Innuos Zen III Vs ZENith
Sign Up To Remove This Advert
Fourlegs
WAVE Digital Cables
6,391
4,001
Melton Mowbray
www.wavehighfidelity.com
There is a connection to the router for ripping and control purposes.
I don't use it as a multi system device.
OK, I have exactly the same connection as you. The PhoenixNET switch inserted between the router and the Innuos (or indeed AN OTHER streamer) gave me an audible uplift in SQ. I am told that it also does the same for the top of the range Statement.
It Cost How Much!?!
Twisted
16,675
1,261
Hartford, Cheshire
Bob
How can that happen, as the flow of data is from the box to the DAC? In my set-up the only purpose of the LAN connection is to control the box via a tablet and to get the information on the CDs?
Fourlegs
WAVE Digital Cables
6,391
4,001
Melton Mowbray
That is exactly how I use mine as well. There is all sorts of chatter between the Innuos and the tablet, reporting back on track progress, loading track and album info onto the tablet etc (albeit that Innuos have sought to reduce that as much as possible with their 2.0 software but they have not reduced it to zero).
The improvement that the Innuos PhoenixNET brings to the party is definitely not just for those that stream and also applies to just playing local files stored on the Innuos. There are those who say it is even better than pulling the router cable from the back of the Innuos.
Edit, I have assumed you are using the Innuos 2.0 software and app and not Roon but that was an assumption. Roon has more chatter and data loading to the tablet than 2.0. Also, I forgot to ask if you are using the Innuos in ‘offline mode’ or not? This is a setting within the 2.0 software.
A.S.
311
298
Hertfordshire
The money spent on the Zen/Zeniths followed by extra spent on power supplies/filters/magic stones runs into thousands. Wouldn’t it be easier to have an ever expanding Deezer/Tidal/Qobuz/Apple/Amazon sub etc which costs just over £100 a year for FLAC minus the hassle of ripping, editing metadata, keeping backups of SSD/HDDs? In a few years, these boxes will fail or Innuos will stop providing software updates. For the cost of these boxes you could have 20-30 years of FLAC subscription minus the hassle of ripping and managing data. This something that I have been mulling over.
It Cost How Much!?!
Twisted
16,675
1,261
Hartford, Cheshire
Bob
I use Innuos 2 software and the latest APP.
It Cost How Much!?!
Twisted
16,675
1,261
Hartford, Cheshire
Bob
I have a Tidal subscription and TBH it doesn't sound as good as ripped CDs. Mind, my CDP sounds better by some margin to my ZEN III at the moment.
Also, a lot of CDs I own are not available on one platform, if they are it's the wrong version of the song etc..
Reactions: leroyd
leroyd
115
50
May I ask what DAC are you using with the Zen III and what CD player are you using? Is the CD player using the same DAC as the Zen?
It Cost How Much!?!
Twisted
16,675
1,261
Hartford, Cheshire
Bob
Wadia X64-4 DAC, Wadia WT2000 transport.  ZEN goes USB to a Gustard 12 SPDIF converter and then Coax (Transparent Reference) to the DAC. Transport via ST optical to the DAC. I may get a better USB converter if I can find one.
If you are local pop in.
leroyd
115
50
Thanks for the invite but I live in the west of Ireland, so no can do. When I got my Zen and ran it through the same Dac as my Primare CD32 player (using the CD32 as a transport) CD and ripped files sounded identical.
Reactions: hifinutt
josh
1,055
35
NW London
If I can ask, why are you thinking of investing so much in a ZEN if it doesn't sound as good as your CDP? Maybe try a different/better streamer once you've ripped your CDs?
hifinutt
14,700
3,124
midlands , , United
phil
thats good to know . just spent 3 days trying to get a zen mark 3 to work and will also be comparing with various cd players . for some strange reason the innuous would not connect via my TP link deco m5 mesh which is supposed to be a mini router . Its only worked after you guys and other suggested plugging it direct to router . as thats a long way from the hifi it wont be practical !!
leroyd
115
50
Same as you, as my router is too far away. I use this and it works perfectly.
https://www.tp-link.com/uk/home-networking/range-extender/tl-wa850re/
Reactions: hifinutt
hifinutt
14,700
3,124
midlands , , United
phil
just tried a few tracks in the zen . i cant really hear any improvement over my marantz used as a transport yet. early days yet .
Reactions: DomT
wHIZZY
Measured Subjectivist
1,797
707
Sunny Devon
Dave
Personally my enthusiasm around the Innuos range is the ability to rip, store and organise all your music in one place, plus easy access to internet radio and online music streaming services, together with the ability to control it all from your chair via the app. With regard to sound quality I would not expect the DAC in the Innuos Mini to sound better than the DAC you already have in the Marantz. To get a better SQ I think your will need a high quality external DAC, say something like a Chord Mojo and upwards.
Reactions: justinhd
justinhd
74
98
23
Justin
The replay from ripped is not bad and (in my system) find it slightly better than the Node2i.
Also great to see (per the Innuos feature request page) that Amazon music connectivity is “Planned”.
hifinutt
14,700
3,124
midlands , , United
phil
thanks i think the black ice heavily modded valve dac is pretty good . i have only used the zen with that . take quite a bit to beat that dac !!
Reactions: wHIZZY
