Kontrapunkt "B" Advice
Wallman
452
-1
Was wondering if anybody out in the great WAM has any thoughts on loadings for this M/C, if you have found a better setting than the recommended from Ortofon :?
gingermrkettle
1,567
38
Warwickshire
Stephen
Resistor loading depends on your taste in sound and the characteristics of your room and system. Using effective 470ohm loading as opposed to 100ohm will give a more effusive, less damped sound which may be good if everything else is a bit on the dry side for your taste. I would stick with the standard tracking weight and VTA settings though to keep the inherent neutrality intact.
Wallman
452
-1
All advice most welcomed :^
kawuschel
