I haven't seen the full trade-in information yet but I would expect so based on previous similar programs.Wow! Do the dealers get to keep the traded-in Lingos? If so, potentially higher trade-in value.
Yes, I was expecting the Krane to end up around there. Clearaudio sells their version of the same arm for $1700 here so it was hard to see the Linn version not being close to or above that price.Certainly makes the packaged Majik LP12 seem like a really good deal.Wow, that's twice the price of the previous "Majik" arms.
The Majik has always been a really good value and has only gotten better with the Karousel and the Krane. With a savings of over $1500 in the US it is almost like getting the arm for free, which is what it has always been in the past. I do wish they could get rid of the Majik power supply and fit the Lingo 12 Volt motor with something simpler to drive it. You would think that something along the lines of the Rega NEO TT-PSU, which they use for their 24 Volt motors, could work for the 12 Volt one and not increase the Majik LP12 cost much. Then we could finally get rid of the PITA slipover pulley for 45RPM!
Do you know how much it costs to build a suspension bridge nowadays?!A grand for an OC-9, wow! That money could push you up the AT range to an ART-7. The suspension change had better be special.
And those changes are a very good idea!Absolutely. That's why I decided on a Majik kit.
My dealer and I added up the costs and even if I change the power supply for the Lingo4 and the standard base for the Trampolin 2, the Majik kit is still very interesting in terms of cost.
I have just updated my order to take the Majik MC with the Koil instead of the Adikt.
- May 20, 2014
- 2,246
- 2,443
- 148
- HiFi Trade?
- No
Not to be confused with “acrow” I did when I first read it…
’troll
I wonder why Linn (knowing what was coming down the pike) didn't forego the Krane at $1800 and simply reprice the Akito at $2000 (or just drop it into the Majik LP12). It is supposedly better then the Krane and Linn has surely amortized all costs associated with R&D and manufacturing equipment for the arm. So it must be pretty much all profit at this point (especially considereing what Linn must be paying Clearaudio to manufacture the Krane - Clearaudio has to make a profit of this deal, too).
You'd think a Scotsman would know better.........
Apparently almost as much as a new Linn cartridge!!!Do you know how much it costs to build a suspension bridge nowadays?!
When I was thinking about going MC with my MDSM/3, my dealer informed me I would have to get an update of the internal preamp card of the MDSM. So there is a MC stage available for it. I suppose that would be the way to go for the Majiks.Was just thinking the same.
One thing that caught my attention in all this is that there's now an MC cartridge at Majik level with no MC phono stage at that level. Linn acknowledge that an MC phono stage must be used.
- May 20, 2014
- 2,246
- 2,443
- 148
- HiFi Trade?
- No
From memory, it’s the Mm/MC card that would be in the Akurate DSM. Not sure about the MDSM/4, though. The spec says that’s a hybrid analogue/digital stage.When I was thinking about going MC with my MDSM/3, my dealer informed me I would have to get an update of the internal preamp card of the MDSM. So there is a MC stage available for it. I suppose that would be the way to go for the Majiks.
’troll
I don't know that kind of detail, but he guessed it would be around 500 euro.From memory, it’s the Mm/MC card that would be in the Akurate DSM. Not sure about the MDSM/4, though. The spec says that’s a hybrid analogue/digital stage.
’troll
Is this the same MM/MC card that would be in the Selekt DSM?From memory, it’s the Mm/MC card that would be in the Akurate DSM. Not sure about the MDSM/4, though. The spec says that’s a hybrid analogue/digital stage.
’troll
yeah, thanks. Mine is a /3. The current /4 version cannot be upgraded.
Can configure the Majik DSM to have a Moving Coil (MC) input? Or use a MC upgrade board to provide MC
No, the internal circuitry is only configurable for Moving Magnet (MM) and Line Level.(The earlier Majik DSM's had the option of an upgrade board to allow this, But this is upgrade board cannot be fitted to the Majik DSM/4.)
So that means that indeed, there is no mc at Majik level.
That's a bit of a drag, fortunately there are excellent external phono stages from Lejonklou, although too expensive for a Majik. Well, there are still a number of Lintos out there...Can configure the Majik DSM to have a Moving Coil (MC) input? Or use a MC upgrade board to provide MC
- May 20, 2014
- 2,246
- 2,443
- 148
- HiFi Trade?
- No
That I don’t know.Is this the same MM/MC card that would be in the Selekt DSM?
- May 20, 2014
- 2,246
- 2,443
- 148
- HiFi Trade?
- No
Yes, it’s very odd introducing a MC when the DSM doesn’t support it. Makes me wonder whether the MDSM is due an enhancement.That's a bit of a drag, fortunately there are excellent external phono stages from Lejonklou, although too expensive for a Majik. Well, there are still a number of Lintos out there...
’troll
For the new Koil cartridge, Linn recommends a capacitance of 100 nF; the internal MC board of the ADSM/3 has a fixed capacitance of 180 nF
The capacitance isn't really that relevant for MC's, whereas for MM's it can lead to peaks or dips in the frequency response, if mismatched. For MC's the load (Ohm) is more relevant.For the new Koil cartridge, Linn recommends a capacitance of 100 nF; the internal MC board of the ADSM/3 has a fixed capacitance of 180 nF
Thanks TendaberryThe capacitance isn't really that relevant for MC's, whereas for MM's it can lead to peaks or dips in the frequency response, if mismatched. For MC's the load (Ohm) is more relevant.
I'm not an MC's lover, for practical reasons (3 kids around the house and stylus replacement every 2/3 years ...).
M.
Similar threads
- Replies
- 5
- Replies
- 6
- Replies
- 4
- Replies
- 2
