2022 The WAM show
Club statistics
Members:
550
Threads:
3516
Discussions:
6
Photos:
Linn Owners
Linn AV5125 Repair
Chetys
16
6
3
UK
Does anyone know someone who repairs older Linn amps in UK, preferably local - I am in the W.Midlands.
It is an AV 5125 and I reckon needs the dynamik power supply re-capped.
Unfortunately I bought second hand from a HiFi retailer (so thought I had some safety, but after months of back and forth emails they are a waste of time) in Northern Ireland who flat refuses to repair it, saying I blew the amp. It was used for about 3-4 hours!
The amp started taking tme to power up, no blue light and making clicking noises, then after 15 -30 secs it would power up, blue light comes on. After about 5-6 uses it just failed - would not power up at all. No bangs.
Obviously I am very experienced with HiFi, all was connected correctly. If anyone can shed any light on this sort of fault it would be appreciated also as well as any repairers.
I have tried Class A Audio, but he doesn't do this sort of repair.
Linn will service it, but the cost will end up high considering the amp age.
Cheers.
formann
Øyvind I
168
113
63
Ski Norway
Linn do service these now. There is a fixed service charge and there may be some small country prices but from Sweden it is approx GBP 350 + postage which also gives you a nice warranty. This is probably thanks to EU requirements of service up to 10 years. Rumors are that this may also be pushed to 20 years which is really good.
Øyvind I
akamatsu
Sourcerer
4,875
4,564
Point Roberts, WA (Vancouver)
Michael
I had an experience of a used AV5105 failing days after purchasing through a dealer. I had bought a pair of the amps so I just had both of them recapped. It was expensive, and it took a lot of time. All this happened years ago, and the amps are still in service performing perfectly. The time and money spent are long forgotten. It all came with a lesson about buying used equipment. It does come with risk.
Sorry that this is no help in finding a repair facility. But you aren't alone in your experience. In the end, it will all work out. ;)
Dasher
826
834
98
I've had a couple of 5125s repaired by Linn over the last decade - both are still performing flawlessly. I have a third one that this thread has reminded me to get boxed up and off to Glasgow.
entdgc
517
427
Congleton, England
Krescendo Audio should be able to fix it.
They are in south England though
What Paul says. The fault sounds very similar to the well known fault affecting the A4200's where a small component on the PSU fails. Mine failed and would not turn on without attention from a hairdryer but once running they worked perfectly until next turned off. I traded them in to Krescendo and I know Richard was able to repair them before selling them on.
Chetys
16
6
3
UK
Thanks Paul & Formann - I had forgotten Krescendo (bought from Richard numerous times). Linn 10 years warranty - i would have to check if thats the same in UK (now we are not part of EU).
Reactions: Paulssurround
Chetys
16
6
3
UK
Akamatsu - Yours sounds like my experience. I have also pretty much decided not to buy second hand. I've bought loads of second hand in past all from reputable people but these guys have seriously spouted so much rubbish. Too much hassle.
Reactions: akamatsu
Chetys
16
6
3
UK
Dasher - Yes I have 5125s & 4200 working for years.
entdgc - thanks for the info - I suspect its that...
flo1984
wammer
372
16
23
I had in the past Linn Kisto ,nobody wanted to check it,not even Linn factory.I would never ever buy any Linn product.
Wenge1
1,076
3,421
178
West Yorkshire
Turbocharging by another name ...... ;)
  • Haha
Reactions: entdgc
Moomintroll
2,130
2,252
The 10 years doesn’t refer to the warranty period. It means that manufactures have to make parts available for that time, whether or not the device is still in production or not. This is under the Right to Repair rules in the UK.
’troll
Moomintroll
2,130
2,252
It’s a shame that you had a bad experience. If the Kisto was no longer supported, that would explain why Linn wouldn’t look at it. If it had been modified or had previously had Unauthorised repairs they wouldn’t touch it either. It was a very complicated device, so no surprise that you couldn’t find anyone else to look at it.
’troll
hodge555
82
62
38
London, UK
www.hoth.uk
I bought my 5125 back in early 2002 and it's been used very regularly ever since.
In August 2020 however it popped something from the PSU board.
I took it to my dealer who sent it to the factory for repair, cost £360.
I thought that was pretty good tbh.
I did buy myself a spare 5125 however, just in case :) (actually it's earmarked for a 2nd system with my old 5103, which may someday be built)
Reactions: silkie
hodge555
82
62
38
London, UK
www.hoth.uk
’troll
The Kisto and Kinos were dropped from Linn support in Sep 2017.
They are great analogue pre-amps and well worth owning.
I run a Kinos.
Having said this however they did have problems, notably from heat which would then affect the OS.
The Kinos suffered more due to it's smaller casework.
The later ones should be OK though.
One tip is never to turn them off, just leave them on standby.
My current Kinos is my second one. My first would get quite hot and it started to show OS problems, even locking up occasionally and then would struggle to re-start. My second one is a much later s/n and so far is fine (touch wood) and I note that it has a different main board.
hodge555
82
62
38
London, UK
www.hoth.uk
Note that the 5105 shares components with the LK240 and they both had a recall on them to replace some capacitors which could become a fire hazard, so make sure to check that this was done. There should be a white sticker with the Linn logo on it and something to the effect, eg CAP 413 FTD.
Reactions: MickC
MickC
Expert Thread Disruptor
1,061
869
MYOB
Even if there is a sticker I’d probably query the serial no. with Linn as a double check.
Mick
vicdiaz
73
Trujillo Alto, PR
Victor Diaz
If the sticker is not in place check if the four black 10,000uf/63v caps were replaced with 6,800uf/85v ones. If so, then it is safe to use the amp. Linn used higher voltage but lower capacitance caps because the higher voltage 10,000uf caps would not fit in.
Reactions: hodge555
