Help with streaming / Bluesound
myles
3,576
1,274
Plymouth
Myles
Right that helps, I think this maybe where the problem lies.
Did I see mention of a recommendation from Bluesound to set the WiFi channel to a certain number? Not a help if you are hard wired.
StingRay
Legend Wammer
9,893
5,220
Suffolk, UK
Ray
Anyone else having problems with QoBuz today?
After a long update yesterday I did not play any music until tonight but for the first time I’m having problems similar to those in this thread. If plays for a while about 20 minutes then stops, the music on the iPad is still playing but no sound. If I pause it and then start it plays but then does the same after about 5 minutes.
Nativebon
MUZIC FIRST
1,157
914
London UK
Ian
Seems I had similar problems yesterday as described on this thread . Only happened the once tho. Would keep watch today.
StingRay
Legend Wammer
9,893
5,220
Suffolk, UK
Ray
I looked on the Bluesound support forum and the last update was a security one that has mucked up a lot of older players, nas and routers, so that maybe the cause although no one has mentioned streaming QoBuz. I have the Node2. I will try again tonight.
StingRay
Legend Wammer
9,893
5,220
Suffolk, UK
Ray
Looks like the issue I had was a one off, since then QoBuz has been working as usual although I have only played around 90 minutes each time.
StingRay
Legend Wammer
9,893
5,220
Suffolk, UK
Ray
I knew this would happen. The problem is back tonight, after about 30 minutes it dropped out, I left it and after about a minute it came back.
egs
