IsoAcoustics Gaia Loudspeakers Feet 2
Status
Not open for further replies.
I reviewed these feet at:
https://www.hifiwigwam.com/forum/topic/145382-isoacoustics-gaia-loudspeaker-feet/ as a result of my good audio buddy Kevin Fiske telling me about them. I thought you would be interested in his views.
As others have observed, the speaker/room interface is more complex than it might at first appear.
Spikes were long thought necessary to stop speakers from oscillating fore and aft in obedience to Newton’s Third Law as the driver cones pump back and forth. They were also assumed to conduct away undesirable vibration in equipment racks and so forth. Now some manufacturers are inviting us to accept that using spikes or any other form of coupling was the wrong approach all along.
The argument goes like this: spikes transfer energy from the speaker into the floor, and can cause it and the connected building structure to sing along with the music. Concrete and timber floors ring at different frequencies, but this unwanted accompaniment always lags behind what the speakers are producing. The speakers themselves, and the kit table, they are excited by the delayed, returning energy, resulting in a smeared, phasey corruption of the original signal.
Canada IsoAcoustics is a proponent of de-coupling. I borrowed a set of its Gaia I isolator footers to try with PMC MB2se speakers. At circa £1200 for eight, they are suitable for speakers weighing up to 100 kg, Other IsoAcoustics models at different prices are designed to work with lighter and heavier speakers.
Gaias are not merely Sorbothane pucks in fancy clothing. They are a patented design using multiple specialist gels with specific Shore durometers that are mechanically contained within a non-ferrous metal shell in such a way as to resist deflections while providing bi-directional isolation tuned to be effective right across the audio band for objects of a given weight range
The Gaia base has a soft concave cup that grips smooth surfaces such as tiles and wood, while the top is threaded for bolting directly to the underside of the speaker or stand base. Optional gripper cups allow the footers to be used on carpeted floors. The Gaia 1s are 64 mm in diameter, 49 mm high, and come with four alternative sizes of fitting bolts. As can be seen from the picture, they have a quality look. I was careful to achieve an identical above-floor height to that provided the MB2s’ factory-supplied spikes. The fitting process is fiddly: the footers are directional so need to be secured in the labelled orientation. Satisfying this key requirement while achieving plumb speaker side walls and a suitable tilt towards the listening position was not easy the first time around, but I got better at it.
After fitting the Gaias I noted that the sofa, on a thick wool carpet over high quality underlay on a screeded, insulated beam and block concrete floor, was no longer vibrating on bass-heavy passages. The bass was still present, but mostly as air pressurisation only and, not only that, but much cleaner too, tighter, better timed with less bloom and overhang. Tonal quality was more easily appreciated by listeners.
As IsoAcoustics has it, distortion from the floor imposes on both speakers nominally equally, and therefore appears centrally in the sound field, obscuring sound staging. In my system the Gaias released a greater still sense of 3D-ness and placement resolution from the MB2s. At one point I thought that with all the disruption and sweat of fitting the footers that I had fluffed the re-connection of cables and got the PMCs out of phase, but no; the Gaias not only pushed the distant wall of the sound stage even further away for a greater sense of depth, but on some recordings they extended it sideways too, outside of the left and right speaker axis.
Web Page: https://isoacoustics.com/products/gaia-series/
Paulssurround
Space Explorer
3,500
3,163
Vancouver
Thank you George for the great review.
I know more than 20 People that have now installed Isoacoustic Gaias to their speakers, and are extremely impressed with the sound quality improvements they have made to their HiFi system.
Reactions: Amormusic
George 47
Subjectivist
9,061
5,618
United Kingdom
Glad to be of service. Many more reviews to come. :cool::cool:
Newton John
420
771
113
Cumbria, UK
After moving house, I found that I'd lost something in terms of imaging from my Komris. Gaias restored this for me.
Other improvemets were more nebulous, probably because I have a concrete floor.
DocC
19
63
North Berwick
Hi George, thanks for the excellent review! From my own experience in a smallish room above the garage in our previous house Townshend seismic platforms (Size 4) under Linn K350A totally transformed the extreme quality of the bass (first noticed on “The Comet is Coming” tracks Summon the Fire and All that Matters is the Moments. Music probably not to everyone’s taste! The Townshend’s seemed to put the speakers back in control! Possibly no longer needed as new house has concrete floors, but will wait to assess when system rebuilt, and as could be awkward to place in the new room was considering an evaluation of the more convenient Gaia I.
Taming of the bass and introducing a Melco to isolate the “noise” on the network have been my greatest musical improvements so far. Hard to assess without home demo!
Andrew
George 47
Subjectivist
9,061
5,618
United Kingdom
Andrew
Can only agree and I have championed spikes for many years. And I did not think the Melco would do anything to help the 'perfect' digital signal. But not so, via evidence of my ears. And some say that so-called digital signals are actually analogue representations of digital. But that is another issue. And as always, it is about the music and whether you enjoy it.
Status
egs
