Oh, no! So you don't have a real Klimax LP12, but a Basik/Klimax hybrid. Oh the shame!Confession time; the lid on my Klimax LP12..........................................was pinched from a Basik turntable. :sofa:
Why after investing in a Klimax level deck would we hide it under a tinted lid. :sofa:
By the way, it sounds better with the oval logo badge, the rectangular one causes standing waves between it and the edges of the dustcover. (What do you mean it isn't April 1st?)
Transparent aluminum wasn't invented until stardate 8442.5 (until Scotty came back in time and gave the formula to Nichols in 1986)!Only if it's transparent aluminum.
In most cases when a customer has me replace a lid it is because it is broken!Well, the new lids are supposed to make the old ones sound broken.................... :brick:
A badge of any shape was an early example of 'upgrade strategy' when it was discovered that their presence introduced damping qualities that had a marketable value. The original LP12s had no such damping badge, and as the lid couldn't be removed without the use of a screwdriver it is a matter of simple logic to deduce that the difference between the old and the new is down to the addition of a badge!By the way, it sounds better with the oval logo badge, the rectangular one causes standing waves between it and the edges of the dustcover. (What do you mean it isn't April 1st?)
Ah, but the early LP12 dust covers had a damping aluminum strip on the front!A badge of any shape was an early example of 'upgrade strategy' when it was discovered that their presence introduced damping qualities that had a marketable value. The original LP12s had no such damping badge, and as the lid couldn't be removed without the use of a screwdriver it is a matter of simple logic to deduce that the difference between the old and the new is down to the addition of a badge!
Mine has a smoked lid without logo but does have a plastic support on the right hand side to prop it open.
Pre Valhalla.
Pre Valhalla.
Similar threads
- Replies
- 28
- Replies
- 24
- Replies
- 6
- Replies
- 1
