Question for transfomer gurus
harmonica98
259
4
Tom
I bought a step-up transformer off eBay using UTC A-21 transformers. While not doubting the quality of the transformers. I have had variable results with it, but basically have had trouble getting enough gain. Thinking it was a system-matching problem, I put it in the classifieds.
Subsequently I have had some feedback that these transformers might not be ideally suited for phono use; it seems the most commonly used UTCs for phono step-up are A10, A11 and A12. The specs are:
Pri. 50/200/250/500/600: Sec 50/200/250/500/600 20-20KHz
Can these be wired for SUT purposes in some way? Or could they usefully be used for another application?
Thanks for the help.
G
Surely one of the slide rule gurus here can answer this one?
Tenson
407
I don't know the txs but for step-up you want a low impedance on one side and high on the other. Small coil to big coil = small voltage to big voltage.
anubisgrau
3,800
28
Belgrade Serbia
Gordan
i'm not a guru but in the highest step up ratio (50 to 600) you can get it wired, your transformer has about 1:3.5 amplification which is unsufficient, hence not enough gain... other taps are even worse with less gain
harmonica98
259
4
Tom
Thanks for the advice chaps. I think I'll stick it on eBay and hopefully someone will be able to make use of the transformers. I'll chalk it up to experience!
kengxx
