After a reasonable amount of trial and occasional error testing through several bake offs, I think I am going to go down the route of bi-amping my big Snells.
Mid and treble will be picked up by 300B loveliness or similar, but that is for later - my KT88 amp can do that for now.
Considering now the amplification for the bass units which have 12” drivers in sealed boxes with a separate crossover (I guess more of a filter ) up to 200hz.
I immediately thought of class D but not sure the impedance is going to be in spec (my valve pre output impedance is c. 5kohm). What would you recommend new or second hand with the following specs?;
- 200w plus
- input impedance 50k plus
- with output / volume control
- under £1k
- 200w plus
- under £1k
