Linn Owners
Linn Akurate DSM/Akubariks Exact Katalyst poor sound
Paul_N
21
24
23
3rd Rock fromthe Sun
I use a combination of an Akurate DSM Exact/Katalyst and Akubariks completely upgraded as well. The sound though seems to be shrouded, like a curtain is hanging in front of it.
Mostly I use Tidal as source (the high quality subscription). By using a simple Denon record player DP-1200 it sounds better, which seems weird to me.
Can I have done something wrong installing the system? Need of different network cables to the internet source? Or do I need specific settings in Konfig?
Any help is much appreciated.
Peter
I haven’t used Tidal or similar but what’s your ADSM like with its other digital inputs - I.e. radio, playlist, songcast, hdmi/toslink?
My LP12 doesn’t generally sound better to me than music from those other sources.
So I’m wondering if it’s something  just re Tidal or a problem with all your digital sources? Not that I will know the answer but others here might.
PeterHawks
27
6
Thank you for your reaction. All the other digital inputs result in more or less the same result, so I try to check my complete setup from the beginning on.
zee9
Audio Junkie
1,298
680
New Jersey, USA
Zorawar
Did you ever resolve this?
Adsm/3 >> Akurate 4200/1 >> Majik 140’s (Silvers/K400)
kengxx
