Room treatments
Room treatments, do you use any?
  • My room is fully treated
    Votes: 0 0.0%
  • My room is part treated
    Votes: 0 0.0%
  • Its something I'm considering
    Votes: 0 0.0%
  • I just use normal furniture, book shelves, rugs etc
    Votes: 0 0.0%
  • No, never thought about it
    Votes: 0 0.0%
  • No, I would never use any
    Votes: 0 0.0%
  • I use electronic room correction eg TACT
    Votes: 0 0.0%
  • Total voters
harv
1,640
84
deepest S.London, ,
erm... guess
Will all the reports from the Hifi shows blaming the room, just intrigued how many people have actually made or had to make changes to their listening room ?
as an aside, my room has one solid exterior wall, one with a huge window, and 2 plasterboard style walls. Should speakers beagainst a dead or live sounding wall?
jonjin
4,711
4
Rug... best upgrade ever! And I spend hours adjusting and adjusting my speaker positions which are currently 59 cm from the back wall and 99 cm from the sides...
JJ
Shakey
781
Wallingford, Oxon.
Gavin
I voted twice (
) as I have the usual bookshelves etc but I have never thought about it. My other half definitely wouldn't be having diffusers and the rest of it stuck to the walls...come to think of it I wouldn't either. I think I'd rather spend money on music despite the advantages that I'm sure are possible.
A
adam
I did my room the best I could,the improvements were huge,the best thing you can invest in,wife permitting,I will do the shop once my liscense comes through.
Shakey
781
Wallingford, Oxon.
Gavin
Hmmm, perhaps I should get some of those metal cup thiongs ina block of would as discussed in the "For Tones" thread...
I'd really like to hear what can be done (with proper room treatments, not metal cup things)!
harv
1,640
84
deepest S.London, ,
erm... guess
What sort of things did you do ?
Anthony
2,057
16
103
Edinburgh, UK
i voted that i just use normal furniture, but still don't have enough yet.
i mentioned curtains to my girlfriend (they would go on one side wall) and she said the blinds are ok and didn't really think it's worth the expense just for acoustics. I also mentioned on tuesday about maybe hanging some nice materially thing/rug on the other side wall instead of framed pictures, but that didn't go down well either.
It;s still a bit echoey for my liking, but getting better. rug and bookshelves have definitely helped and a nice, softarmchair should also improve things. wooden floors may look good but are terrible for acoustics.
Ideally I'd like a separate listening room treated where necessary with GOOD LOOKING treatments/furniture etc. back in the real world i'll just have to make do with what is acceptable to both of us.
Vic Mackey
319
Below the Noise Floo
My room is fully treated. There are lots of products and coverings of absorbing and diffusingmaterials about so with a bit of imagination you con easy treat your room. Just depends how serious you are about this hobby.
Anthony, that echo you can hear is flutter. I guess you have two reflecting walls facing each other.
Vic
A
adam
Hi Harv,
The first thing I did was pick matty at RPG brains and help and alot of reasing to help me understand what you need to do,why?and where to put it.
I started out with foam from RPG and matty,I helped tame the livelyness of the room,and bass traps for the corners.It helped but didn't solve the problem,so I made them thicker to help the coefficents (spelling).Making them thicker by using rockwall to a depth of 8-10cm helped trap more freqs I was having problems with.
I then bought some fabric to cover them,hung them on the walls behind the speakers,first reflections,bass traps for the corners,and more absorbtion for the rear wall.
The effects were startling,this is when I really saw the importance of treating a room,for me it was OK as the room was built as the entertainment room.It still has some bummer notes at low freq probably due to alot of glass down one side.
Laugh at a carpet,but it makes a really big difference,hard surface floors and lamite are killers of good sound.
rockmeister
18,067
711
Scotland
it does matter...it really does...no snake oil, but it's a compromise between living and hifi, so I arrange the room as best I can according to sensible practice.... Concrete floor 3/4 rugged, bookcase on one side wall, window with heavy curtains on the other, large setee facing spks...fairly standard...if it sound a bit hard, consider hanging a rug behind the setee, or try drawing the curtains, but otherwise that's it.
S
smu
Auralex 50mm foam wedges on the wall behind my speakers and one on each side wall. . . . as Adam said, the improvements to the sound and especially the sound stage are huge.
smu.
Kinchitshaw
