For my next cripplying round of overthinking I will mostly be focusing on DSP.
I've pretty much made my mind up that I'm going to build a few subs as my next upgrade step and couple them with DSP, but I'm not sure which DSP route to go down, what boxes to shortlist, what are important features, pros and cons to look out for, trade offs to make, impact on signal chain to to consider.
Here's where my shortlist is so far, am I missing any key options? any other pros/cons to consider?
DSP
URL
Pro
Con
PC running something like Acourate and HQPlayer
https://www.audiovero.de/en/acourate.php
Stupid number of taps "ultimate solution?". Can be combined with a streamer and server
It's a PC! Need to figure out how to build a high quality silent, low EMI/RFI solution
Roon or Jriver with convolution filters made with REW or Audiolense
https://juicehifi.com/
cheap with REW
limited functionality
miniDSP - SHD
https://www.minidsp.com/products/streaming-hd-series/shd
Dirac "auto" configure with a mic
Less functionality
Roomperfect
https://lyngdorf.steinwaylyngdorf.com/roomperfect/
Epic reviews, auto mic config
Less functionality
Linea research - ASC48
https://linea-research.co.uk/asc48/
Studio grade (?) lots of features & power
Cost, complexity, not as many taps as a PC
I've read a few articles and posts about PC based options being "the best solution" due to the software, options and quality that can be created from effectively unconstrained taps.
As a computer nerd I'm quite drawn to a PC option, however I'm a bit paranoid about being able to build a PC that I'm happy to connect directly to my hifi - most likely this would be via a USB connection to an external DAC. however it will connect into the same power bar as the hifi so need to make sure the PSU is clean, and the USB connection is perfect, clean & noise free.
I'm mindful of all the conversations about clocking (and reclocking) and the differences between USB data transmission clock versus DAC sample clock, even so I know that generally PCs have bloody awful clocks. I don't know if I will ever try reclocking with something like a mutec but having the option to do so wouldn't be a bad thing.
Building a crazy "audiophile" grade pc like this one seems a step too far https://audiopc.shop/en/winkel/audiophile-music-servers/reference-audiophile-music-server-coffee-lake-fc5-ppa-studio-paul-pang/
but what high quality options & considerations should you give to a PC in the audio chain if you are striving for high end sound reproduction? making it silent running is a given. Audiopc sell "audio grade" USB cards, is that key? What PSU options are out there to make sure it's not dumping loads of crap onto the hifi power bar?
DSP
URL
Pro
Con
cheap with REW
miniDSP - SHD
Less functionality
Roomperfect
Less functionality
