high quality ply-wood
Biscuit
6,491
8
Cambs, , United King
I'm hopefully going to take a few days off workin the coming weeksto get the plinth for the Sony made (he says - we shall see
I was wondering where I should go to getgood quality marine(?) type plywood? Will the local Homebase/B&Q have it, or do I need to have a look in the Yellow Pages for a local timber merchant?
Also, is there a specific type of ply I should be looking out for?
Unfortunately, probably won't be going for an aluminium sandwich type plinth on this first attempt - not enough time to sort out the CAD and the CNCing, but maybe in the future after I've tried this one, which will be a plain 'lots of layers of ply' design like the ones of the DD museum.
Biscuit
6,491
8
actually, just found a local(ish) timber yard that sells birch ply of the right thickness - so will give them a ring and see if they will do small orders
Setting Son
1,365
52
W Yorks.
Lee
Russell,
The big B&Q's (Warehouse?) do 18mm birch ply. They'll also cut it for you.
hth
jagdesign
641
3
Setting Son wrote:
Russell,The big B&Q's (Warehouse?) do 18mm birch ply. They'll also cut it for you.
hth
B&Q's plywood certainly isn't high quality, I built a guitar cab usingthe exact stuffa couple of years ago.
The nicest ply is marine grade, you can get it from most timber merchants and it can look stunning.Pricey though;)
jagdesign
641
3
Yeah some of it's not bad, I wouldn't want to make a TT plinthfromit though.
Dunno if it'd be big enough buthow aboutmodding a beech chopping board like this one
Really nice timber, great to work with, shouldn't warp at all and best of all they're less than a tenner (if I remembered that correctly) from Asda. I bought one a while ago and ended up using it to make a guitar body:)
JPG
2,941
Bristol
Yep- Tesco do one of those, too. Not really big enough for a TT though.
Marine ply is void-free, and with nicer plys and waterproof glue. WBP- the stuff you will get from B&Q is cheap and has lots of voids in it- mini resonance chambers. Loveley.
TigerTiger
2,107
356
Scotland
George
Aircraft grade birch ply.. cost, probably around 500 beer vouchers a sheet, dont know where to get it, but it does exist, anddef audiophool :note:
If your interested I have some contacts...
Cheers
Geo.
soupdragon
283
Derbyshire
ask for furniture grade birch ply
may need a variety of thicknesses to getthe plinth thickness to accomodate the bolts of the DD deck - sandwich effect.
liam
Youngedennis
