapt to wide range of equipment
Robust, durable PE material near indestructible
Diaphragms with copper plated voice coils for precise sound resolution
Closed design shields from external noise
One-sided cable guarantees flexibility
Leatherette earpads assure long lasting comfort
Handcrafted in Germany
3-Year manufacturer warranty
Kinchitshaw
