Hifi streaming
Man in a van
1,862
356
113
Staffordshire
Ronnie
Hi all,
Currently, I cast my phone to a Google Chromecast which is hardwired into a DAC which in turn is hardwired into the amp. It's glitchy, keeps dropping the signal and switching off though, and means my phone needs to be in close proximity. It also takes ages to connect sometimes, and finally, I'm pretty sure it's an excellent way of degrading a signal.
Dan
Dan, please tell us about your router, where is it in relation to your Chromecast ?
Is this the TV version of the chromecast or the Audio version?
Does your router provide 2.4 and 5.0 GHz wireless at the same time ?
If so, have you tried to seperate the signal bands (a seperate SSID for each band) ?
Google will help you find the user manual
ronnie
DomT
7,517
5,236
Nottingham
Dom
I have never, ever experienced this behaviour:unsure:
I am sure that there are lots of happy Spotify users but when using Spotify Connect with my Auralic or Innuos when playing a song then using the phone for a non-Spotify activity then returning to Spotify the App has disconnected and needs to be closed and opened again. When the Innuos Sense App first came out it did the same thing but they fixed it quickly in a new release. My Auralic looses connection in the same way about 5% of the time when playing Tidal or streaming CDs. It’s just Spotify that’s a problem (using an iPhone).
By the way am still enjoying your old 909!
hearhere
843
602
113
Portsmouth, UK
Peter
Hi all,
I read here avidly though rarely post, and the advice I'm looking for is probably too simplistic for the forum elsewhere.
I'm about to change music streaming to Tidal. I have a really good amp and speakers, and a decent cd player.
I really love hifi music, but I also like the convenience of streaming. This far I've been on Amazon music unlimited, but I'm switching to Tidal for various reasons which I'll go into if asked, but anyhow.
What I'm looking for as a dedicated device which will either plug into my DAC or straight into the amp if it has a self contained DAC, and will run Tidal without needing my phone or other external device.
Does such a thing exist??
Thanks for any help.
Dan
Dan - The rest of your system certainly deserves a proper streamer. There's tons to choose from, but don't use a phone or PC for anything other than control. Keep the signal confined to audio components that are designed for HiFi.
The obvious suggestion is the relatively inexpensive (£500) Bluesound Node. This is a good streamer that you hard-wire (if possible) to your router and it feeds your existing DAC via its coax digital output. It has a built-in DAC but your existing one is almost certainly better.
For a better quality unit, consider the NAD C658 Streamer / DAC at about £1600. This has a far better feature list and will sound better than the Node. Its DAC may well match or better your existing one, in which case you could consider selling it to part-fund the NAD.
Both the Bluesound and NAD use the BluOS control app (download onto any of 5 platforms including your phone, your PC or even an old Amazon Kindle! This is arguably the best control app out there and it's an important consideration with streamers that the user-interface is excellent.
Incidentally you may prefer QoBuz over Tidal. Both offer vast lists of music at CD quality, but QoBuz also has lots at genuine High Resolution level, whereas Tidal offer MQA encoded files that may or may not sound better than CD quality. In any event MQA needs an MQA compatible processor, which the Bluesound and NAD both have. Both QoBuz and Tidal offer free trial periods of a month or so. Good luck. Peter
Flatty
53
9
13
Sunny manchester
Dan
ronnie
Thanks Ronnie. The WiFi does indeed have separate bands, and the router isn't far away. As far as I can tell though, I have to connect the phone by Bluetooth to the Chromecast (audio).
Presumably this will just degrade the quality.
Would I be better having a dedicated iPad and try and find a way of hardwiring this (if that's possible) to the DAC, or is there a single piece of equipment that I can connect to the DAC or directly to the amp, which will stream a playlist without needing a phone or an iPad or computer?
Flatty
53
9
13
Sunny manchester
Dan
Thanks so much. So how does it work? Is Tidal or quboz already loaded onto the bluesound or NAD, and the phone just tells it what to do?
hearhere
843
602
113
Portsmouth, UK
Peter
Once you have your streamer connected to the router and your DAC (or directly to amp if you use the built-in DAC), you need to subscribe to a streaming service such as Tidal or QoBuz. This costs about £15-20 per month and allows you to stream CD quality (or better) music through your system.
BluOS (the control app) can be downloaded to whatever platform you prefer to use to control the streamer - ie to select the source (streaming service, music stored on your NAS or PC, TV music, world-wide radio stations, Paradise Radio, etc etc), and to search for music available to add to your Queue or Playlist of music lined up to listen to. Lots of other functions too.
It may be helpful if you visit your local Sevenoaks HiFi store for a demonstration of a Blusound or NAD streamer and play about with the BluOS app in the store. If you're new to streaming, this will be an eye-opener to the wonderful world of having umteen millions of albums at your fingertips! You'll never buy a CD or record again, so the subscription cost is a real bargain. Peter
Reactions: Flatty
griffo104
6,703
1,198
Newport
Griffo
Really confused about the bluetooth to the Chromecast, mine connects over Wifi using the Google home app. Never used bluetooth to connect to the chromecast.
The google Home app defines the devices, so my chromecast is called "family room" as that's where it is and then I cast to it from the chrome browser or an app such as Amazon music it asks which device to connect to.
You declare other Google devices such as the Nest in the same way so I can cast to either the chromecast in the living room or the Nest device in the bedroom or kitchen. This is all over your wifi not bluetooth so you don't need your phone close to a device.
Also when I was having dropouts I bought one of these :
This allows you to plug an ethernet cable in to the plug and then plug this in to the chromecast so no longer have to worry about the wifi as such as you are hardwiring it. Sadly, typical of google, they have stopped selling it when they discontinued the chromecast but it may be worth a look on eBay for one.
This may be a cheaper solution than buying more hardware.
Reactions: Lawrence001
Man in a van
1,862
356
113
Staffordshire
Ronnie
I second ther suggestion by @griffo104, in fact my link in post #4 did the same, in a more convoluted manner perhaps :rolleyes:
I can vouch for its efficacity (y)
Otherwise I suggest setting up the Router to provide a seperate SSID for each band and tethering the CCA to either the 5.0 or 2.4 GHz band and connecting by Wi-Fi.
ronnie
Flatty
53
9
13
Sunny manchester
Dan
Thanks, I was a very earlier adopter of streaming, initially Sony music unlimited, then Spotify, then apple (deleted my playlist after spending a week making it) so then Amazon, but this keeps deleting songs. I'll see can I go into a shop I think, and try and get to grips with it. The router is unfortunately in another room.
unclepuncle
14,659
382
Northants
hearhere
843
602
113
Portsmouth, UK
Peter
As long as the router is reasonably close to the streamer (next room maybe), wi-fi should be pretty reliable. Many users rely on wifi for streaming - it doesn't require the bandwidth that gaming or video streaming does. Well that's my understanding! Peter
kengxx
