Membership Upgrades
Club statistics
Members:
546
Threads:
151
3418
Discussions:
6
Photos:
Linn Owners
Linn Solo Concern
AlbertF
52
56
UK scotland
I have recently taken delivery of a new pair of solos to accompany my Klimax DSM and 242s. The sound is all I could wish for however, I was not expecting the fans to come on and detract from the experience as much as they do. Even without stacking the boxes I find the fans kick on after an hour of enthusiastic play, but thereafter even when the boxes cool down they still come on and audible over quiet passages of music.
At volume level you could  ‘talk over’ they seem fine but once volume increases to make conversation difficult the fans start up after an hour. I am still checking out their behaviour. Should I expect this and therefore I need to adjust my expectations ?
Any first hand experience of the Solos would be greatly appreciated and whether this is to be expected
tpalm
7
8
8
Finland
Tuomas
My previous 92db sensitivity dynamic speakers never turned fans on but my current planar magnetic speakers with 86db sensitivity turned fans on after a serious Infected Mushroom session
  • Haha
Reactions: AlbertF and zee9
HansBertil
845
553
113
Sweden
Bertil
Unfortunately I have no experience from Solos although I would very much like to. The cooling down time will be about the same as the warning up and likely even longer since you’re still using the amp during cooling. To add to that there might be a bit hysteresis in the temperature sensor as well. What I can see from the specs the sensitivity for A242 is 87 dB/W @1m. So rather power hungry if played loud.
Ben Webster
System doesn‘t matter - if you have mine
949
113
Frankfurt a.M. 🇩🇪
Even the 242 are very demanding, one pair of Solos are the optimal fit.
On a scale 0-100 everything below 75 should work without fan (depends also on room temperature, kind of music and RCA/XLR).
What cable do you use between Solos and 242 (brand, length, single or multi-wiring)?
MickC
Expert Thread Disruptor
1,061
868
MYOB
Make sure you have enough space above them. I use mine in an Isoblue rack, one each on a shelf, and the fans never kick in, although the cases get quite warm/hot after a while.
Mick
Moomintroll
2,124
2,241
Chord Rumour X is only 1.3mm2 cross section, you may want to try something with 4mm2 and see what that does.
Reactions: Nestor Turton
Ben Webster
949
113
Frankfurt a.M. 🇩🇪
Length shouldn’t be an issue and I have no experience with Chord Rumour X.
But as @Moomintrollsaid maybe  you can try another cable to make sure that the cable isn‘t the problem.
zee9
Audio Junkie
1,278
657
New Jersey, USA
Zorawar
That sounds weird to me. I have mark 1 242’s and I’ve run them passive, aktiv and Exakt with akurate amps. All with k400 cable. For a passive setup I used a split k400 (k200?) cable and never had my fans come on? Cable lengths are 14’.
Until a week ago I was dying to find solos but have had no luck in the used market. I usually don’t go above 65 on the volume but maybe 70 once in a blue moon to scare the neighbors.
Adsm/3 >> Akurate 4200/1 >> Akurate 242 (mark 1) Silvers/K200
Fordy99
13
4
8
I have similar problems with my Twins. Using 2 to bi-amp a pair of 350’s. The fans come on quickly and although not intrusive, you can hear they are on.  More worrying for me, is that one of them (the older non Dynamic amp) regularly clips and I lose sound until it behaves itself. Given I listen to rock/metal at loud volumes it is getting tiresome and I’m thinking of upgrading to Solos (until I saw your post !!).
AlbertF
52
56
UK scotland
Interesting. I wondered if the same might apply to the twin. I like plenty of volume and a bit of rock hence my concern.
Fazioli
178
165
73
Nottingham UK
Andrew
After owning 8 Solos for 10-15 years or so, I have to say "What fans?" I can't ever recall triggering them even though they have been played quite hard at times for extended periods. Their cases get hot, but never enough to trigger a fan. Presumably they are positioned such that they can freely ventilate.
It may be that there is a fault which needs investigating by Linn HQ-especially as you say they are new. Good luck!
AlbertF
52
56
UK scotland
Thanks Fazioli and can I ask what speakers you are using?
My solos are currently not stacked or air is free to move around them
Chris 1970
Love colors in music
432
523
France
Christophe
Albert,
My experience:
1) during the 4 years I had a pair of Solo and Komri in passive mode (20 years ago) – first model with no Dynamik – the fans were activated, when I listened to high volume (on the Klimax Kontrol: 60 to 70). I don't remember how they were placed on shelves.
2) during my first audition of the NGKDSM in the Linn shop in June 2021, it was a pair of Solo – Dynamik version – with 10.000€ Martin Logan.
Volume was at 65 on the DSM. The fans worked the 2/3 of the session. The Solos didn't have a lot of air as they were placed on the 2 shelves under the DSM, and close to the wall.
3) Klimax Twin Chakra – no Dynamik – in active mode with Komri are dead silent in my experience in 2 different homes (on the Klimax Kontrol: 60 to 70) since 2006.
For me, Klimax Solos need to have a LOT of air above them, best with nothing at all above. So you need to separate them completely, one on the left, one on the right.
Again, in active mode, it's not necessary.
Excellent amplifiers by the way 😊
BenHao
7
6
Is dust a concern? The linn solo amp has air vents on top, so that makes it easy to dust to get in.
